November 16, 2020 at 8:46 am
H_E
SubscriberHi,
I'm a beginner in Ansys and I would like to simulate the melting of a filament in the nozzle similar to the diagram attached. What models and boundary conditions should I use?
Thanks.
November 16, 2020 at 10:24 amDrAmine
Ansys EmployeeIs the filament already molten as it escapes the nozzle?nNovember 16, 2020 at 12:48 pmH_E
Subscriberyes.nNovember 16, 2020 at 1:18 pmDrAmine
Ansys EmployeeAnd you want to simulate the domain outside the nozzle? Will the melt solidify?nNovember 16, 2020 at 1:29 pmNovember 16, 2020 at 1:37 pmDrAmine
Ansys EmployeeOkay so only nozzle melt flow all liquid, right? nNovember 16, 2020 at 2:02 pmH_E
SubscriberThe inlet is solid and it melts and flow out of the nozzle.nNovember 16, 2020 at 2:19 pmDrAmine
Ansys EmployeeSo you might use solidification and Melting Model with a sort of pulling effect solid at the inlet section.nNovember 16, 2020 at 2:31 pmH_E
SubscriberHow can I do that ? I tried to use velocity inlet and specifying the velocity magnitude and pressure outlet but the results seem to be incorrect. I also tried to specify the initial gauge pressure at the velocity inlet but it doesn't seem to have any effect on the pressure distribution.nNovember 16, 2020 at 3:07 pmDrAmine
Ansys EmployeeYou might ignore at first ignore the mushy zone and not freeze the solid motion. Can you add more info?nNovember 16, 2020 at 3:35 pmH_E
SubscriberBelow are the boundary conditions I set for this simulation:nVelocity inlet: velocity magnitude 0.001 m/s normal to boundary, temperature 300KnPressure Outlet: gauge pressure 0 PanWall: stationary wall, no-slip condition, temperature 543Kn
I get this pressure distribution but I expect a pressure change to occur at the nozzle tip (the section where there is a dimensional change).nI then tried to specify the initial gauge pressure of 1.64e6 Pa at the velocity inlet boundary condition window but I still get the same result.
Viewing 10 reply threads- The topic ‘Simulation of melting of filament in FDM’ is closed to new replies.
5649
1885
1403
1303
