LS Dyna
LS Dyna
Simulation of elastic and plastic behaviour of ABS and obtaining energy ebsorption
    • salmarzooqi
      I am attempting to model the compression of a simple cube made of ABS material and obtain the stress strain curve and compare the simulation with the experimental data.
      I have made compression samples and obtained the true stress and strain and used an isotropic multilinear hardening model for plasticity.
      should I use static, quasistatic, explicit to simulate this. I tried static and in the results couldnt see the elastic region of all curves.
    • salmarzooqi
      Here also is the material model
    • salmarzooqi
    • Ram Gopisetti
      what is your compression rate say 0.001/s or 1/s. this rate will describe what simulation conditions to used,Most of the compression test are qusic static.
      cheers, Ram
  • The topic ‘Simulation of elastic and plastic behaviour of ABS and obtaining energy ebsorption’ is closed to new replies.
