Ansys Products
Ansys Products
Sintering of materials with transient thermal distribution
    • Osama Jadaan
      How do we incorporate transient heat transfer (transient thermal distribution) in the sintering of materials. Sintering is a capability available in the additive manufacturing add-on in ANSYS Mechanical.
      Thank you.
    • Ashish Khemka
      Please do a web search for a paper titled:
      Computational modeling of heat transfer and sintering behavior during direct metal laser sintering of AlSi10Mg alloy powder
      Also, please see if the following link is of use to you: Tutorial workbench with sintering process; (ansys.com)
      Ashish Khemka
    • Osama Jadaan
      Thank you Ashish, I appreciate your reply.
      I read the paper you suggested. I also read all documentation in ANSYS regarding the sintering models and add-on module, did the tutorials and started my own model.
      The paper you asked me to read only deals with transient heat transfer modeling, which I have no issue with and know how to do. My question was regarding using the transient thermal results as input into the sintering analysis (add-on). how do we go about doing this in ansys. Currently, it seems like ansys assumes constant temperature profile throughout the component at a given time. But what I need is to use a transient temperature profile that varies with time and position with the sintering analysis.
      Thank you.
      Osama Jadaan
    • Ashish Khemka
      Hi Osama,
      Please wait for other members to comment.
      Ashish Khemka
    • JP-Ansys
      Hello Osama,
      You can import the transient thermal results through an external data system, i.e. as an imported load. For further information please read the following section: Importing Loads (ansys.com).
      János
    • Osama Jadaan
      Thank you, Janos. I will try your suggestion.
      Osama Jadaan
Viewing 5 reply threads
  • The topic ‘Sintering of materials with transient thermal distribution’ is closed to new replies.
