3D Design
3D Design
Solid edge file in Workbench 19.0
    • aa02004
      I'm trying to upload an ST10 file from solid edge into workbench 19.0 student (fluent) for CFD application. First I import the geometry file (.par). Then I right-click on Mesh to update or refresh, but it gives me an error stating: 'No compatible interface found for this file type'.
      Thank you
      The Student license does not include the CAD plugin interface to import directly.
      Instead, you click on Geometry to launch SpaceClaim, then you can open the .par file from SpaceClaim.
      If you get any issue in the transfer, export a neutral file from SolidEdge like a Parasolid file then Open that in SpaceClaim.
  • The topic ‘Solid edge file in Workbench 19.0’ is closed to new replies.
