May 29, 2024 at 7:51 am
Hitendra Singh
SubscriberSo i want to study the temperature, velocity and pressure of the flow coming out of cd nozzle after the combustion process inside the chamber. 2 different inlets are provided, one for liquid methane (LNG) and another for liquid oxygen (LOx) and i want them to get mixed and ignite inside the chamber. I am not understanding why the flow is going downwards and velocity of flow is maximum at throat and decreasing further. Any suggestion would be appreciated.
Mesh:
Target skewness: 0.9 (Default)
Number of nodes: 176174
Number of elements: 175014
Setup:
1. Solver:
Pressure based, steady and absolute
2. Model:
k-epsilon standard with standard wall function and curvature correction
3. Species:
Non premixed combustion with Inlet diffusion, chemical equilibrium and non-adiabatic enabled at standard atmospheric operating pressure.
3.1. Boundary:
CH4 = 1 and O2 = 1 with fuel temperature 90K and oxidizer temperature 60K.
3.2. Calculated Pdf table.
3.3. Radiation is enabled as Discrete ordinatesÂ
4. Boundary Condition:
Fuel inlet (mass flow inlet)
Mass flow inlet = 0.017 kg/s
Initial Gauge pressure = 2465000 Pa
Turbulent intensity = 10%
Mean Mixture Fraction = 1
Mixture Fraction Variance = 0
Oxygen inlet (mass flow inlet)
Mass flow inlet = 0.026 kg/s
Mean Mixture Fraction = 0
 Outlet (pressure outlet)
Gauge pressure = 96500 Pa
Initialization method: Hybrid
June 5, 2024 at 1:04 pm
vinaraya
Ansys EmployeeHi Hitendra,
Is the combustion complete? has all the reactants converted to products ?
Could you share the contours of mass fraction of O2, CH4 and product species like CO2 and H20.
- The topic ‘Simulation of combustion of LNG and LOx in CD nozzle’ is closed to new replies.
5664
1890
1419
1304
