LS Dyna
LS Dyna
software crashing and sph
    • Kamyab Karimi
      hi, when I am trying to define sph to sph coupling, LS-DYNA force exits (crashes).
      may someone help me with this problem?
      also, what type of contact should I select for cold spray (droplet and substrate are both sph)?
    • Ram Gopisetti
      Hi , try using the latest version of solver, R14, see the field CONT in *CONTROL_SPH
      cheers, Ram
      • Kamyab Karimi
        I have student version of ls-dyna, and its up to date.
        prepost ls-dyna force exits before evening simulation.
        when I insert define_sph-sph-coupling card and click apply, the prepost program force exits.
        without defining sph-sph coupling I get negative volume for particle error.
  • The topic ‘software crashing and sph’ is closed to new replies.
