Electronics
Electronics
SMA Connector design HFSS not working – how can I fix that?
    • imtiaz
      Hi, I designed an SMA model following a video, but overall, it is not working at all. See the S11, fully reflecting. I've attached the hfss file here, anyone please help to figure out the issue??
      Here is the HFSS design file: https://drive.google.com/file/d/1-EzQaEdfGbC4eAbAFTsphZBXEx6QhyiW/view?usp=sharing
    • Anchal Singh
      Hello Imtiaz,
      Please note that with the installation of AEDT, various SMA connectors are provided as the 3D component file. You can access them from Component Libraries and use them in your model.
      Hope this will help you.
      Regards
      Anchal
      • imtiaz
        I do not find any 3d component in my installation location. Can you please specify the location where I can find those things?
    • Anchal Singh
      Hello Imtiaz,
      Please check the Surface Mount Device folder in the Component Library.
      Regards
      Anchal
  • The topic ‘SMA Connector design HFSS not working – how can I fix that?’ is closed to new replies.
