TAGGED: Ansys-Siwave, ansys-thermal, current-density, siwave
July 16, 2024 at 2:56 pm
Andrew
SubscriberHi,
I am running current density analysis on PCB board using a DC current source. Can we do similar kind of analysis using a frequency dependent current source or voltage source in SIwave? If yes then kindly elaborate a little bit.
Regards
July 19, 2024 at 9:02 am
Mrinmoy Bharadwaj
Ansys EmployeeHello Andrew,
Yes you can carry out a current density analysis using a frequency dependent source voltage source in SIwave. One way of doing it is to use the "push excitation" option during SIwave+Circuit co-simulation of your pcb. Please try it out.Â-
July 22, 2024 at 1:52 pm
July 23, 2024 at 9:39 am
Mrinmoy Bharadwaj
Ansys EmployeeThanks for Sharing the image your set-up. As I mentioned, AC/Frequency-dependent sources can be assigned in SIwave and current density can be viewed. Either you define your current-time data as an input to the frequency dependent source OR use the push-excitation workflow for doing the same wherein you will define your excitations in the Ansys Circuit designer and push excitations back to SIwave.Â
Additionally, such analysis can also be done in HFSS Classic and HFSS 3D Layout where you can view current densities in the planes.-
July 23, 2024 at 9:42 am
Andrew
SubscriberOk Thanks. let me try these and get back to you later.
- The topic ‘SIwave Current Density Analysis’ is closed to new replies.
5884
1306
