Slitting sliding interface zone X into a coupled wall with shadow zone Y; and Creating empty surface
May 10, 2020 at 6:13 am
PRABUPETER
SubscriberDear all,
I work in a 3d vof problem with solid cylinders. When i upload in Fluent i get these ..(shown below).
Why this occur?I have used shared topology in design modeler.
Can any one help.
Thanks
Prabu..
Note: Slitting sliding interface zone 10 into a coupled wall with shadow zone 62.
creating wall-10-shadow
Note: Slitting sliding interface zone 45 into a coupled wall with shadow zone 63.
creating wall-45-shadow
Note: Slitting sliding interface zone 48 into a coupled wall with shadow zone 64.
creating wall-48-shadow
Note: Slitting sliding interface zone 55 into a coupled wall with shadow zone 65.
creating wall-55-shadow
Note: Slitting sliding interface zone 53 into a coupled wall with shadow zone 66.
creating wall-53-shadow
Note: Slitting sliding interface zone 52 into a coupled wall with shadow zone 67.
creating wall-52-shadow
Sliding interface contact_region-contact_region_7-contact_region_2-contact_region_7-contact_region_8-contact_region_3-contact_region_8 already defined, skipped.
Sliding interface contact_region_6 already defined, skipped.
Sliding interface contact_region_5 already defined, skipped.
Sliding interface contact_region_4 already defined, skipped.
.....Â
parallel,
Done.
Preparing mesh for display...
Note: zone-surface: cannot create surface from sliding interface zone.
Creating empty surface.
Done.
May 12, 2020 at 1:38 am
Karthik Remella
AdministratorHello,
If you are using Sliding Mesh type of analysis, please do not use Share Topology between bodies which are sliding about an interface. Instead, ensure that your have created contact regions (in Meshing). Please see if this helps.
Thanks.Â
Best,
karthik
May 12, 2020 at 4:02 am
PRABUPETER
SubscriberThanks for the response Karthik, My problem is a open channel flow past a vertical cylinder and my mesh does not slide.Â
I don't know why such info comes. May be i will try with contact regions. Thanks.
- The topic ‘Slitting sliding interface zone X into a coupled wall with shadow zone Y; and Creating empty surface’ is closed to new replies.
3737
1328
1163
1090
1014
