October 15, 2023 at 8:30 amHamid RSubscriber
Hi everyone,
I simulated a BLDC motor in Ansys Electronics 2022 R2 using an external circuit. However, I encountered an issue where the simulation results do not start from t=0, but instead, they start from t=-0.01 ms. The rotor's initial position is zero. Can anyone help me identify the problem causing this offset in time?
October 16, 2023 at 6:41 amTimosAnsys Employee
the offset in sumulation time (t=-0.01ms) is a known postprocessing defect in Ansys Maxwell 2022R2. I recommend upgrading to newer versions where the issue has been resolved.
- The topic ‘Simulation Start Time Offset in Ansys Electronics 2022 R2’ is closed to new replies.
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Question for Maxwell
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- How to customize pulse waveform and injection site in microstrip array
- 180 Degree Phase Shift When Measuring S21
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
513
488
225
209
