TAGGED: ansys-mechanical, fluent, fluid-flow, fluids, mechanical
May 18, 2022 at 1:21 am
MechEngStud
Subscriberwhy is it the Power Coefficient (Cp) of slotted airfoil wind turbine blade has a higher value at low tsr compare to a normal wind turbine blade? But as the tsr increases the Cp of slotted airfoil blade decreases so much compare to a normal wind turbine blade?
May 18, 2022 at 12:31 pmRob
Forum ModeratorWhat does the literature say on the matter? Have you modelled both?
May 19, 2022 at 1:19 amMechEngStud
Subscriberyes i modelled both. the slotted airfoil wind turbine has a higher Cp at low tsr compare to the baseline blade. but as the tsr increases the Cp of the slotted airfoil wind turbine blade has a lower Cp compare to the baseline blade.
May 19, 2022 at 8:59 amRob
Forum ModeratorOK, assuming you've taken area etc into account for the coefficient what does literature say about the benefits (or otherwise) of slotted blades?
May 20, 2022 at 4:57 amMechEngStud
SubscriberIt delays the separations of fluid at the tail end of the airfoil becoz the slot re energize the streanlime delaying the drag. in low tsr, the slot is effective but in high tsr the slot is a disadvantage as it decreases the value of Cp. my question is why is this phenomenom happening? care to explain?
May 20, 2022 at 10:20 amRob
Forum ModeratorIt'll be linked to boundary layer separation and turbulence. That's one for the Courses, or a text book.
Viewing 5 reply threads- The topic ‘SLotted airfoil wind turbine blade’ is closed to new replies.
3727
1328
1163
1090
1014
