June 30, 2020 at 7:56 am
Tharathep1234
SubscriberDear all,
I'm doing simulation of flowing in micro-channel PCHE (counter flow). I'm quite confuse about solid-fluid interface.
As a figures, adjacent cell zones are different between them.Which one is correct?
(I thought interface should be adjacent solid domain and interface-shadow should be adjacent fluid domain)
And when I created name selection with interface name, ANSYS Fluent will create shadow zones automatically, is that right?
Thank you
June 30, 2020 at 8:04 am
Amine Ben Hadj Ali
Ansys EmployeeThat is a coupled boundary: leave it as it is.
- The topic ‘Solid-Fluid interface’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
