Slotted Airfoil Wind turbine blade
    • MechEngStud
      why is it the Power Coefficient (Cp) of slotted airfoil wind turbine blade has a higher value at low tsr compare to a normal wind turbine blade? But as the tsr increases the Cp of slotted airfoil blade decreases so much compare to a normal wind turbine blade?
    • Keyur Kanade
  • The topic ‘Slotted Airfoil Wind turbine blade’ is closed to new replies.
