March 13, 2024 at 2:48 am
Gregory Harrington
SubscriberI imported my geometry to use in the watertight workflow.
I added a proximity local sizing scoped to edges on a particular part surface.
No matter what surface I pick, I always receive the warning "Note that size controls based on edges cannot be used in a Size Control File"
I am not sure what a size control file is or how I can fix this seeing as how I havent done anything other than import geometry and try to add a proximity refinement.
March 13, 2024 at 8:23 pm
Federico
Ansys EmployeeHello Gregory,
you can ignore this warning as it should not have any impact on your mesh. The warning is exactly what it says: edge sizing controls cannot be used in a Size Control File, which is not your case.
March 13, 2024 at 8:26 pm
Federico
Ansys EmployeeA Size Control File in Fluent Meshing is a set of instructions that guide the meshing algorithm on how to apply specific mesh sizes to certain parts of the geometry or localized regions.
March 13, 2024 at 8:41 pm
Gregory Harrington
SubscriberOk thanks for the clarification! I assumed it was going to cause my edge scoping to not work as intended.Â
- The topic ‘Size controls based on edges cannot be used in a Size Control File?’ is closed to new replies.
5654
1890
1414
1303
