June 8, 2025 at 3:16 am
Dato
SubscriberHi all,
I have used SC for a long time but recently I found something wrong with SC navigation.Â
When I use mouse wheel to zoom in and out, the model visualization panel acting like frame by frame. And I found the zoom in/out behavior is recorded in history by CTRL + Z as shown below.
It's quite puzzled. Any suggestions would be highly appreciated!!
Best regards
June 9, 2025 at 6:05 am
Devendra Badgujar
Forum Moderator-
June 10, 2025 at 3:52 am
Dato
SubscriberHi professor,
It doesn't work. I have rebuilded the geometry manually in another file since it's a large assembly with thousands of bodies. It worked but it's quite time-consuming.Â
It's confusing. Is it caused by large load?Â
Thanks for your kind reply.
June 10, 2025 at 3:56 am
Dato
SubscriberOh, The problem occurs again for new manually created models and I haven't changed setting in SC. It seems like a bug. Crazy.
June 10, 2025 at 4:05 am
Dato
SubscriberÂ
I found that the problem occurred when I turn on the visibility of a component. It’s rather strange.Â
Are there any possible solution? The problem make orientation react slowly when zooming using mouse wheel.
Thanks!
3190
1025
962
859
798
