Skewness exceeded 0.98 at 13748 cells !
    • Sida
      Using Mechanical, as we can see the skewness is highly acceptable; below 0.6.
      However, when I ran calculation in fluent it fails, and after checking case, it says skewness exceeds 0.98
    • DrAmine
      Different algorithms and numerical methods. So expect that the metrics are different. Moreover it comes after doing some Deforming mesh dye to motion.
  • The topic ‘Skewness exceeded 0.98 at 13748 cells !’ is closed to new replies.
