Photonics
Photonics
Small signal ac analysis using charge solver
    • richajangra66
      The script file that you have given for ssac analysis foe vertical photodetector shows an error. i want to plot the normalized response vs. frequency plot for my problem. In ansys manual also there is no information regarding this. Can you please help me with the error the script shows.
    • Amrita Pati
      Hi Richa,
      I was able to run the files without any issue. It could be related to your hardware specs. Would you be able to share a screenshot of the log file? It should be in the same directory, and should be named something like: "vpd_CHARGE_ssac_p0.log".
      Amrita
    • richajangra66
      Here it is. I am still not able to run it.
  • The topic ‘Small signal ac analysis using charge solver’ is closed to new replies.
