January 22, 2024 at 1:01 pm
Andreas Wathne
SubscriberHi, I am trying to simulate a model of a PM synchronous motor considering the mechanical transient. It should start from rpm=0 and reach the sync. rpm=1000, but no matter how I set up the simulation, it only seem to oscillate from approx. -200 to 200 rpm. I have also tried with a ramp function to gradually increase the applied voltage, and also several combinations of the connection of the phases. Are there someone that has experience with the starting of a PMSM in Ansys Maxwell or have any idea of what I can do to make it work? I do not get it to work if I say that initial speed is 1000rpm either, it just imediately drops to approx. 200 rpm and oscillates...
January 24, 2024 at 10:04 pm
HDLI
Ansys EmployeeHello Andreas,
To simulate the starting process, we need to make synchrous frequency in excitation for speed.
Please open a bldc example in RMxprt and build Maxwell model, then enable "consider mechanical transient" in Motion. After that, you can perform this simulation.
Please review circuit to find how to make synchrous frequency for different speed in excitation.
HDLI
- The topic ‘Simulation setup PMSM Mechanical transient’ is closed to new replies.
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
4597
1495
1386
1209
