August 10, 2024 at 10:39 pm
Bastian Bruck
SubscriberHello, im trying to simulate a solar water collector, but im having problems heating the water in the fluid region. My model consist of 3 volumes. The top one is the air pocket where the sun rays comes throught and heats up the copper volume which heats up the fluid region.Â
In the simulation i use the rosseland solar model.png)
The fluid should heat up, but it doesnt, it aactually heats up just decimals, and ive tried everything. Ive applied a sharing topolgy type of mesh, where everything should be conected and not non-conformal.
As you can see, the copper is pretty hot, almost 400 kelvin, but the water stays cold, the inlet water velocity is 0.02m/s, and the tube diameter is like 5 cm.
This is the outlet water temperature. Can someone help me solve this issue??
August 12, 2024 at 10:56 am
Forum ModeratorWhich radiation model are you using? The solar load model will add heat into the domain, but only to the walls.Â
August 12, 2024 at 6:59 pm
Bastian Bruck
Subscriberim using the rosseland model. Ive seen people doing simulations on a solar air heater, and heats up the walls and fluid it self, i dont know why mine hasnt work yet. i dont know what should i change in my model.
August 13, 2024 at 8:59 am
Forum ModeratorHave you set the fluid absorbtion coefficients? Check the tutorials in Fluent's Help and also the various courses in Learning on here.Â
August 23, 2024 at 7:25 am
Bastian Bruck
Subscriberi havent found a solar collector like im making it. i need to heat up this fluid, how would you do it?, also i havent found any example like this in the ansys fluent guide or help tutorials, need help.
August 23, 2024 at 8:43 am
Forum ModeratorYou won't. What you may well find are tutorials that cover aspects of your work - you then use the useful bits to guide your work.Â
5849
.png)
.png)
