TAGGED: ansys-fluent, fluid-dynamics, fluid-flow, fluids, mechanical
May 18, 2022 at 1:18 am
MechEngStud
SubscriberWhy is it the Power Coefficient (Cp) of slotted airfoil wind turbine blade has a higher value at low tsr compare to a normal wind turbine blade? But as the tsr increases the Cp of slotted airfoil blade decreases so much compare to a normal wind turbine blade?
May 18, 2022 at 5:19 amKeyur Kanade
Ansys EmployeeViewing 1 reply thread- The topic ‘Slotted airfoil Wind Turbine blade’ is closed to new replies.
