July 8, 2024 at 6:08 pm
22721064
Subscriberdear professor,I would like to ask whether the Size of a pixel in topology optimization can be modified. When I set the Size of a pixel along x-axis (in nm) to 30, it can normally run with the guess area I set, but when I change it to 30nm or more, it will give an error. Do you have any solution?thank you for your answer
The error is as follows:
July 9, 2024 at 5:35 pm
Guilin Sun
Ansys EmployeePlease refer to https://innovationspace.ansys.com/forum/forums/topic/tapuyouhuasize-of-a-pixelwenti/
- The topic ‘Size of a pixel along x-axis or y-axis(in nm) in inverse design using topology’ is closed to new replies.
