Solar Thermal CFD model – Parabolic Trough Concentrator
    • Jon Reed
      I am having trouble setting up a simple solar thermal model.
      I have a Parabolic Trough Collector, a hollow cylindrical copper receiver, and water as a heat transfer fluid inside that receiver, the simulation is for my university project.
      I cannot seem to attain any significant temperature rise regardless of my set up parameters so I am obviously doing something wrong - can someone please help me with the set up?
      Thanks in advance!
    • SRP
      Can you please share screenshot of  geometry, mesh and the boundary condition that you have applied? It will help to better understand your problem and help to resolve issue faster.
      Thank you.
    • Atia Hannoura
      Hi
      i have the same problem
      Assuming you've already checked previous threads on the topic please post some screenshots as per SRP's comment.
    • Atia Hannoura
    • Atia Hannoura
      mesh
    • Atia Hannoura
      boundary conditions
      Where is the mesh between the tube and reflector?
    • Atia Hannoura
      how can i do this ?  there is no material between the tube and reflector
      There must be something? Fluent uses a finite volume approach. If there aren't any cells there is nothing to calculate the flow/heat transfer on.
    • Atia Hannoura
      there is air between them should i simulate air in this region ?
      Yes if you want to have any energy pass through that zone.
Viewing 11 reply threads
  • The topic ‘Solar Thermal CFD model – Parabolic Trough Concentrator’ is closed to new replies.
