Ansys Products
Ansys Products
Simulation License Error SiWave 2022 R2
    • eleblanc-royer
      When I first installed SiWave I accidentally entered the incorrect license server informatino so SiWave would not even start correctly. I fixed this by running "C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ClientSettings\ClientSettings.exe" and changing the license server host name and port to be correct. This allows SiWave to startup and run, however whenever I try to perform any simulations I get errors about accessing the simulation license server. When I look at the error log it appears that "ansyscl" is using the old, incorrect, license information. Is there somewhere else that I need to change the license server information? Thank you
    • George Karnos
      Check the following file for the correct license server name:
      C:\Program Files\AnsysEM\Shared Files\licensing\ansyslmd.ini
      If it is not, change it to the correct name and save file.
      If it is correct, please check the %TEMP%\.ansys directory for the siwave licdebug file.
      iF there is an error contained in that file, please post it.
    • eleblanc-royer
      I have pasted a snippet of what the erorr looks like from within SiWave at the bottom of this reply. I have blocked out my computer and host name. Additionally, I have pasted the log it is pointing to below. I have redacted my user name and host computer name. The one thing that seems out of place to me is where it states "2022/10/03 10:37:27    INFO                ANSYSLI_PRODORD_FILE=COULD NOT BE FOUND!". Is that potentially my issue?
      *Start of Log file*
      -------------------------------------------- NORMAL STARTUP 2022/10/03 10:37:27 ---------------------------------------------
      Ansys Licensing Interconnect version 2022.2.0 (20220502) for winx64.  Updated at Ansys Release 2022 R2.  Started on 2022/10/03 10:37:27 by @:winx64 with pid 17560.
      (C) 2022 ANSYS, Inc.  Unauthorized use, distribution, or duplication is prohibited.
      Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6
      Built Using OpenSSL 1.1.1n  15 Mar 2022
      Please note that entries in this debug log have the following format:
      TIMESTAMP              ACTION              FEATURE                    REVISION (BUILD DATE)             A/B/C/D                 W/X/Y/Z   PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY                                    SOCKET:IP
      Licenses statistics:
      A is the number of licenses requested by this ACTION.
      B is the number of licenses used by this USER.
      C is the number of licenses used by all users.
      D is the number of licenses available in the local license pool.
      License server performance statistics:
      W is the number of currently connected client applications.
      X is the maximum number of connected client applications.
      Y is the unique serial number of this client application.
      Z is the number of all client applications served by this Licensing Interconnect server.
      2022/10/03 10:37:27    INFO                ANSYSLI_CMD=C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..15192.32727.log
      2022/10/03 10:37:27    INFO                ANSYSLI_INITIALIZATION_FILE='C:\Program Files\AnsysEM\Shared Files\Licensing\ansyslmd.ini'
      2022/10/03 10:37:27    INFO                ANSYSLI_TIMEOUT_FLEXLM=15
      2022/10/03 10:37:27    INFO                Configuring ACL Core
      2022/10/03 10:37:27    INFO                ACL Core Initialized
      2022/10/03 10:37:27    INFO                ANSYSCL_PORT=51980
      2022/10/03 10:37:27    INFO                Listen Socket Created
      2022/10/03 10:37:27    INFO                ANSYSLI_CLIENT_IDLE_TIMEOUT=0
      2022/10/03 10:37:27    INFO                ANSYSCL_FNP_PATH=1055@linflex4
      2022/10/03 10:37:27    INFO                Ready to accept connections.
      2022/10/03 10:37:27    INFO                ANSYSLI_IP_OVERRIDE option is off.
      2022/10/03 10:37:28    CLIENT_ACCEPT        1/1/1/1        7408:127.0.0.1
      2022/10/03 10:37:28    CLIENT_CONNECT        1/1/1/1   15192:15192:SIWAVE.EXE:@:winx64             7408:127.0.0.1
      2022/10/03 10:37:28    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   15192:15192:SIWAVE.EXE:@:winx64             7408:127.0.0.1
      2022/10/03 10:37:28    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   15192:15192:SIWAVE.EXE:@:winx64             7408:127.0.0.1
      End of Log file
      SiWave Error
    • George Karnos
      can you paste the contents of the licdebug..SIWAVE.EXE.221.out file located under %TEMP%\.ansys
      • eleblanc-royer
        Yes I have two files:
        First one "licdebug.XXXX.SIWAVE.EXE.222.out"
        2022/09/27 12:44:11    INFO                Starting Licensing Client Proxy server.
        2022/09/27 12:44:11    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 9376.25533 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..9376.25533.log
        2022/09/27 12:44:12    INFO                Started ANSYSLI server.
        2022/09/27 12:44:13    CLIENT_CONNECT        1/1/1/1   9376:SIWAVE.EXE:@ :winx64    7388:10.14.0.93
        2022/09/27 12:44:13    NEW_CONNECTION      Connected to Licensing Client Proxy server: 61485@127.0.0.1.
        2022/09/27 12:44:13    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   9376:SIWAVE.EXE:@ :winx64    7388:10.14.0.93
        2022/09/27 12:44:13    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   9376:SIWAVE.EXE:@ :winx64    7388:10.14.0.93
        2022/09/27 15:13:16    CLIENT_EXIT        0/1/1/1   9376:SIWAVE.EXE:@ :winx64    7388:10.14.0.93
        2022/09/28 11:50:56    INFO                Starting Licensing Client Proxy server.
        2022/09/28 11:50:56    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 18040.33621 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..18040.33621.log
        2022/09/28 11:50:56    INFO                Started ANSYSLI server.
        2022/09/28 11:50:57    CLIENT_CONNECT        1/1/1/1   18040:SIWAVE.EXE:@ :winx64   7392:10.14.10.38
        2022/09/28 11:50:57    NEW_CONNECTION      Connected to Licensing Client Proxy server: 57352@127.0.0.1.
        2022/09/28 11:50:57    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   18040:SIWAVE.EXE:@ :winx64   7392:10.14.10.38
        2022/09/28 11:50:57    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   18040:SIWAVE.EXE:@ :winx64   7392:10.14.10.38
        2022/09/28 16:06:14    CLIENT_EXIT        0/1/1/1   18040:SIWAVE.EXE:@ :winx64   7392:10.14.10.38
        2022/09/29 10:43:40    INFO                Starting Licensing Client Proxy server.
        2022/09/29 10:43:40    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 16124.53166 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..16124.53166.log
        2022/09/29 10:43:40    INFO                Started ANSYSLI server.
        2022/09/29 10:43:41    CLIENT_CONNECT        1/1/1/1   16124:SIWAVE.EXE:@ :winx64   7500:10.14.4.130
        2022/09/29 10:43:41    NEW_CONNECTION      Connected to Licensing Client Proxy server: 49763@127.0.0.1.
        2022/09/29 10:43:42    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   16124:SIWAVE.EXE:@ :winx64   7500:10.14.4.130
        2022/09/29 10:43:42    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   16124:SIWAVE.EXE:@ :winx64   7500:10.14.4.130
        2022/09/29 12:35:23    CLIENT_EXIT        0/1/1/1   16124:SIWAVE.EXE:@ :winx64   7500:10.14.4.130
        2022/09/29 14:43:26    INFO                Starting Licensing Client Proxy server.
        2022/09/29 14:43:26    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 504.51432 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..504.51432.log
        2022/09/29 14:43:26    INFO                Started ANSYSLI server.
        2022/09/29 14:43:26    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 4828.51432 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..4828.51432.log
        2022/09/29 14:43:27    CLIENT_CONNECT        1/1/1/1   504:SIWAVE.EXE:@ :winx64     7428:10.14.4.130
        2022/09/29 14:43:27    NEW_CONNECTION      Connected to Licensing Client Proxy server: 52549@127.0.0.1.
        2022/09/29 14:43:27    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   504:SIWAVE.EXE:@ :winx64     7428:10.14.4.130
        2022/09/29 14:43:27    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   504:SIWAVE.EXE:@ :winx64     7428:10.14.4.130
        2022/09/29 14:43:27    CLIENT_CONNECT        1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:43:27    NEW_CONNECTION      Connected to Licensing Client Proxy server: 52554@127.0.0.1.
        2022/09/29 14:43:28    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:43:28    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:45:30    CLIENT_EXIT        0/1/1/1   504:SIWAVE.EXE:@ :winx64     7428:10.14.4.130
        2022/09/29 14:52:07    CHECKOUT            elec_solve_siwave               22.2 (2022.0502)             1/1/1/4                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:07    CHECKOUT            FEAT_ELEC_SOLVE_SIWAVE          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:08    CHECKOUT            elec_solve_level3               22.2 (2022.0502)             1/1/1/4                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:08    CHECKOUT            elec_solve_level2               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:08    CHECKOUT            elec_solve_level1               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:08    CHECKOUT            FEAT_ELEC_SOLVE_LEVEL1          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:08    CHECKOUT            FEAT_ELEC_SOLVE_LEVEL2          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:08    CHECKOUT            FEAT_ELEC_SOLVE_LEVEL3          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             FEAT_ELEC_SOLVE_SIWAVE          22.2 (2022.0502)             1/0/0/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             elec_solve_siwave               22.2 (2022.0502)             1/0/0/4                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             FEAT_ELEC_SOLVE_LEVEL1          22.2 (2022.0502)             1/0/0/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             elec_solve_level1               22.2 (2022.0502)            1/0/0/10                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             FEAT_ELEC_SOLVE_LEVEL2          22.2 (2022.0502)             1/0/0/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             elec_solve_level2               22.2 (2022.0502)            1/0/0/10                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             FEAT_ELEC_SOLVE_LEVEL3          22.2 (2022.0502)             1/0/0/1                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 14:52:19    CHECKIN             elec_solve_level3               22.2 (2022.0502)             1/0/0/4                 1/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 15:59:38    CLIENT_EXIT        0/1/1/1   4828:SIWAVE.EXE:@ :winx64    7404:10.14.4.130
        2022/09/29 16:00:28    INFO                Starting Licensing Client Proxy server.
        2022/09/29 16:00:28    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2256.51560.log
        2022/09/29 16:00:30    INFO                Started ANSYSLI server.
        2022/09/29 16:00:31    CLIENT_CONNECT        1/1/1/1   2256:SIWAVE.EXE:@ :winx64    7376:10.14.4.130
        2022/09/29 16:00:31    NEW_CONNECTION      Connected to Licensing Client Proxy server: 58240@127.0.0.1.
        2022/09/29 16:00:32    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   2256:SIWAVE.EXE:@ :winx64    7376:10.14.4.130
        2022/09/29 16:00:32    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   2256:SIWAVE.EXE:@ :winx64    7376:10.14.4.130
        2022/09/29 17:13:24    CLIENT_EXIT        0/1/1/1   2256:SIWAVE.EXE:@ :winx64    7376:10.14.4.130
        2022/09/30 11:40:29    INFO                Starting Licensing Client Proxy server.
        2022/09/30 11:40:29    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15852.33597 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..15852.33597.log
        2022/09/30 11:40:29    INFO                Started ANSYSLI server.
        2022/09/30 11:40:30    CLIENT_CONNECT        1/1/1/1   15852:SIWAVE.EXE:@ :winx64   6904:10.14.5.83
        2022/09/30 11:40:30    NEW_CONNECTION      Connected to Licensing Client Proxy server: 65032@127.0.0.1.
        2022/09/30 11:40:30    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   15852:SIWAVE.EXE:@ :winx64   6904:10.14.5.83
        2022/09/30 11:40:30    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   15852:SIWAVE.EXE:@ :winx64   6904:10.14.5.83
        2022/09/30 11:40:44    CLIENT_EXIT        0/1/1/1   15852:SIWAVE.EXE:@ :winx64   6904:10.14.5.83
        2022/09/30 11:40:56    INFO                Starting Licensing Client Proxy server.
        2022/09/30 11:40:56    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 8020.71441 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..8020.71441.log
        2022/09/30 11:40:58    INFO                Started ANSYSLI server.
        2022/09/30 11:40:59    CLIENT_CONNECT        1/1/1/1   8020:SIWAVE.EXE:@ :winx64    7416:10.14.5.83
        2022/09/30 11:40:59    NEW_CONNECTION      Connected to Licensing Client Proxy server: 65187@127.0.0.1.
        2022/09/30 11:40:59    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   8020:SIWAVE.EXE:@ :winx64    7416:10.14.5.83
        2022/09/30 11:40:59    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   8020:SIWAVE.EXE:@ :winx64    7416:10.14.5.83
        2022/09/30 11:41:22    CLIENT_EXIT        0/1/1/1   8020:SIWAVE.EXE:@ :winx64    7416:10.14.5.83
        2022/09/30 11:41:36    INFO                Starting Licensing Client Proxy server.
        2022/09/30 11:41:36    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 11776.15068 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..11776.15068.log
        2022/09/30 11:41:38    INFO                Started ANSYSLI server.
        2022/09/30 11:41:39    CLIENT_CONNECT        1/1/1/1   11776:SIWAVE.EXE:@ :winx64   7384:10.14.5.83
        2022/09/30 11:41:39    NEW_CONNECTION      Connected to Licensing Client Proxy server: 65398@127.0.0.1.
        2022/09/30 11:41:39    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   11776:SIWAVE.EXE:@ :winx64   7384:10.14.5.83
        2022/09/30 11:41:39    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   11776:SIWAVE.EXE:@ :winx64   7384:10.14.5.83
        2022/09/30 12:00:53    CLIENT_EXIT        0/1/1/1   11776:SIWAVE.EXE:@ :winx64   7384:10.14.5.83
        2022/09/30 14:38:15    INFO                Starting Licensing Client Proxy server.
        2022/09/30 14:38:15    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 6136.59436 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..6136.59436.log
        2022/09/30 14:38:15    INFO                Started ANSYSLI server.
        2022/09/30 14:38:16    CLIENT_CONNECT        1/1/1/1   6136:SIWAVE.EXE:@ :winx64    7388:10.14.5.83
        2022/09/30 14:38:16    NEW_CONNECTION      Connected to Licensing Client Proxy server: 62344@127.0.0.1.
        2022/09/30 14:38:17    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   6136:SIWAVE.EXE:@ :winx64    7388:10.14.5.83
        2022/09/30 14:38:17    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   6136:SIWAVE.EXE:@ :winx64    7388:10.14.5.83
        2022/09/30 15:26:56    CLIENT_EXIT        0/1/1/1   6136:SIWAVE.EXE:@ :winx64    7388:10.14.5.83
        2022/09/30 15:27:13    INFO                Starting Licensing Client Proxy server.
        2022/09/30 15:27:13    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 18396.35041 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..18396.35041.log
        2022/09/30 15:27:15    INFO                Started ANSYSLI server.
        2022/09/30 15:27:16    CLIENT_CONNECT        1/1/1/1   18396:SIWAVE.EXE:@ :winx64   6900:10.14.5.83
        2022/09/30 15:27:16    NEW_CONNECTION      Connected to Licensing Client Proxy server: 59921@127.0.0.1.
        2022/09/30 15:27:17    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   18396:SIWAVE.EXE:@ :winx64   6900:10.14.5.83
        2022/09/30 15:27:17    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   18396:SIWAVE.EXE:@ :winx64   6900:10.14.5.83
        2022/09/30 15:27:52    CLIENT_EXIT        0/1/1/1   18396:SIWAVE.EXE:@ :winx64   6900:10.14.5.83
        2022/09/30 15:28:16    INFO                Starting Licensing Client Proxy server.
        2022/09/30 15:28:16    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2216.26760 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2216.26760.log
        2022/09/30 15:28:18    INFO                Started ANSYSLI server.
        2022/09/30 15:28:19    CLIENT_CONNECT        1/1/1/1   2216:SIWAVE.EXE:@ :winx64    7392:10.14.5.83
        2022/09/30 15:28:19    NEW_CONNECTION      Connected to Licensing Client Proxy server: 60245@127.0.0.1.
        2022/09/30 15:28:19    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   2216:SIWAVE.EXE:@ :winx64    7392:10.14.5.83
        2022/09/30 15:28:19    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   2216:SIWAVE.EXE:@ :winx64    7392:10.14.5.83
        2022/09/30 15:33:49    INFO                Starting Licensing Client Proxy server.
        2022/09/30 15:33:49    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 12212.96922 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..12212.96922.log
        2022/09/30 15:33:51    INFO                Started ANSYSLI server.
        2022/09/30 15:33:52    CLIENT_CONNECT        1/1/1/1   12212:SIWAVE.EXE:@ :winx64   7424:10.14.5.83
        2022/09/30 15:33:52    NEW_CONNECTION      Connected to Licensing Client Proxy server: 61821@127.0.0.1.
        2022/09/30 15:33:53    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   12212:SIWAVE.EXE:@ :winx64   7424:10.14.5.83
        2022/09/30 15:33:53    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   12212:SIWAVE.EXE:@ :winx64   7424:10.14.5.83
        2022/09/30 15:34:13    CLIENT_EXIT        0/1/1/1   12212:SIWAVE.EXE:@ :winx64   7424:10.14.5.83
        2022/09/30 17:07:14    CLIENT_EXIT        0/1/1/1   2216:SIWAVE.EXE:@ :winx64    7392:10.14.5.83
        2022/10/03 10:35:26    INFO                Starting Licensing Client Proxy server.
        2022/10/03 10:35:26    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 18044.23005 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..18044.23005.log
        2022/10/03 10:35:26    INFO                Started ANSYSLI server.
        2022/10/03 10:35:27    CLIENT_CONNECT        1/1/1/1   18044:SIWAVE.EXE:@ :winx64   6904:10.14.4.119
        2022/10/03 10:35:27    NEW_CONNECTION      Connected to Licensing Client Proxy server: 51354@127.0.0.1.
        2022/10/03 10:35:27    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   18044:SIWAVE.EXE:@ :winx64   6904:10.14.4.119
        2022/10/03 10:35:27    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   18044:SIWAVE.EXE:@ :winx64   6904:10.14.4.119
        2022/10/03 10:36:58    CLIENT_EXIT        0/1/1/1   18044:SIWAVE.EXE:@ :winx64   6904:10.14.4.119
        2022/10/03 10:37:25    INFO                Starting Licensing Client Proxy server.
        2022/10/03 10:37:25    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..15192.32727.log
        2022/10/03 10:37:27    INFO                Started ANSYSLI server.
        2022/10/03 10:37:28    CLIENT_CONNECT        1/1/1/1   15192:SIWAVE.EXE:@ :winx64   7408:10.14.4.119
        2022/10/03 10:37:28    NEW_CONNECTION      Connected to Licensing Client Proxy server: 51980@127.0.0.1.
        2022/10/03 10:37:28    CHECKOUT            electronics3d_gui               22.2 (2022.0502)            1/1/1/10                 1/1/1/1   15192:SIWAVE.EXE:@ :winx64   7408:10.14.4.119
        2022/10/03 10:37:28    CHECKOUT            FEAT_ELECTRONICS3D_GUI          22.2 (2022.0502)             1/1/1/1                 1/1/1/1   15192:SIWAVE.EXE:@ :winx64   7408:10.14.4.119
        Second one "licdebug.XXXX.SIWAVE_NG.EXE.222.out"
        2022/09/29 16:12:35    ERROR               Unable to connect to ansyscl on port 58240 as ansyscl is not currently running.
        2022/09/29 16:12:35    INFO                Starting Licensing Client Proxy server.
        2022/09/29 16:12:35    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -aclport 58240 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2256.51560.log
        2022/09/29 16:12:37    INFO                Started ANSYSLI server.
        2022/09/29 16:12:52    CONNECT_ERROR       16313        0/0/0/0   8904:SIWAVE_NG.EXE:@:winx64   0:10.14.4.130
                ANSYSLI exited or could not read server port ansyscl..2256.51560.
                Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2256.51560.log for more information.
        2022/09/29 16:12:52    INFO                Starting Licensing Client Proxy server.
        2022/09/29 16:12:52    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2256.51560.log
        2022/09/29 16:12:54    INFO                Started ANSYSLI server.
        2022/09/29 16:13:09    CONNECT_ERROR       16309        0/0/0/0   8904:SIWAVE_NG.EXE:@:winx64   0:10.14.4.130
        2022/09/29 16:36:40    INFO                Starting Licensing Client Proxy server.
        2022/09/29 16:36:40    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2256.51560.log
        2022/09/29 16:36:42    INFO                Started ANSYSLI server.
        2022/09/29 16:36:57    CONNECT_ERROR       16313        0/0/0/0   2744:SIWAVE_NG.EXE:@:winx64   0:10.14.4.130
        2022/09/29 16:36:57    INFO                Starting Licensing Client Proxy server.
        2022/09/29 16:36:57    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2256.51560 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2256.51560.log
        2022/09/29 16:36:59    INFO                Started ANSYSLI server.
        2022/09/29 16:37:14    CONNECT_ERROR       16309        0/0/0/0   2744:SIWAVE_NG.EXE:@:winx64   0:10.14.4.130
        2022/09/30 11:42:45    ERROR               Unable to connect to ansyscl on port 65398 as ansyscl is not currently running.
        2022/09/30 11:42:45    INFO                Starting Licensing Client Proxy server.
        2022/09/30 11:42:45    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 11776.15068 -nodaemon -aclport 65398 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..11776.15068.log
        2022/09/30 11:42:47    INFO                Started ANSYSLI server.
        2022/09/30 11:43:02    CONNECT_ERROR       16313        0/0/0/0   14576:SIWAVE_NG.EXE:@:winx64   0:10.14.5.83
                ANSYSLI exited or could not read server port ansyscl..11776.15068.
                Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl..11776.15068.log for more information.
        2022/09/30 11:43:02    INFO                Starting Licensing Client Proxy server.
        2022/09/30 11:43:02    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 11776.15068 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..11776.15068.log
        2022/09/30 11:43:04    INFO                Started ANSYSLI server.
        2022/09/30 11:43:19    CONNECT_ERROR       16309        0/0/0/0   14576:SIWAVE_NG.EXE:@:winx64   0:10.14.5.83
        2022/09/30 15:43:53    ERROR               Unable to connect to ansyscl on port 60245 as ansyscl is not currently running.
        2022/09/30 15:43:53    INFO                Starting Licensing Client Proxy server.
        2022/09/30 15:43:53    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2216.26760 -nodaemon -aclport 60245 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2216.26760.log
        2022/09/30 15:43:55    INFO                Started ANSYSLI server.
        2022/09/30 15:44:10    CONNECT_ERROR       16313        0/0/0/0   15284:SIWAVE_NG.EXE:@:winx64   0:10.14.5.83
                ANSYSLI exited or could not read server port ansyscl..2216.26760.
                Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2216.26760.log for more information.
        2022/09/30 15:44:10    INFO                Starting Licensing Client Proxy server.
        2022/09/30 15:44:10    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 2216.26760 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..2216.26760.log
        2022/09/30 15:44:12    INFO                Started ANSYSLI server.
        2022/09/30 15:44:27    CONNECT_ERROR       16308        0/0/0/0   15284:SIWAVE_NG.EXE:@:winx64   0:10.14.5.83
        2022/10/03 10:38:03    ERROR               Unable to connect to ansyscl on port 51980 as ansyscl is not currently running.
        2022/10/03 10:38:03    INFO                Starting Licensing Client Proxy server.
        2022/10/03 10:38:03    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -aclport 51980 -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..15192.32727.log
        2022/10/03 10:38:05    INFO                Started ANSYSLI server.
        2022/10/03 10:38:20    CONNECT_ERROR       16313        0/0/0/0   7228:SIWAVE_NG.EXE:@:winx64   0:10.14.4.119
                ANSYSLI exited or could not read server port ansyscl..15192.32727.
                Please refer C:\Users\\AppData\Local\Temp\.ansys\ansyscl..15192.32727.log for more information.
        2022/10/03 10:38:20    INFO                Starting Licensing Client Proxy server.
        2022/10/03 10:38:20    INFO                C:\Program Files\AnsysEM\v222\Win64\licensingclient\winx64\ansyscl.exe -acl 15192.32727 -nodaemon -log C:\Users\\AppData\Local\Temp\.ansys\ansyscl..15192.32727.log
        2022/10/03 10:38:22    INFO                Started ANSYSLI server.
        2022/10/03 10:38:37    CONNECT_ERROR       16308        0/0/0/0   7228:SIWAVE_NG.EXE:@:winx64   0:10.14.4.119
    • George Karnos
      Try setting the following System Environment Variable:
      Variable:   ANSYSCL_BIND_TO_LOOPBACK
      Variable Value: 1
      • eleblanc-royer
        Sadly that did not change anything. Still fail with the same exact error response. Do I need to completely re-install everything?
Viewing 4 reply threads
  • The topic ‘Simulation License Error SiWave 2022 R2’ is closed to new replies.
