3D Design
3D Design
Sketching dimension in Desigh Modeller – Extrude
    • fx213
      Theme: Length of Extrude in ANSYS DesignModeler Sketching
      I would like to ask you a question on how we can give dimension to the Extrude we select after Sketching in order to convert our 2D sketch model into 3D dimensional model in DesignModeler.
      I have attached two images with the sketch (2nd) and the extruded model (1rst). I do not want the width of the model in the YZ (PLANE) direction to be that large. How can I edit/ change this, giving the Extrude the dimension I want? Do I do that from Sketching as well?
      Thank you in advance.
      Kind regards,
      FX
      Extrude
      Sketch
      Extrude should add an extra panel under the tree, it looks like you're missing something. Clicking on the "Details View" button bottom left may bring it back. If not, on the top menus Tools -> Windows -> Reset layout   to (hopefully) fix the interface.
    • Keyur Kanade
      yes, as rob suggsted, please reset layout and then check following tutorial which explains controls under extrude.
      https://www.youtube.com/watch?v=_N7WXFON_Nc
    • fx213
      Dear Rwoolhou and Kkanade,
      Thank you both for your replies.
      I figured it out eventually. I determined the dimensions from the Sketching dropdown menus. Thanks for your help.
      Kind regards,
      FX
    • Keyur Kanade
      good.
      can you mark this post as 'is solution' to help others on forum.
    • fx213
      Yes, of course. Thank you a lot for your help.
      FX
Viewing 5 reply threads
  • The topic ‘Sketching dimension in Desigh Modeller – Extrude’ is closed to new replies.
