May 1, 2024 at 10:18 am
Adrián Oya
SubscriberHi!
I'm trying to generate a slice in a .stl geometry in DesignModeler but it doesn't allow me.
Do you know how can I do that?
May 1, 2024 at 11:03 am
peteroznewman
SubscriberOpen the .stl file in SpaceClaim. On the Design Tab, select three vertices (or one facet) and click the Plane tool. You can also move the Plane around using the Move tool On the Facets tab,use the Split tool.
- The topic ‘Slice geometry in .stl file’ is closed to new replies.
