Simulation of Gyroid
    • reda mejbar
      I would like to Simulate This gyroid structure (hyperelastic material, static structural, compression). However, I am not sure how I can define the self contact (when cells intersect each other)? would it be better in this case to use dynamic loading? I attached the project file. Thank you.
      All the best,
      Ansys project
      The link does not let anyone download the file.
    • reda mejbar
      I apolgize for that. I modified it now. Thanks
      You have uploaded a *.wbpj file. This file is useless without the *_files folder of the same name.  In Workbench, open the *.wbpj file and use File, Archive to create a *.wbpz file which contains the *_files folder in the file.  Users can then download the *.wbpz file and use Workbench to open the archive.
      Without seeing your model, I can advise you that in Explicit Dynamics, self contact is automatically created with no user input required.
  • The topic ‘Simulation of Gyroid’ is closed to new replies.
