June 28, 2020 at 1:36 pm
AndreasLyng11
SubscriberHello All
I have meshed a 3D model of a butt weld via. submerged arc welding. The mesh were generated by sweeping the square volumes with quadrilateral elements and using triangular elements in the weld. I want to refine/smoothen the transition between quadrilateral elements and triangular elements. The mesh are seen below together with the areas where refinement is needed (marked with red)Â
June 29, 2020 at 5:02 am
Keyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.Â
you will need to increase size of tet elements or reduce size of hex elements.Â
please see help manual on definining sizing.
also check following for sizing.Â
https://www.youtube.com/watch?v=w4q6q8nKF3U
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
July 6, 2020 at 3:21 pm
AndreasLyng11
SubscriberThank you very much!Â
- The topic ‘Smoothing transition from quadrilateral elements to triangular elements’ is closed to new replies.
4618
1530
1386
1210
