September 26, 2023 at 7:27 pm
Joseph Spada
SubscriberFollowing this case...
/forum/forums/topic/siwave-home-circuit-element-properties-tabs-information-required/
I have Lock Top View Selected from the View tab, however the "Circuit Element Parameters" button is still grayed out. Â
The goal is to remove any extraneous components when exporting to HFSS/Electronics Desktop. If components are included model boundary is extended beyond what is desired, see attached pic.
September 27, 2023 at 3:18 pm
Nathan B
Ansys Employee"Circuit Element Parameters" will work regardless of angle of view. It doesn't need to be in top-down view for "Circuit Element Parameters" to be accessable. The reason why "Circuit Element Parameters" is not avaialable is because there are no Capacitors, Inductors, Resistors, Ports, Voltage Probes, Current Sources, Voltage Sources, or Net Terminals.Â
Your screenshot shows a large component outline which indicates there is a padstack, which is part of the component, that is in the upper right-hand corner. You can edit the component in both SIwave or HFSS 3D Layout -
October 6, 2023 at 6:45 pm
Joseph Spada
SubscriberThank you. This solved my problem.Â
- The topic ‘SiWave Circuit Elements’ is closed to new replies.
