June 23, 2023 at 12:08 pm
Urvi Mehta
SubscriberI am Urvi Mehta, a student pursuing Aerospace Engineering. I wanted to know the geometry dimensions of the cone from the course “Shock Expansion Theory” under the “Simulation example : Wedge vs Cone", please.
June 23, 2023 at 1:22 pm
Forum ModeratorIf you download the files you can use the tools in Fluent to find out.
June 23, 2023 at 1:51 pm
Urvi Mehta
SubscriberThat is right. But, there is only a .msh file which is the meshing file that cannot be viewed in the meshing section. It is directly imported to the setup part. I can't get the dimensions.
June 23, 2023 at 2:03 pm
Forum ModeratorI suggest you have a look at the post processing options in Fluent.
June 23, 2023 at 8:53 pm
June 26, 2023 at 9:31 am
Forum ModeratorYes, have a look in Views>Camera (or Views) you should see a symmetry option. That'll mirror the image based on the axis/symmetry you tell it.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_sec_graphics_view.html 37.6.3
June 26, 2023 at 2:28 pm
Urvi Mehta
SubscriberGot it. Thank you so much for your help!
- The topic ‘Simulation of Cone’ is closed to new replies.
5814
