Kampus Merdeka Belajar
Ask questions related to general and focused sessions.
Simulation Example – Streamlining in High-Speed Rail Transport
    • Rizqi A'mal Hibatullah Tabrani
      I am facing a problem when I simulate "" the color of the train is different from the example, does it matter?
      Thank you.
    • dzikrian.d
      Hello, Regarding whether the effect of the train color matter or not, it depends on what kind of results that you take from the simulation. If you don’t have to investigate any phenomenon that occurs on the object surface (i.e. Pressure distribution, wall shear stress, etc.), the different in the colors of the trains does not matter.
      Thank you
    • Raihan Lutfianto
      Hi Rizqi, that is why you need to understand the simulation objective first. Here, simulation is not about comparing your result with the tutorial, but it is about how you can solve the physics of the problem and interpret it correctly.
      Thanks for all the explanations sir
  • The topic ‘Simulation Example – Streamlining in High-Speed Rail Transport’ is closed to new replies.
