SMART crack growth – critical crack length
    • nw196
      Hi,I'm running a fatigue cycle on a hollow cylinder of shell thickness 40mm, with a Semi Elliptical Crack on the surface. nMy SMART crack model runs up to a crack extension of 24mm after a cycle of ~77000 cycles, at which point the model stops. nHas it stopped at 24mm as the software believes this is the critical crack length? or because it's met some other parameter? nI have not set a predetermined crack length or time for the model to stop.Any help appreciated.n
    • Ashish Khemka
      nFor the SMART crack model do you have the Auto Time Stepping set to Program Controlled?nSMART crack growth will only calculate the first result in that case because the solver will default to one substep. For calculating more increments you need to specify more substeps. For instance, set Auto Time Stepping to 'Off' and then specify the number of substeps.nRegards,nAshish Khemkann
  • The topic ‘SMART crack growth – critical crack length’ is closed to new replies.
