March 18, 2020 at 12:37 pm
Phil J
SubscriberWhen the students download the 2020 R1 student version, the workbench text is very small. Almost unreadable. What can we change to make the text font normal size?
March 18, 2020 at 2:03 pm
Sai Deogekar
Ansys EmployeeHello,
There is a similar post which might help:Â /forum/forums/topic/installation-issues/?order=all#comment-f4eba110-a9b1-4cfc-ba10-a7fc0125c694
Hope this helps,
Sai
March 18, 2020 at 4:10 pm
Phil J
SubscriberSai,
Thank you so very much. I will pass this along to the students.
Sincerely,
Phil
February 14, 2023 at 2:38 pm
FMKinstruction
SubscriberThe student version R2023 v1 uses an extremely small font. I fixed most (but not all) of this following the recommendation I found here: https://www.cfd-online.com/
Forums/ansys/184634-work- bench-gui-very-small-font.html This fixed everything except for "mechanical", i.e. I start up a static structural analysis, import some simple geometry, and then select "model" command to apply loads and create a mesh. Unfortunately the modeler package goes back to the "tiny font" mode. The panel at left is normal size, but the menus at the top are unreadable and step on each other.
Interestingly, both Discovery and SpaceClaim use normal fonts while DesignModeler uses the tiny font and is unusable.
I'm running Windows 11 on my Lenovo laptop, Intel i7 processor.
- The topic ‘Small font in Workbench in Student Version’ is closed to new replies.
5834
