March 30, 2023 at 2:00 pm
Alberto
SubscriberI'm trying to solve a dynamic mesh problem, but when i'm about t=0.09s fluent close itself and display no error messages.
How can i understand the problem? otherwise it is no longer possible to continue computation
March 31, 2023 at 9:50 am
Forum ModeratorAnything in the transcript (.trn) file? Did you hit any time limits on the cluster, or use solution steering?
March 31, 2023 at 9:55 am
Alberto
SubscriberHow can i find this file? I don't know if it is a question of time limits because fluent closes automatically without dispaly anything
March 31, 2023 at 10:27 am
Forum ModeratorIt should be in the working folder. Fluent rarely "disappears" without some error somewhere, but if the cluster run duration limits are reached it will: we see that here when running tests on the short duration queue.
March 31, 2023 at 10:31 am
Alberto
SubscriberMaybe this is the error, it look likes memory error message..any suggestion on how to handle and continue simulation?
Error [cortex] [time 3/31/23 12:8:36] Cortex received a fatal signal (SEGMENTATION VIOLATION). -
March 31, 2023 at 10:55 am
Forum ModeratorOK. Segmentation error tends to suggest the solver had a problem, and with moving mesh that could be diveregence or the remeshing did something odd. What else does the last section of the .trn say? Specifically the last couple of time step residual blocks.
March 31, 2023 at 11:00 am
Alberto
SubscriberThis is an error on a different simulation, which is still running, so does not compromise it. I don't find any file in my working folder so i can't tell you more. It is possibile that this is due to the fact that i'm trying to simulate the falling of a seed in a 3D domain, and when it start to rotates it create some problem?
March 31, 2023 at 12:54 pm
Forum ModeratorThat sounds like the remeshing had a problem, check you're not moving too quickly as the seed begins to tumble. Ie you may need a smaller time step.
March 31, 2023 at 1:01 pm
Alberto
Subscriberok, but i’m using 1e-05 as timestep which is too small, i have a mesh with 110k elements (unstructured tetrahedral) with refinement around the seed body. As remeshing method i’m using the unified which works good when i perform a 1DOF simulation allowing the seed to translate uniquely along vertical direction. For what concern the smoothing i’ve choose diffusion with 2 as diffusion factor.
March 31, 2023 at 1:02 pm
Forum ModeratorTime step is a function of speed and cell size. If the seed tumbles can the rotational speed mean the time step becomes too big?
March 31, 2023 at 1:05 pm
Alberto
SubscriberI'll try to set 5e-06 as dt. How about diffusion and unified remeshing? they're the good choice for this type of problem?
March 31, 2023 at 1:31 pm
Forum ModeratorPass, I don't tend to use moving mesh. Check the example videos in Help. The two tutorials are for overset, which is an alternative method.
March 31, 2023 at 2:13 pm
Alberto
SubscriberCan you link or provide some materials about overset mesh ? what i found is not complete and i can’t understand the method.
Many thanks for the help given up to now
March 31, 2023 at 2:24 pm
Forum ModeratorOnly what's on the Help system, I can't share anything from the Learning Hub.
April 17, 2023 at 3:59 pm
Alberto
SubscriberI've found these two files:
cortex error which says: " Error [cortex] [time 4/17/23 17:36:40] Cortex received a fatal signal (SEGMENTATION VIOLATION). "
fluent-999999-error which states: " Error [node 999999] [time 4/17/23 17:36:36] Abnormal Exit! "
In addittion I can't continue the computation it seems like it is finisched but it was only at 12% and it took 2 days.
April 18, 2023 at 10:20 am
Forum ModeratorHow does your set up compare with the examples? The above isn't overly diagnostic. Is there not a transcript file (.trn) which has something? Ideally post the few lines above the error & the error as it's the trigger that's most likely to help.
April 18, 2023 at 12:31 pm
Alberto
SubscriberI dont find this .trn file inside any folder. The above messages are all error files fluent returns to me.
April 18, 2023 at 1:11 pm
Forum ModeratorAnd you're running stand alone? Ie no Workbench? I can't diagnose anything from what we have so far.
April 18, 2023 at 6:39 pm
Alberto
SubscriberI've found this .trn file inside ansys file which i link here: https://drive.google.com/file/d/1pIVsTqoAOqPVjHmTXwL1q0f5pDjn9y4a/view?usp=share_link
many thanks in advance
April 19, 2023 at 9:14 am
Forum ModeratorI'm not permitted to open that: it's one of the rules to allow staff to answer questions on here. Please post the last few iteration lines and first some error messages.
April 19, 2023 at 9:17 am
Alberto
SubscriberUpdating solution at time levels N and N-1.
6DOF angular solver has not converged
6DOF angular solver has not converged done.Updating mesh at time level N... done.
iter continuity x-velocity y-velocity z-velocity k omega intermit retheta time/iter
100799 8.6132e-04 5.0025e-06 5.4756e-06 5.9177e-06 1.2778e-06 4.6477e-06 2.9313e-08 4.3843e-08 0:00:11 12
100800 3.4947e-03 5.8489e-05 5.9952e-05 6.6332e-05 3.0098e-05 9.6385e-05 2.6096e-07 8.8221e-07 0:00:13 11
100801 1.8936e-03 1.7863e-05 1.8692e-05 2.0957e-05 6.0513e-06 1.9697e-05 8.0019e-08 1.9280e-07 0:00:11 10
100802 9.5855e-04 5.5207e-06 5.8881e-06 6.6502e-06 1.2177e-06 5.1505e-06 3.5600e-08 4.4790e-08 0:00:08 9
!100802 solution is converged
step flow-time flow-time cl cd
32950 2.6360e-01 2.6360e-01 -1.3622e-02 1.5761e-02
Flow time = 0.2636000000000984s, time step = 32950
267050 more time stepsUpdating solution at time levels N and N-1.
100802 9.5855e-04 5.5207e-06 5.8881e-06 6.6502e-06 1.2177e-06 5.1505e-06 3.5600e-08 4.4790e-08 0:00:11 12
100803 3.9090e-03 6.8440e-05 7.9123e-05 8.3832e-05 3.0006e-05 9.5593e-05 2.7165e-07 8.8165e-07 0:00:10 11
100804 2.0903e-03 2.0539e-05 2.3673e-05 2.4854e-05 6.0327e-06 1.9680e-05 8.0529e-08 1.9295e-07 0:00:09 10
100805 1.0492e-03 5.9002e-06 6.7989e-06 7.0504e-06 1.2142e-06 4.8732e-06 3.4632e-08 4.5152e-08 0:00:09 9
Done.
Registering ReportDefFiles, ("C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\.\\cd-rfile.out" "C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\.\\cl-rfile.out")
Writing "| gzip -2cf > SolutionMonitor.gz"...
Writing temporary file C:\\Users\\Alberto\\AppData\\Local\\Temp\\flntgz-53842 ...
Done.
Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\FFF-2-4-32951.cas.h5" in NODE0 mode and compression level 1 ...
402421 cells, 1 zone ...
812558 faces, 3 zones ...
71584 nodes, 1 zone ...
Done.Writing boundary layer flags ...
Done.
Done.Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\sim_ansys\simulazione_\coarse_mesh_falling_seed_files\dp0\FFF-2\Fluent\FFF-2-4-32951.dat.h5" in NODE0 mode and compression level 1 ...
Writing results.
Done.Performance Timer for 9874 iterations on 30 compute nodes
Average wall-clock time per iteration: 1.395 sec
Global reductions per iteration: 585 ops
Global reductions time per iteration: 0.000 sec (0.0%)
Message count per iteration: 250192 messages
Data transfer per iteration: 210.863 MB
LE solves per iteration: 15 solves
LE wall-clock time per iteration: 0.258 sec (18.5%)
LE global solves per iteration: 11 solves
LE global wall-clock time per iteration: 0.003 sec (0.2%)
LE global matrix maximum size: 744
AMG cycles per iteration: 18.872 cycles
Relaxation sweeps per iteration: 1368 sweeps
Relaxation exchanges per iteration: 0 exchanges
LE early protections (stall) per iteration: 0.000 times
LE early protections (divergence) per iteration: 0.000 times
Total SVARS touched: 433
Time-step updates per iteration: 0.28 updates
Time-step wall-clock time per iteration: 0.850 sec (60.9%)Total wall-clock time: 13775.651 sec
April 19, 2023 at 10:46 am
Forum ModeratorThere's nothing there other than a solver complaint about the 6DOF convergence. Lift & drag coefficients are small, but the 6DOF model should use the forces: I assume they're sensible?
April 19, 2023 at 10:49 am
Alberto
Subscriberyes, it should use the forces from fluid to compute motion. what can i do about 6 dof angular convergence? I've insert the inertia tensor (which is symmetric non diagonal) due to non symmetry in my geometry. I've set the material in a wrong way maybe, becouse i've changed from aluminion to wood-maple, but aluminium still be there
April 19, 2023 at 11:03 am
Forum ModeratorI suspect your problem is linked to the motion, so check the forces just before the model fails. Also, how fast is the object rotating? Ie is it trying to flip? That could mean it's moving too quickly for the solver, which then diverges.
April 19, 2023 at 11:07 am
Alberto
Subscriberyes, it tumble and flip, it rotates at 160 rad/s. I'm able to capture the motion, i.e. i can visualize the solid body which falls while it translate and rotates but when it approach the walls simulation crash. I can solve this by enlarging the domain, it is not a problem of solver. But still to get this message: six dof angular solver do not converge. This can affect the computation accuracy ?
April 19, 2023 at 11:43 am
Forum ModeratorThe object gets close to or contacts a wall? That'll be a problem unless you've got the collision UDFs on. The moving mesh can't have walls making contact as it breaks the mesh topology.
Separately the 6DOF solver may be struggling with the rotation speed depending on the time step size relative to the cell size.
April 19, 2023 at 12:12 pm
Alberto
SubscriberThe object contacts a wall, i've enlarged the domain to avoid that, but angular solver still not converge. It is possible that it is due to a wrong initial setting of the orientation of the object ? cause the only things i know are: inertia tensor and center of gravity. Anything about initial configuration (orientation)
April 19, 2023 at 1:10 pm
Forum ModeratorInitial orientation will have some effect, but that should settle as it falls. Assuming the heavy end finishes up at the bottom and the "slower" bit is at the top.
April 24, 2023 at 9:12 am
Alberto
SubscriberHi, what this error means? I'm simulating a dynamic mesh with k-w model for turbolence, and my setup always crash at certain time giving the abnormal exit error without more info. I don't enconteur negative volume cells or divergence problem, I'm running with 15 cpu over a machine with 80 and i'm connected to internet with the lan. Any ideas ?
April 24, 2023 at 9:30 am
Forum ModeratorOK, to summarise.
You have:
- a cortex error, but no other information
- a transcript that shows a normal end to a run with files saving & parallel data. OK, so the solver isn't converging well but nothing looks wrong
- domain is big enough to avoid the falling object hitting anything
Is the extended domain is all one fluid region?
April 24, 2023 at 9:34 am
Alberto
Subscriberyes, when i'm creating the dynamic mesh zone, i make the body as rigid body and the fluid as deforming. In addition i've also create the interior-fluid as deforming, which is a zone automatically created by fluent. Simulation crash also if i solve with one dof only, for example only translation, so no hitting occurs
April 24, 2023 at 10:14 am
Forum ModeratorOK, so it's potentially the rotation. What remeshing have you got on the fluid?
April 24, 2023 at 10:28 am
Alberto
SubscriberNo, becouse it happens also when i'm translating only ( 1DOF). I'm using a unified remeshing method with diffusion coefifcient of 2 or more
April 24, 2023 at 10:41 am
Forum ModeratorOops, translation not rotation. OK, so what do the flow & mesh look like just before it fails?
April 24, 2023 at 12:08 pm
Alberto
SubscriberThis is the report, nothing seem strange also residuals are close to 0 before it fails.
Fluent
Version: 3d, dp, pbns, dynamesh, sstkw, transient (3d, double precision, pressure-based, dynamic mesh, SST k-omega, transient)
Release: 22.2.0
Title:Models
------Model Settings
Space 3D
Time Unsteady, 2nd-Order Implicit
Viscous SST k-omega turbulence model
Heat Transfer Disabled
Solidification and Melting Disabled
Species Disabled
Coupled Dispersed Phase Disabled
NOx Pollutants Disabled
SOx Pollutants Disabled
Soot Disabled
Mercury Pollutants Disabled
Structure Disabled
Acoustics Disabled
Eulerian Wall Film Disabled
Potential/Li-ion Battery Disabled
Multiphase Disabled
Material Properties
-------------------Material: wood-maple (solid)
Property Units Method Value(s)
Density kg/m^3 constant 532.17
Cp (Specific Heat) J/(kg K) constant 1684.8
Thermal Conductivity W/(m K) constant 0.25826Material: air (fluid)
Density kg/m^3 constant 1.225
Cp (Specific Heat) J/(kg K) constant 1006.43
Thermal Conductivity W/(m K) constant 0.0242
Viscosity kg/(m s) constant 1.7894e-05
Molecular Weight kg/kmol constant 28.966Material: aluminum (solid)
Density kg/m^3 constant 2719
Cp (Specific Heat) J/(kg K) constant 871
Thermal Conductivity W/(m K) constant 202.4
Cell Zone Conditions
--------------------Zones
name id type
fluid 4 fluidSetup Conditions
fluid
Condition Value
Frame Motion? no
Mesh Motion? no
Boundary Conditions
name id type
walls 5 wall
seed 6 wallSetup Conditions
walls
Condition Value
Wall Motion Stationary Wall
Shear Boundary Condition No Slip
Wall Surface Roughness 0seed
Condition Value
Solver Settings
---------------Equations
Equation Solved
Flow yes
Turbulence yesNumerics
Numeric Enabled
Absolute Velocity Formulation yesUnsteady Calculation Parameters
Number of Time Steps 4000
Time Step Size [s] 0.0008
Max Iterations/Time Step 20Under-Relaxation Factors
Variable Relaxation Factor
Density 1
Body Forces 1
Turbulent Kinetic Energy 0.8
Specific Dissipation Rate 0.8
Turbulent Viscosity 1
Explicit Momentum 0.75
Explicit Pressure 0.75Linear Solver
Variable Solver Type Termination Criterion Residual Reduction Tolerance
Flow F-Cycle 0.1
Turbulent Kinetic Energy Flexible 0.1 0.7
Specific Dissipation Rate Flexible 0.1 0.7Pressure-Velocity Coupling
Parameter Value
Type Coupled
Flow Courant Number 200Discretization Scheme
Variable Scheme
Pressure PRESTO!
Momentum QUICK
Turbulent Kinetic Energy QUICK
Specific Dissipation Rate QUICKSolution Limits
Quantity Limit
Minimum Absolute Pressure 1
Maximum Absolute Pressure 5e+10
Minimum Temperature 1
Maximum Temperature 5000
Minimum Turb. Kinetic Energy 1e-14
Minimum Spec. Dissipation Rate 1e-20
Maximum Turb. Viscosity Ratio 100000
April 24, 2023 at 12:34 pm
Forum ModeratorOther than the PBCS courant number being a little optimistic there's nothing obvious to cause problems. Pictures of what's going on in the model (ie mesh & contours) may help.
April 24, 2023 at 1:31 pm
Alberto
SubscriberBefore closing fluent automatically a window has appeared saying: “there’s no active application” and then all is closed instantly.
The mesh motion, contours of velocity and pressure are in agree with physics and nothing strange occurs. Convergence of scaled residual is also good and solution converges in 5 iteration.
here the last rows of .trn file
==================================================================================== BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 13 PID 16848 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 14 PID 24444 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)==================================================================================================Message from the Cortex Process================================Fatal error in one of the compute processes.==============================================================================Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).Error Object: ()Error: There is no active application.Error Object: (rp-var-value 'pdf/filename) -
April 24, 2023 at 1:38 pm
Forum ModeratorPictures of what's going on in the model (ie mesh & contours) may help.
April 24, 2023 at 1:54 pm
Alberto
SubscriberAlso some info on the mesh quality
Minimum Orthogonal Quality = 9.67777e-02 cell 720 on zone 4 (ID: 168922 on partition: 11) at location (-4.73982e-03, 9.61930e-03, -4.66381e-04)Maximum Aspect Ratio = 2.29950e+01 cell 2542 on zone 4 (ID: 168589 on partition: 13) at location (-5.72564e-03, 1.96574e-02, -9.18095e-04)
April 24, 2023 at 2:45 pm
Forum ModeratorNow check how the mesh is deforming at the ends. How well resolved is the red "dot" at the left hand end?
April 24, 2023 at 2:56 pm
Alberto
SubscriberSorry I dont understand your question but the mesh does not deform, the picture is related to the latest timestep, i was able to run this simulation two week ago, with same setup, now they crash. Maybe it is related to a parallel setup ? or grapic card settings?
April 24, 2023 at 3:54 pm
Forum ModeratorWhat has gpu got to do with moving mesh? If the mesh does not deform how are you using 1DOF and dynamic mesh?
April 24, 2023 at 4:19 pm
Alberto
SubscriberI was explain myself badly, mesh deforms, but near the solid boundaries anything strange like too deformed tetrahedral . I was able to run this simulation two weeks ago, so i dont think it is a mesh problem or model issue.
In the .trn file also, this error occurs at each processor (i've run with 15 cores):
Updating solution at time levels N and N-1.done.Updating mesh at time level N... done.iter continuity x-velocity y-velocity z-velocity k omega time/iter760 9.9713e-04 1.5911e-05 1.3513e-05 1.8015e-05 2.0660e-06 1.0548e-04 0:00:45 20761 6.8108e-03 9.3173e-05 7.0772e-05 1.3309e-04 5.3867e-04 3.5784e-03 0:00:45 19762 3.6281e-03 4.8553e-05 4.0775e-05 5.7765e-05 1.2741e-04 1.6395e-03 0:00:42 18763 2.0489e-03 3.0135e-05 2.5671e-05 3.6498e-05 3.0753e-05 5.1376e-04 0:00:38 17764 1.3749e-03 2.2572e-05 1.9371e-05 2.6834e-05 7.6857e-06 2.0990e-04 0:00:38 16765 1.0560e-03 1.8779e-05 1.6088e-05 2.1766e-05 2.0604e-06 1.0932e-04 0:00:35 15766 8.5239e-04 1.6339e-05 1.3986e-05 1.8640e-05 6.4454e-07 7.1077e-05 0:00:32 14! 766 solution is convergedstep flow-time flow-time drag186 1.4880e-01 1.4880e-01 5.6377e-04Flow time = 0.1487999999999995s, time step = 1863814 more time stepsUpdating solution at time levels N and N-1.done.Updating mesh at time level N...set_part_dest_tree: cell not found on myid = 7==================================================================================== BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 0 PID 23216 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 1 PID 9040 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 2 PID 26648 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 3 PID 22940 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 4 PID 28556 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 5 PID 19352 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 6 PID 20752 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 7 PID 2416 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 8 PID 26880 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1073740940 (c0000374)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 9 PID 6276 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 10 PID 27744 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 11 PID 16984 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 12 PID 1988 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 13 PID 16848 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)======================================================================================================================================================================= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES= RANK 14 PID 24444 RUNNING AT DESKTOP-C8FD4F6= EXIT STATUS: -1 (ffffffff)==================================================================================================Message from the Cortex Process================================Fatal error in one of the compute processes.==============================================================================Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).Error Object: ()Error: There is no active application.Error Object: (rp-var-value 'pdf/filename) -
April 25, 2023 at 10:13 am
Forum ModeratorTry with fewer cores. Otherwise, if it worked previously and not know I'm not sure. Also, try with PISO rather than PBCS: in transient there's little benefit to the pressure based coupled solver, and PISO may be better behaved.
April 25, 2023 at 4:12 pm
Alberto
SubscriberAnd how about cores setting? maybe i have to change something, I think the error occurs during the parallelization, so the MPI crash. how can i reset to the default value of fluent without reinstall it ?
April 25, 2023 at 4:30 pm
Forum ModeratorIt's a model failure, not the install. Try with fewer parallel cpu set and see if it's any better. Did PISO help?
April 25, 2023 at 4:37 pm
Alberto
SubscriberWith PISO model diverge in 5 iterations, then i've switch back to coupled and now also this crash at iteration 1. It is so strange
April 26, 2023 at 10:53 am
Forum ModeratorGo back a few auto saves, then re-run with a smaller time step and look carefully at what's going on. Not just mesh, but also flow (including turbulence). I can only offer guidance.
April 26, 2023 at 1:19 pm
Alberto
SubscriberI've reinstall, now the problem of crash is solved (i think) but the model crash due to non negative volume. here my trn file transcript. Do you think i have to lower the timestep? i'm using diffusion method with coefficient = 3 (maximum)
Build Time: May 28 2021 13:53:52 EDT
Executable Path: C:/PROGRA~1/ANSYSI~1/v212/fluent/ntbin/win64/fluent.exe---------------------------------------------------------------------------------
ID Hostname Core O.S. PID Vendor
n4 DESKTOP-C8FD4F6 5/80 Windows-x64 14108 Intel(R) Xeon(R) Gold 6230
n3 DESKTOP-C8FD4F6 4/80 Windows-x64 23480 Intel(R) Xeon(R) Gold 6230
n2 DESKTOP-C8FD4F6 3/80 Windows-x64 15352 Intel(R) Xeon(R) Gold 6230
n1 DESKTOP-C8FD4F6 2/80 Windows-x64 14232 Intel(R) Xeon(R) Gold 6230
n0* DESKTOP-C8FD4F6 1/80 Windows-x64 17316 Intel(R) Xeon(R) Gold 6230
host DESKTOP-C8FD4F6 Windows-x64 3176 Intel(R) Xeon(R) Gold 6230MPI Option Selected: intel
Selected system interconnect: default
---------------------------------------------------------------------------------Cortex Process ID: 20468
License Server Path: 1055@192.168.64.92
(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Solution|Run Calculation"))
(cx-gui-do cx-activate-item "NavigationPane*List_Tree1")
(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list "Solution|Calculation Activities"))
(cx-gui-do cx-activate-item "Run Calculation*Table1*Table9(Solution Advancement)*Table1*PushButton1(Calculate)")Writing Settings file "C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF.set"...
writing rp variables ... Done.
writing domain variables ... Done.
writing fluid (type fluid) (mixture) ... Done.
writing interior-fluid (type interior) (mixture) ... Done.
writing walls (type wall) (mixture) ... Done.
writing seed (type wall) (mixture) ... Done.
writing dynamic zone fluid ... Done
writing dynamic zone seed ... Done
writing dynamic zone interior-fluid ... Done
writing zones map name-id ... Done.Fast-loading "C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\\addons\afd\lib\hdfio.bin"
Done.Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-1-00000.cas.h5" in NODE0 mode and compression level 1 ...
Writing mesh ...
139800 cells, 1 zone ...
298818 faces, 3 zones ...
33833 nodes, 1 zone ...
Done.
Done.Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-1-00000.dat.h5" in NODE0 mode and compression level 1 ...
Writing results.
Done.Writing to DESKTOP-C8FD4F6:"C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\FFF-Setup-Output.cas.h5" in NODE0 mode and compression level 1 ...
Writing mesh ...
Done.
Done.Updating solution at time levels N and N-1.
1 1.0000e+00 1.5394e-03 9.2497e-04 3.2958e-02 2.5839e-04 1.2843e+02 0:00:38 19
2 1.0000e+00 1.0300e-02 9.6514e-03 3.1551e-02 2.8132e-04 5.9805e-01 0:00:43 18
3 1.0000e+00 3.5683e-03 3.2347e-03 9.7273e-03 1.0939e-04 3.0929e-01 0:00:39 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 72 cells
4 7.1627e-01 3.6252e-03 3.2389e-03 1.2984e-02 3.8179e-05 1.1170e-01 0:00:36 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 766 cells
5 3.5641e-01 3.6778e-03 3.2471e-03 9.7443e-03 1.3667e-05 4.9692e-02 0:00:33 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1095 cells
6 2.3952e-01 3.3818e-03 2.9535e-03 6.2383e-03 5.4956e-06 2.9290e-02 0:00:30 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1228 cells
7 2.6042e-01 2.8038e-03 2.4592e-03 4.1362e-03 2.4816e-06 1.9059e-02 0:00:28 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1305 cells
8 2.7782e-01 2.0806e-03 1.8673e-03 2.6871e-03 1.2321e-06 1.3265e-02 0:00:23 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1358 cells
9 2.3487e-01 1.6792e-03 1.5371e-03 2.0153e-03 6.6088e-07 9.8420e-03 0:00:21 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1406 cells
10 1.6773e-01 1.3507e-03 1.2445e-03 1.5990e-03 3.7781e-07 8.0851e-03 0:00:19 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1435 cells
11 1.1101e-01 1.1002e-03 1.0142e-03 1.2781e-03 2.2999e-07 6.9081e-03 0:00:18 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1448 cells
12 7.4687e-02 9.3017e-04 8.4935e-04 1.0524e-03 1.4990e-07 6.0414e-03 0:00:14 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1461 cells
13 5.4305e-02 8.2594e-04 7.4357e-04 9.0613e-04 1.0449e-07 5.4012e-03 0:00:13 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1481 cells
14 4.2460e-02 7.4220e-04 6.6124e-04 7.9079e-04 7.7275e-08 4.9258e-03 0:00:11 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1496 cells
15 3.3651e-02 6.7879e-04 6.0255e-04 7.0941e-04 5.9726e-08 4.5727e-03 0:00:09 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1503 cells
16 2.6478e-02 6.3267e-04 5.6399e-04 6.5592e-04 4.7105e-08 4.3177e-03 0:00:07 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1509 cells
17 2.0915e-02 5.9846e-04 5.3622e-04 6.2032e-04 3.8459e-08 4.1307e-03 0:00:05 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1515 cells
18 1.6810e-02 5.7117e-04 5.1831e-04 5.9522e-04 3.2318e-08 3.9930e-03 0:00:04 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1520 cells
19 1.3883e-02 5.5106e-04 5.0453e-04 5.7616e-04 2.8135e-08 3.8931e-03 0:00:02 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1523 cells
20 1.1798e-02 5.3722e-04 4.9389e-04 5.6120e-04 2.5620e-08 3.8229e-03 0:00:00 0
Flow time = 0.0005s, time step = 1
3999 more time stepsUpdating solution at time levels N and N-1.
20 1.1798e-02 5.3722e-04 4.9389e-04 5.6120e-04 2.5620e-08 3.8229e-03 0:00:34 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1517 cells
21 1.0246e-02 2.4675e-03 2.4064e-03 2.4517e-03 3.0641e-04 6.9201e-02 0:00:33 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1476 cells
22 1.1668e-02 8.5329e-04 8.0786e-04 8.6931e-04 7.3897e-05 1.7517e-02 0:00:32 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1452 cells
23 1.1647e-02 4.4248e-04 4.0350e-04 4.6468e-04 1.7656e-05 7.2321e-03 0:00:28 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1432 cells
24 1.1356e-02 3.3545e-04 3.0039e-04 3.4723e-04 4.5229e-06 4.3549e-03 0:00:27 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1419 cells
25 1.1001e-02 2.7400e-04 2.4682e-04 2.7919e-04 1.3250e-06 3.3592e-03 0:00:26 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1411 cells
26 1.0697e-02 2.2959e-04 2.0822e-04 2.3409e-04 4.7826e-07 2.9453e-03 0:00:25 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1402 cells
27 1.0391e-02 2.1136e-04 1.9168e-04 2.1748e-04 2.2364e-07 2.7383e-03 0:00:21 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1392 cells
28 1.0115e-02 2.0443e-04 1.8578e-04 2.1282e-04 1.3213e-07 2.6105e-03 0:00:21 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1387 cells
29 9.8508e-03 2.0877e-04 1.9008e-04 2.1775e-04 9.2324e-08 2.5253e-03 0:00:20 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1386 cells
30 9.5898e-03 2.1921e-04 1.9963e-04 2.2893e-04 7.1814e-08 2.4652e-03 0:00:18 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1384 cells
31 9.3302e-03 2.3261e-04 2.1214e-04 2.4278e-04 6.0077e-08 2.4185e-03 0:00:15 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1382 cells
32 9.0723e-03 2.4728e-04 2.2536e-04 2.5800e-04 5.1961e-08 2.3790e-03 0:00:14 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1383 cells
33 8.8183e-03 2.6178e-04 2.3788e-04 2.7286e-04 4.5732e-08 2.3462e-03 0:00:12 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1381 cells
34 8.5698e-03 2.7559e-04 2.4970e-04 2.8671e-04 4.1418e-08 2.3193e-03 0:00:11 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1384 cells
35 8.3286e-03 2.8757e-04 2.5926e-04 2.9891e-04 3.7488e-08 2.2965e-03 0:00:08 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1383 cells
36 8.0953e-03 2.9772e-04 2.6721e-04 3.0956e-04 3.4309e-08 2.2774e-03 0:00:07 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1382 cells
37 7.8704e-03 3.0676e-04 2.7421e-04 3.1908e-04 3.1862e-08 2.2610e-03 0:00:05 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1383 cells
38 7.6542e-03 3.1458e-04 2.8018e-04 3.2695e-04 3.0002e-08 2.2464e-03 0:00:04 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1382 cells
39 7.4470e-03 3.2013e-04 2.8464e-04 3.3248e-04 2.7920e-08 2.2323e-03 0:00:02 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1380 cells
40 7.2483e-03 3.2435e-04 2.8820e-04 3.3670e-04 2.6104e-08 2.2210e-03 0:00:00 0
Flow time = 0.001s, time step = 2
3998 more time stepsUpdating solution at time levels N and N-1.
40 7.2483e-03 3.2435e-04 2.8820e-04 3.3670e-04 2.6104e-08 2.2210e-03 0:00:35 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1314 cells
41 7.1056e-03 1.9999e-03 1.9471e-03 4.8915e-03 3.9244e-04 5.6901e-02 0:00:34 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1271 cells
42 8.1135e-03 7.9265e-04 7.4149e-04 1.5379e-03 8.7552e-05 1.4163e-02 0:00:29 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1242 cells
43 8.1759e-03 4.8964e-04 4.3840e-04 6.9272e-04 1.9591e-05 4.6063e-03 0:00:29 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1220 cells
44 8.0154e-03 4.7084e-04 4.1917e-04 5.2960e-04 4.5858e-06 2.2498e-03 0:00:28 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1207 cells
45 7.7958e-03 4.4177e-04 3.9691e-04 4.6690e-04 1.1824e-06 1.5362e-03 0:00:27 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1202 cells
46 7.5872e-03 4.1486e-04 3.7717e-04 4.3392e-04 3.6599e-07 1.2662e-03 0:00:26 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1193 cells
47 7.3960e-03 3.9025e-04 3.5729e-04 4.0777e-04 1.5075e-07 1.1358e-03 0:00:24 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1185 cells
48 7.2183e-03 3.6726e-04 3.3723e-04 3.8361e-04 8.5942e-08 1.0539e-03 0:00:20 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1183 cells
49 7.0504e-03 3.4644e-04 3.1887e-04 3.6197e-04 5.9994e-08 9.9476e-04 0:00:19 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1181 cells
50 6.8946e-03 3.1343e-04 2.8906e-04 3.2724e-04 4.6995e-08 9.5108e-04 0:00:18 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1178 cells
51 6.7403e-03 3.1088e-04 2.8596e-04 3.2509e-04 4.0209e-08 9.1339e-04 0:00:17 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1177 cells
52 6.5901e-03 2.9671e-04 2.7265e-04 3.0999e-04 3.4978e-08 8.8165e-04 0:00:13 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1176 cells
53 6.4501e-03 2.7314e-04 2.5078e-04 2.8469e-04 3.0639e-08 8.5694e-04 0:00:12 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1171 cells
54 6.3073e-03 2.7338e-04 2.5030e-04 2.8491e-04 2.8316e-08 8.3346e-04 0:00:11 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1170 cells
55 6.1690e-03 2.6352e-04 2.4138e-04 2.7463e-04 2.5861e-08 8.1280e-04 0:00:09 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1168 cells
56 6.0404e-03 2.4421e-04 2.2441e-04 2.5439e-04 2.3476e-08 7.9696e-04 0:00:07 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1166 cells
57 5.9080e-03 2.4547e-04 2.2553e-04 2.5602e-04 2.2377e-08 7.8011e-04 0:00:05 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1166 cells
58 5.7859e-03 2.2803e-04 2.0995e-04 2.3777e-04 2.0681e-08 7.6527e-04 0:00:04 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1165 cells
59 5.6598e-03 2.3031e-04 2.1150e-04 2.4062e-04 1.8796e-08 7.5352e-04 0:00:02 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1164 cells
60 5.5439e-03 2.1449e-04 1.9745e-04 2.2385e-04 1.8305e-08 7.4134e-04 0:00:00 0
Flow time = 0.0015s, time step = 3
3997 more time stepsUpdating solution at time levels N and N-1.
60 5.5439e-03 2.1449e-04 1.9745e-04 2.2385e-04 1.8305e-08 7.4134e-04 0:00:34 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1048 cells
61 5.3752e-03 2.6850e-03 2.6305e-03 7.1013e-03 3.9329e-04 4.8751e-02 0:00:37 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 990 cells
62 5.2691e-03 1.1215e-03 1.0628e-03 2.3898e-03 8.6664e-05 1.2259e-02 0:00:32 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 952 cells
63 5.1838e-03 6.5477e-04 5.9652e-04 1.0076e-03 1.9279e-05 3.8895e-03 0:00:31 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 929 cells
64 4.9987e-03 5.9478e-04 5.3289e-04 6.8030e-04 4.5056e-06 1.8012e-03 0:00:30 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 915 cells
65 4.8348e-03 4.8170e-04 4.3435e-04 5.0686e-04 1.1664e-06 1.1912e-03 0:00:25 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 903 cells
66 4.7104e-03 4.2486e-04 3.8509e-04 4.4133e-04 3.6648e-07 9.6514e-04 0:00:24 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 896 cells
67 4.6054e-03 3.7560e-04 3.4219e-04 3.8937e-04 1.5558e-07 8.5631e-04 0:00:23 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 894 cells
68 4.5111e-03 3.3428e-04 3.0535e-04 3.4565e-04 9.0563e-08 7.9059e-04 0:00:20 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 893 cells
69 4.4237e-03 2.9901e-04 2.7422e-04 3.0898e-04 6.4076e-08 7.4370e-04 0:00:19 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 890 cells
70 4.3415e-03 2.6954e-04 2.4812e-04 2.7860e-04 5.1021e-08 7.0748e-04 0:00:18 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 888 cells
71 4.2635e-03 2.4530e-04 2.2641e-04 2.5385e-04 4.3171e-08 6.7753e-04 0:00:15 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 887 cells
72 4.1889e-03 2.2505e-04 2.0820e-04 2.3299e-04 3.7915e-08 6.5230e-04 0:00:14 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 886 cells
73 4.1170e-03 2.0795e-04 1.9288e-04 2.1530e-04 3.4011e-08 6.2995e-04 0:00:11 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 884 cells
74 4.0476e-03 1.9346e-04 1.7992e-04 2.0031e-04 3.1021e-08 6.1020e-04 0:00:10 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 883 cells
75 3.9805e-03 1.8106e-04 1.6889e-04 1.8746e-04 2.8522e-08 5.9197e-04 0:00:09 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 882 cells
76 3.9154e-03 1.7033e-04 1.5934e-04 1.7631e-04 2.6454e-08 5.7550e-04 0:00:06 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 881 cells
77 3.8523e-03 1.6106e-04 1.5113e-04 1.6676e-04 2.4534e-08 5.6004e-04 0:00:05 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 881 cells
78 3.7910e-03 1.5291e-04 1.4388e-04 1.5840e-04 2.2858e-08 5.4604e-04 0:00:03 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 877 cells
79 3.7315e-03 1.4575e-04 1.3744e-04 1.5106e-04 2.1315e-08 5.3288e-04 0:00:02 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 875 cells
80 3.6737e-03 1.3944e-04 1.3173e-04 1.4470e-04 2.0073e-08 5.2098e-04 0:00:00 0
Flow time = 0.002s, time step = 4
3996 more time stepsUpdating solution at time levels N and N-1.
80 3.6737e-03 1.3944e-04 1.3173e-04 1.4470e-04 2.0073e-08 5.2098e-04 0:00:33 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 722 cells
81 3.6275e-03 5.7943e-03 5.6961e-03 1.1552e-02 3.9396e-04 4.3967e-02 0:00:37 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 667 cells
82 4.8618e-03 1.9111e-03 1.8540e-03 3.5771e-03 8.6265e-05 1.0898e-02 0:00:31 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 636 cells
83 5.0737e-03 7.1437e-04 6.7904e-04 1.1600e-03 1.9163e-05 3.3124e-03 0:00:31 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 618 cells
84 5.0193e-03 4.0882e-04 3.8655e-04 5.2193e-04 4.4898e-06 1.4422e-03 0:00:29 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 605 cells
85 4.9089e-03 3.2853e-04 3.1279e-04 3.5961e-04 1.1707e-06 9.2359e-04 0:00:25 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 600 cells
86 4.7969e-03 2.8829e-04 2.7639e-04 3.0523e-04 3.7136e-07 7.4937e-04 0:00:24 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 599 cells
87 4.6927e-03 2.5863e-04 2.4902e-04 2.7242e-04 1.5992e-07 6.7264e-04 0:00:21 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 596 cells
88 4.5946e-03 2.3558e-04 2.2721e-04 2.4723e-04 9.3063e-08 6.2789e-04 0:00:20 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 593 cells
89 4.5009e-03 2.1781e-04 2.1010e-04 2.2784e-04 6.4740e-08 5.9751e-04 0:00:19 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 593 cells
90 4.4108e-03 2.0402e-04 1.9674e-04 2.1278e-04 5.1780e-08 5.7294e-04 0:00:16 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 592 cells
91 4.3233e-03 1.9311e-04 1.8631e-04 2.0068e-04 4.3334e-08 5.5184e-04 0:00:15 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 590 cells
92 4.2383e-03 1.8436e-04 1.7811e-04 1.9115e-04 3.6963e-08 5.3438e-04 0:00:14 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 589 cells
93 4.1553e-03 1.7705e-04 1.7141e-04 1.8336e-04 3.3679e-08 5.1771e-04 0:00:11 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 586 cells
94 4.0744e-03 1.7081e-04 1.6582e-04 1.7676e-04 3.0291e-08 5.0179e-04 0:00:10 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 584 cells
95 3.9954e-03 1.6530e-04 1.6089e-04 1.7092e-04 2.6908e-08 4.8792e-04 0:00:09 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 584 cells
96 3.9182e-03 1.6028e-04 1.5639e-04 1.6569e-04 2.5554e-08 4.7403e-04 0:00:06 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 583 cells
97 3.8430e-03 1.5574e-04 1.5225e-04 1.6108e-04 2.3622e-08 4.6050e-04 0:00:05 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 582 cells
98 3.7695e-03 1.5158e-04 1.4836e-04 1.5696e-04 2.1460e-08 4.4879e-04 0:00:03 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 583 cells
99 3.6979e-03 1.4766e-04 1.4464e-04 1.5314e-04 2.1113e-08 4.3679e-04 0:00:02 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 581 cells
100 3.6282e-03 1.4398e-04 1.4113e-04 1.4950e-04 1.9804e-08 4.2478e-04 0:00:00 0
Flow time = 0.0025s, time step = 5
3995 more time stepsUpdating solution at time levels N and N-1.
>> Dividing domain into 5 partitions using Metis.
Time = 0.222 seconds.
Done.>> 5 Stored Partitions:
Collective Partition Statistics: Minimum Maximum Total
Cell count 70854 70876 354309
Mean cell count deviation -0.0% 0.0%
Partition boundary cell count 1832 3024 11541
Partition boundary cell count ratio 2.6% 4.3% 3.3%Face count 146129 147869 727836
Mean face count deviation -0.5% 0.7%
Partition boundary face count 2063 3373 6404
Partition boundary face count ratio 1.4% 2.3% 0.9%Cell weights 7e+05 7e+05 4e+06
Mean cell weight deviation -0.0% 0.0%Partition neighbor count 4 4
Partition Method Metis
Stored Partition Count 5
Done.Smoothing partition boundaries...
100 3.6282e-03 1.4398e-04 1.4113e-04 1.4950e-04 1.9804e-08 4.2478e-04 0:00:34 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 488 cells
101 3.7213e-03 4.0668e-03 3.9201e-03 1.5643e-02 3.9482e-04 4.0493e-02 0:00:34 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 448 cells
102 4.6129e-03 1.1915e-03 1.1387e-03 4.2909e-03 8.6139e-05 9.8682e-03 0:00:29 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 429 cells
103 4.7651e-03 4.2016e-04 3.9924e-04 1.2124e-03 1.9142e-05 2.8904e-03 0:00:25 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 420 cells
104 4.7117e-03 2.5111e-04 2.4164e-04 4.2246e-04 4.4946e-06 1.1928e-03 0:00:22 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 415 cells
105 4.6099e-03 2.1867e-04 2.1318e-04 2.5149e-04 1.1757e-06 7.3644e-04 0:00:20 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 414 cells
106 4.5041e-03 2.0398e-04 2.0024e-04 2.1741e-04 3.7488e-07 5.8916e-04 0:00:20 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 413 cells
107 4.4016e-03 1.9326e-04 1.9028e-04 2.0385e-04 1.6088e-07 5.2623e-04 0:00:18 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 412 cells
108 4.3032e-03 1.8497e-04 1.8246e-04 1.9440e-04 9.3839e-08 4.8943e-04 0:00:15 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 411 cells
109 4.2086e-03 1.7832e-04 1.7607e-04 1.8706e-04 6.6219e-08 4.6229e-04 0:00:14 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 411 cells
110 4.1175e-03 1.7262e-04 1.7067e-04 1.8082e-04 5.2050e-08 4.3957e-04 0:00:12 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 409 cells
111 4.0296e-03 1.6746e-04 1.6577e-04 1.7534e-04 4.3367e-08 4.1950e-04 0:00:10 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 409 cells
112 3.9447e-03 1.6278e-04 1.6127e-04 1.7027e-04 3.7555e-08 4.0152e-04 0:00:11 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 409 cells
113 3.8626e-03 1.5839e-04 1.5707e-04 1.6564e-04 3.3250e-08 3.8520e-04 0:00:09 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 408 cells
114 3.7831e-03 1.5432e-04 1.5297e-04 1.6123e-04 2.9670e-08 3.6994e-04 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
115 3.7061e-03 1.5046e-04 1.4902e-04 1.5705e-04 2.6838e-08 3.5618e-04 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
116 3.6315e-03 1.4681e-04 1.4526e-04 1.5308e-04 2.4437e-08 3.4360e-04 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
117 3.5594e-03 1.4330e-04 1.4166e-04 1.4936e-04 2.2244e-08 3.3202e-04 0:00:04 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
118 3.4896e-03 1.3987e-04 1.3820e-04 1.4575e-04 2.0505e-08 3.2145e-04 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 407 cells
119 3.4222e-03 1.3657e-04 1.3485e-04 1.4220e-04 1.8881e-08 3.1164e-04 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 406 cells
120 3.3570e-03 1.3339e-04 1.3163e-04 1.3884e-04 1.7429e-08 3.0257e-04 0:00:00 0
Flow time = 0.003s, time step = 6
3994 more time stepsUpdating solution at time levels N and N-1.
120 3.3570e-03 1.3339e-04 1.3163e-04 1.3884e-04 1.7429e-08 3.0257e-04 0:00:23 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 332 cells
121 3.5092e-03 2.4134e-03 2.3255e-03 1.5813e-02 3.9580e-04 3.7707e-02 0:00:21 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 309 cells
122 3.4129e-03 7.2594e-04 6.9376e-04 4.2005e-03 8.6152e-05 9.0503e-03 0:00:23 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 288 cells
123 3.4016e-03 3.0547e-04 2.9077e-04 1.1733e-03 1.9167e-05 2.5428e-03 0:00:21 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 274 cells
124 3.3612e-03 2.1577e-04 2.0855e-04 3.9850e-04 4.5146e-06 9.6780e-04 0:00:19 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 270 cells
125 3.3007e-03 1.8711e-04 1.8265e-04 2.2440e-04 1.1883e-06 5.5129e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 268 cells
126 3.2396e-03 1.6960e-04 1.6655e-04 1.8799e-04 3.8226e-07 4.2355e-04 0:00:16 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 266 cells
127 3.1825e-03 1.5711e-04 1.5460e-04 1.7203e-04 1.6460e-07 3.7276e-04 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 264 cells
128 3.1288e-03 1.4776e-04 1.4547e-04 1.6034e-04 9.5216e-08 3.4674e-04 0:00:15 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 264 cells
129 3.0777e-03 1.4044e-04 1.3825e-04 1.5099e-04 6.6250e-08 3.2882e-04 0:00:13 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 263 cells
130 3.0286e-03 1.3455e-04 1.3235e-04 1.4343e-04 5.1632e-08 3.1569e-04 0:00:12 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 262 cells
131 2.9813e-03 1.2963e-04 1.2741e-04 1.3725e-04 4.2878e-08 3.0387e-04 0:00:10 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 261 cells
132 2.9357e-03 1.2537e-04 1.2321e-04 1.3210e-04 3.6798e-08 2.9422e-04 0:00:09 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 261 cells
133 2.8916e-03 1.2163e-04 1.1956e-04 1.2770e-04 3.2375e-08 2.8469e-04 0:00:08 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 260 cells
134 2.8491e-03 1.1829e-04 1.1633e-04 1.2386e-04 2.9053e-08 2.7680e-04 0:00:06 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 260 cells
135 2.8081e-03 1.1528e-04 1.1346e-04 1.2048e-04 2.6312e-08 2.6864e-04 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 258 cells
136 2.7686e-03 1.1252e-04 1.1083e-04 1.1746e-04 2.4059e-08 2.6166e-04 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 257 cells
137 2.7306e-03 1.0998e-04 1.0842e-04 1.1472e-04 2.2447e-08 2.5419e-04 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 256 cells
138 2.6940e-03 1.0763e-04 1.0618e-04 1.1220e-04 2.0705e-08 2.4780e-04 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 256 cells
139 2.6589e-03 1.0544e-04 1.0409e-04 1.0987e-04 1.8953e-08 2.4066e-04 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 255 cells
140 2.6252e-03 1.0344e-04 1.0217e-04 1.0775e-04 1.7633e-08 2.3476e-04 0:00:00 0
Flow time = 0.0035s, time step = 7
3993 more time stepsUpdating solution at time levels N and N-1.
140 2.6252e-03 1.0344e-04 1.0217e-04 1.0775e-04 1.7633e-08 2.3476e-04 0:00:26 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 214 cells
141 2.8288e-03 3.6231e-03 3.5021e-03 1.3539e-02 3.9671e-04 3.5334e-02 0:00:27 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 197 cells
142 3.2665e-03 1.0481e-03 1.0088e-03 3.6279e-03 8.6240e-05 8.3602e-03 0:00:24 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 190 cells
143 3.3481e-03 3.8470e-04 3.7127e-04 1.0327e-03 1.9212e-05 2.2641e-03 0:00:22 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 180 cells
144 3.3247e-03 2.3545e-04 2.3025e-04 3.7262e-04 4.5354e-06 8.0654e-04 0:00:23 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 178 cells
145 3.2603e-03 2.0118e-04 1.9778e-04 2.2996e-04 1.1963e-06 4.3217e-04 0:00:20 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 176 cells
146 3.1890e-03 1.8537e-04 1.8230e-04 2.0112e-04 3.8450e-07 3.2299e-04 0:00:18 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 176 cells
147 3.1228e-03 1.7449e-04 1.7163e-04 1.8711e-04 1.6480e-07 2.8330e-04 0:00:16 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 176 cells
148 3.0616e-03 1.6656e-04 1.6385e-04 1.7712e-04 9.4744e-08 2.6398e-04 0:00:14 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 176 cells
149 3.0040e-03 1.6057e-04 1.5809e-04 1.6969e-04 6.5509e-08 2.5164e-04 0:00:13 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 175 cells
150 2.9491e-03 1.5585e-04 1.5358e-04 1.6402e-04 5.1111e-08 2.4229e-04 0:00:13 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 174 cells
151 2.8966e-03 1.5196e-04 1.4987e-04 1.5953e-04 4.2378e-08 2.3439e-04 0:00:11 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
152 2.8464e-03 1.4859e-04 1.4664e-04 1.5579e-04 3.6197e-08 2.2733e-04 0:00:10 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
153 2.7982e-03 1.4558e-04 1.4373e-04 1.5250e-04 3.1557e-08 2.2086e-04 0:00:08 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
154 2.7520e-03 1.4278e-04 1.4107e-04 1.4951e-04 2.7734e-08 2.1476e-04 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
155 2.7078e-03 1.4016e-04 1.3861e-04 1.4675e-04 2.4601e-08 2.0897e-04 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
156 2.6653e-03 1.3771e-04 1.3630e-04 1.4419e-04 2.2084e-08 2.0347e-04 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 173 cells
157 2.6244e-03 1.3535e-04 1.3408e-04 1.4173e-04 2.0006e-08 1.9821e-04 0:00:04 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 171 cells
158 2.5849e-03 1.3305e-04 1.3193e-04 1.3934e-04 1.8256e-08 1.9315e-04 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 171 cells
159 2.5468e-03 1.3079e-04 1.2981e-04 1.3700e-04 1.6794e-08 1.8827e-04 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 171 cells
160 2.5099e-03 1.2863e-04 1.2776e-04 1.3471e-04 1.5647e-08 1.8357e-04 0:00:00 0
Flow time = 0.004s, time step = 8
3992 more time stepsUpdating solution at time levels N and N-1.
160 2.5099e-03 1.2863e-04 1.2776e-04 1.3471e-04 1.5647e-08 1.8357e-04 0:00:22 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 144 cells
161 2.7172e-03 1.9624e-03 1.8703e-03 1.0534e-02 3.9750e-04 3.3264e-02 0:00:25 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 128 cells
162 2.7223e-03 6.8900e-04 6.5493e-04 3.1201e-03 8.6338e-05 7.7949e-03 0:00:22 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 123 cells
163 2.6524e-03 3.3268e-04 3.2048e-04 9.5569e-04 1.9257e-05 2.0588e-03 0:00:20 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 123 cells
164 2.5857e-03 2.5865e-04 2.5322e-04 3.9443e-04 4.5562e-06 6.9849e-04 0:00:18 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 123 cells
165 2.5093e-03 2.3498e-04 2.3111e-04 2.6619e-04 1.2039e-06 3.5383e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 121 cells
166 2.4347e-03 2.1972e-04 2.1640e-04 2.3517e-04 3.8688e-07 2.5556e-04 0:00:18 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 120 cells
167 2.3689e-03 2.0781e-04 2.0488e-04 2.1991e-04 1.6543e-07 2.2074e-04 0:00:16 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 120 cells
168 2.3100e-03 1.9814e-04 1.9559e-04 2.0851e-04 9.4814e-08 2.0387e-04 0:00:14 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 118 cells
169 2.2559e-03 1.9008e-04 1.8789e-04 1.9931e-04 6.5253e-08 1.9299e-04 0:00:13 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 117 cells
170 2.2053e-03 1.8315e-04 1.8128e-04 1.9165e-04 5.0410e-08 1.8462e-04 0:00:11 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
171 2.1576e-03 1.7705e-04 1.7544e-04 1.8502e-04 4.1619e-08 1.7759e-04 0:00:12 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
172 2.1127e-03 1.7158e-04 1.7015e-04 1.7912e-04 3.5571e-08 1.7142e-04 0:00:10 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
173 2.0703e-03 1.6660e-04 1.6529e-04 1.7381e-04 3.0946e-08 1.6582e-04 0:00:08 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
174 2.0304e-03 1.6200e-04 1.6081e-04 1.6894e-04 2.7002e-08 1.6067e-04 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
175 1.9927e-03 1.5770e-04 1.5662e-04 1.6442e-04 2.3805e-08 1.5596e-04 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
176 1.9572e-03 1.5361e-04 1.5266e-04 1.6019e-04 2.1217e-08 1.5170e-04 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
177 1.9237e-03 1.4970e-04 1.4885e-04 1.5620e-04 1.9113e-08 1.4777e-04 0:00:04 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
178 1.8922e-03 1.4597e-04 1.4522e-04 1.5240e-04 1.7402e-08 1.4410e-04 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
179 1.8626e-03 1.4241e-04 1.4177e-04 1.4876e-04 1.5868e-08 1.4059e-04 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 115 cells
180 1.8350e-03 1.3901e-04 1.3846e-04 1.4528e-04 1.4500e-08 1.3720e-04 0:00:00 0
Flow time = 0.004500000000000001s, time step = 9
3991 more time stepsUpdating solution at time levels N and N-1.
180 1.8350e-03 1.3901e-04 1.3846e-04 1.4528e-04 1.4500e-08 1.3720e-04 0:00:26 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 100 cells
181 2.0639e-03 3.9635e-03 3.8713e-03 1.7879e-02 3.9812e-04 3.1447e-02 0:00:23 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 91 cells
182 1.7726e-03 1.4607e-03 1.4222e-03 5.9272e-03 8.6438e-05 7.3387e-03 0:00:21 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 88 cells
183 1.6077e-03 6.0706e-04 5.8977e-04 1.8074e-03 1.9304e-05 1.8962e-03 0:00:23 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 86 cells
184 1.5348e-03 3.9228e-04 3.8274e-04 6.6840e-04 4.5756e-06 6.1150e-04 0:00:20 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 83 cells
185 1.4700e-03 3.2278e-04 3.1490e-04 3.8319e-04 1.2116e-06 2.8895e-04 0:00:18 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
186 1.4139e-03 2.8194e-04 2.7514e-04 3.0713e-04 3.8992e-07 1.9929e-04 0:00:16 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
187 1.3696e-03 2.5167e-04 2.4583e-04 2.7124e-04 1.6665e-07 1.6932e-04 0:00:15 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
188 1.3335e-03 2.2833e-04 2.2314e-04 2.4549e-04 9.5284e-08 1.5613e-04 0:00:16 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
189 1.3022e-03 2.0986e-04 2.0521e-04 2.2513e-04 6.5165e-08 1.4838e-04 0:00:14 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
190 1.2741e-03 1.9495e-04 1.9077e-04 2.0858e-04 4.9998e-08 1.4276e-04 0:00:12 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
191 1.2485e-03 1.8258e-04 1.7885e-04 1.9486e-04 4.0854e-08 1.3813e-04 0:00:12 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
192 1.2249e-03 1.7206e-04 1.6874e-04 1.8329e-04 3.4370e-08 1.3402e-04 0:00:10 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
193 1.2032e-03 1.6292e-04 1.5996e-04 1.7328e-04 2.9511e-08 1.3031e-04 0:00:09 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
194 1.1831e-03 1.5484e-04 1.5223e-04 1.6452e-04 2.5732e-08 1.2694e-04 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 80 cells
195 1.1647e-03 1.4762e-04 1.4530e-04 1.5674e-04 2.2694e-08 1.2384e-04 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
196 1.1477e-03 1.4109e-04 1.3906e-04 1.4972e-04 2.0318e-08 1.2098e-04 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
197 1.1322e-03 1.3518e-04 1.3338e-04 1.4338e-04 1.8524e-08 1.1831e-04 0:00:04 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
198 1.1181e-03 1.2975e-04 1.2819e-04 1.3755e-04 1.6712e-08 1.1572e-04 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
199 1.1052e-03 1.2477e-04 1.2340e-04 1.3217e-04 1.4930e-08 1.1331e-04 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 78 cells
200 1.0935e-03 1.2017e-04 1.1894e-04 1.2720e-04 1.3322e-08 1.1106e-04 0:00:00 0
Flow time = 0.005000000000000001s, time step = 10
3990 more time stepsUpdating solution at time levels N and N-1.
200 1.0935e-03 1.2017e-04 1.1894e-04 1.2720e-04 1.3322e-08 1.1106e-04 0:00:23 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 71 cells
201 1.4057e-03 6.9893e-03 6.7858e-03 3.4997e-02 3.9855e-04 2.9897e-02 0:00:21 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 67 cells
202 1.2787e-03 2.6430e-03 2.5590e-03 1.2316e-02 8.6526e-05 7.0101e-03 0:00:23 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 64 cells
203 1.1687e-03 9.6695e-04 9.3193e-04 3.5950e-03 1.9345e-05 1.7835e-03 0:00:21 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 63 cells
204 1.1202e-03 5.3016e-04 5.1249e-04 1.1662e-03 4.5925e-06 5.5688e-04 0:00:19 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 61 cells
205 1.0745e-03 4.0937e-04 3.9677e-04 5.4578e-04 1.2175e-06 2.5163e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 61 cells
206 1.0353e-03 3.4655e-04 3.3647e-04 3.8376e-04 3.9179e-07 1.6818e-04 0:00:16 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 60 cells
207 1.0057e-03 3.0133e-04 2.9323e-04 3.2293e-04 1.6687e-07 1.4101e-04 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 60 cells
208 9.8235e-04 2.6681e-04 2.6012e-04 2.8454e-04 9.4775e-08 1.2939e-04 0:00:13 12
! 208 solution is converged
Flow time = 0.005500000000000001s, time step = 11
3989 more time stepsUpdating solution at time levels N and N-1.
208 9.8235e-04 2.6681e-04 2.6012e-04 2.8454e-04 9.4775e-08 1.2939e-04 0:00:21 20
! 208 solution is convergedturbulent viscosity limited to viscosity ratio of 1.000000e+05 in 58 cells
209 1.3222e-03 9.0554e-03 8.7845e-03 5.6668e-02 3.9873e-04 2.8606e-02 0:00:24 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 55 cells
210 1.7842e-03 2.4817e-03 2.3979e-03 1.4378e-02 8.6566e-05 6.8500e-03 0:00:22 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 54 cells
211 1.8239e-03 8.0370e-04 7.7499e-04 3.5616e-03 1.9365e-05 1.7275e-03 0:00:20 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 53 cells
212 1.8046e-03 4.6579e-04 4.5297e-04 1.0819e-03 4.5971e-06 5.3247e-04 0:00:18 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 53 cells
213 1.7591e-03 3.8429e-04 3.7582e-04 4.9827e-04 1.2153e-06 2.3609e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
214 1.7086e-03 3.4224e-04 3.3578e-04 3.7470e-04 3.8765e-07 1.5561e-04 0:00:15 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
215 1.6631e-03 3.1210e-04 3.0685e-04 3.3596e-04 1.6273e-07 1.2956e-04 0:00:16 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
216 1.6224e-03 2.8936e-04 2.8508e-04 3.0980e-04 9.1164e-08 1.1830e-04 0:00:15 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
217 1.5848e-03 2.7230e-04 2.6860e-04 2.8961e-04 6.1180e-08 1.1163e-04 0:00:13 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
218 1.5495e-03 2.5906e-04 2.5579e-04 2.7376e-04 4.6129e-08 1.0674e-04 0:00:11 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
219 1.5158e-03 2.4852e-04 2.4572e-04 2.6115e-04 3.7037e-08 1.0275e-04 0:00:10 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
220 1.4834e-03 2.3998e-04 2.3752e-04 2.5088e-04 3.0834e-08 9.9322e-05 0:00:09 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
221 1.4522e-03 2.3282e-04 2.3060e-04 2.4241e-04 2.6172e-08 9.6275e-05 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
222 1.4219e-03 2.2672e-04 2.2473e-04 2.3529e-04 2.2498e-08 9.3433e-05 0:00:08 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 52 cells
223 1.3925e-03 2.2133e-04 2.1954e-04 2.2920e-04 1.9549e-08 9.0727e-05 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 51 cells
224 1.3639e-03 2.1654e-04 2.1494e-04 2.2391e-04 1.7130e-08 8.8132e-05 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 51 cells
225 1.3361e-03 2.1208e-04 2.1075e-04 2.1915e-04 1.5116e-08 8.5648e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 51 cells
226 1.3090e-03 2.0794e-04 2.0683e-04 2.1485e-04 1.3463e-08 8.3273e-05 0:00:03 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 51 cells
227 1.2826e-03 2.0407e-04 2.0318e-04 2.1088e-04 1.2025e-08 8.1010e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 50 cells
228 1.2569e-03 2.0038e-04 1.9965e-04 2.0716e-04 1.0774e-08 7.8916e-05 0:00:00 0
Flow time = 0.006000000000000002s, time step = 12
3988 more time stepsUpdating solution at time levels N and N-1.
228 1.2569e-03 2.0038e-04 1.9965e-04 2.0716e-04 1.0774e-08 7.8916e-05 0:00:24 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 46 cells
229 1.7753e-03 2.8031e-03 2.7581e-03 5.6505e-02 3.9884e-04 2.7692e-02 0:00:26 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 39 cells
230 1.8083e-03 6.5105e-04 6.2867e-04 1.0524e-02 8.6635e-05 6.8444e-03 0:00:23 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 39 cells
231 1.6681e-03 2.9554e-04 2.8230e-04 2.5823e-03 1.9409e-05 1.7112e-03 0:00:21 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
232 1.5987e-03 2.2385e-04 2.1613e-04 7.2687e-04 4.6198e-06 5.0840e-04 0:00:19 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
233 1.5408e-03 1.9982e-04 1.9464e-04 2.7945e-04 1.2268e-06 2.0733e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
234 1.4877e-03 1.8509e-04 1.8128e-04 2.0251e-04 3.9432e-07 1.2578e-04 0:00:18 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
235 1.4448e-03 1.7427e-04 1.7130e-04 1.8592e-04 1.6706e-07 1.0012e-04 0:00:16 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 37 cells
236 1.4093e-03 1.6584e-04 1.6345e-04 1.7608e-04 9.4105e-08 8.9700e-05 0:00:14 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
237 1.3781e-03 1.5903e-04 1.5710e-04 1.6825e-04 6.3366e-08 8.3950e-05 0:00:13 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
238 1.3499e-03 1.5337e-04 1.5177e-04 1.6167e-04 4.8129e-08 7.9950e-05 0:00:11 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
239 1.3237e-03 1.4851e-04 1.4712e-04 1.5607e-04 3.8696e-08 7.6773e-05 0:00:10 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
240 1.2991e-03 1.4422e-04 1.4302e-04 1.5122e-04 3.1903e-08 7.4130e-05 0:00:09 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
241 1.2757e-03 1.4035e-04 1.3928e-04 1.4689e-04 2.6856e-08 7.1959e-05 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
242 1.2533e-03 1.3679e-04 1.3583e-04 1.4299e-04 2.2950e-08 7.0154e-05 0:00:08 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
243 1.2317e-03 1.3347e-04 1.3264e-04 1.3941e-04 1.9838e-08 6.8626e-05 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 36 cells
244 1.2107e-03 1.3034e-04 1.2966e-04 1.3613e-04 1.7332e-08 6.7307e-05 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 35 cells
245 1.1904e-03 1.2735e-04 1.2682e-04 1.3304e-04 1.5327e-08 6.6134e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 35 cells
246 1.1707e-03 1.2448e-04 1.2407e-04 1.3009e-04 1.3538e-08 6.5040e-05 0:00:03 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 35 cells
247 1.1515e-03 1.2176e-04 1.2142e-04 1.2729e-04 1.1958e-08 6.4012e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 35 cells
248 1.1329e-03 1.1919e-04 1.1889e-04 1.2459e-04 1.0646e-08 6.3115e-05 0:00:00 0
Flow time = 0.006500000000000002s, time step = 13
3987 more time stepsUpdating solution at time levels N and N-1.
248 1.1329e-03 1.1919e-04 1.1889e-04 1.2459e-04 1.0646e-08 6.3115e-05 0:00:24 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 31 cells
249 1.9637e-03 2.8665e-03 2.7469e-03 3.3314e-02 3.9885e-04 2.7024e-02 0:00:26 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 31 cells
250 1.8630e-03 7.0427e-04 6.6858e-04 7.0074e-03 8.6701e-05 6.7245e-03 0:00:23 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 30 cells
251 1.6891e-03 2.7951e-04 2.6321e-04 1.7901e-03 1.9446e-05 1.6899e-03 0:00:21 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 30 cells
252 1.6019e-03 1.8367e-04 1.7457e-04 5.2251e-04 4.6340e-06 4.9509e-04 0:00:19 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
253 1.5360e-03 1.5306e-04 1.4695e-04 2.1538e-04 1.2315e-06 1.9321e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
254 1.4782e-03 1.3563e-04 1.3107e-04 1.5171e-04 3.9578e-07 1.1167e-04 0:00:16 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
255 1.4373e-03 1.2315e-04 1.1950e-04 1.3356e-04 1.6746e-07 8.6694e-05 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
256 1.4100e-03 1.1360e-04 1.1055e-04 1.2263e-04 9.4065e-08 7.7187e-05 0:00:13 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
257 1.3902e-03 1.0607e-04 1.0347e-04 1.1416e-04 6.2979e-08 7.2345e-05 0:00:14 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
258 1.3747e-03 9.9980e-05 9.7773e-05 1.0728e-04 4.7202e-08 6.9150e-05 0:00:12 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
259 1.3624e-03 9.4921e-05 9.3039e-05 1.0159e-04 3.7568e-08 6.6677e-05 0:00:10 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
260 1.3520e-03 9.0647e-05 8.9041e-05 9.6801e-05 3.0915e-08 6.4610e-05 0:00:09 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
261 1.3431e-03 8.6988e-05 8.5619e-05 9.2731e-05 2.5966e-08 6.2816e-05 0:00:08 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
262 1.3354e-03 8.3825e-05 8.2653e-05 8.9211e-05 2.2114e-08 6.1217e-05 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
263 1.3285e-03 8.1054e-05 8.0032e-05 8.6148e-05 1.9027e-08 5.9757e-05 0:00:05 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
264 1.3224e-03 7.8591e-05 7.7714e-05 8.3418e-05 1.6503e-08 5.8398e-05 0:00:04 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
265 1.3168e-03 7.6404e-05 7.5657e-05 8.0995e-05 1.4408e-08 5.7108e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
266 1.3117e-03 7.4442e-05 7.3825e-05 7.8827e-05 1.2650e-08 5.5862e-05 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
267 1.3070e-03 7.2657e-05 7.2184e-05 7.6872e-05 1.1160e-08 5.4635e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 29 cells
268 1.3028e-03 7.1050e-05 7.0702e-05 7.5092e-05 9.8883e-09 5.3412e-05 0:00:00 0
Flow time = 0.007000000000000003s, time step = 14
3986 more time stepsUpdating solution at time levels N and N-1.
268 1.3028e-03 7.1050e-05 7.0702e-05 7.5092e-05 9.8883e-09 5.3412e-05 0:00:23 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 28 cells
269 2.7003e-03 2.8761e-03 2.7503e-03 1.9882e-02 3.9876e-04 2.5929e-02 0:00:25 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 25 cells
270 2.7855e-03 7.4603e-04 7.0752e-04 4.5470e-03 8.6752e-05 6.4361e-03 0:00:23 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 25 cells
271 2.5387e-03 2.7814e-04 2.6299e-04 1.2059e-03 1.9477e-05 1.6039e-03 0:00:20 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 25 cells
272 2.3783e-03 1.7108e-04 1.6424e-04 3.7950e-04 4.6476e-06 4.6239e-04 0:00:19 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
273 2.2584e-03 1.4053e-04 1.3643e-04 1.7577e-04 1.2368e-06 1.7297e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
274 2.1569e-03 1.2413e-04 1.2118e-04 1.3421e-04 3.9821e-07 9.4667e-05 0:00:15 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
275 2.0834e-03 1.1244e-04 1.1009e-04 1.2046e-04 1.6894e-07 6.9872e-05 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
276 2.0324e-03 1.0348e-04 1.0156e-04 1.1057e-04 9.5092e-08 6.0745e-05 0:00:13 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
277 1.9943e-03 9.6483e-05 9.4902e-05 1.0266e-04 6.3796e-08 5.5576e-05 0:00:12 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
278 1.9646e-03 9.0899e-05 8.9547e-05 9.6278e-05 4.7831e-08 5.2906e-05 0:00:10 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
279 1.9407e-03 8.6326e-05 8.5119e-05 9.1047e-05 3.8186e-08 5.0353e-05 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
280 1.9208e-03 8.2525e-05 8.1408e-05 8.6691e-05 3.1553e-08 4.9015e-05 0:00:10 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
281 1.9037e-03 7.9295e-05 7.8244e-05 8.3006e-05 2.6820e-08 4.7272e-05 0:00:08 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
282 1.8886e-03 7.6514e-05 7.5523e-05 7.9840e-05 2.2822e-08 4.6450e-05 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
283 1.8751e-03 7.4088e-05 7.3150e-05 7.7099e-05 1.9704e-08 4.5096e-05 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
284 1.8629e-03 7.1932e-05 7.1059e-05 7.4685e-05 1.7126e-08 4.4630e-05 0:00:04 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
285 1.8516e-03 6.9998e-05 6.9188e-05 7.2533e-05 1.5107e-08 4.3554e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
286 1.8410e-03 6.8253e-05 6.7508e-05 7.0614e-05 1.3349e-08 4.3277e-05 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
287 1.8310e-03 6.6670e-05 6.5980e-05 6.8869e-05 1.1953e-08 4.2327e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 23 cells
288 1.8216e-03 6.5232e-05 6.4580e-05 6.7275e-05 1.0687e-08 4.2130e-05 0:00:00 0
Flow time = 0.007500000000000003s, time step = 15
3985 more time stepsUpdating solution at time levels N and N-1.
288 1.8216e-03 6.5232e-05 6.4580e-05 6.7275e-05 1.0687e-08 4.2130e-05 0:00:21 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 20 cells
289 3.4786e-03 2.1270e-03 2.0342e-03 1.1918e-02 3.9859e-04 2.4670e-02 0:00:23 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 20 cells
290 3.5243e-03 5.9757e-04 5.6515e-04 2.9055e-03 8.6796e-05 6.1017e-03 0:00:21 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 20 cells
291 3.1820e-03 2.3540e-04 2.2128e-04 8.0035e-04 1.9507e-05 1.5032e-03 0:00:20 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 20 cells
292 2.9613e-03 1.5062e-04 1.4350e-04 2.6647e-04 4.6566e-06 4.2561e-04 0:00:18 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 19 cells
293 2.8031e-03 1.2541e-04 1.2051e-04 1.3924e-04 1.2378e-06 1.5504e-04 0:00:16 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 19 cells
294 2.6698e-03 1.1135e-04 1.0761e-04 1.1632e-04 3.9629e-07 8.2147e-05 0:00:15 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 19 cells
295 2.5688e-03 1.0118e-04 9.8087e-05 1.0557e-04 1.6617e-07 5.9901e-05 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
296 2.4955e-03 9.3385e-05 9.0737e-05 9.7220e-05 9.2202e-08 5.1422e-05 0:00:13 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
297 2.4384e-03 8.7299e-05 8.4985e-05 9.0551e-05 6.0878e-08 4.7057e-05 0:00:11 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
298 2.3919e-03 8.2463e-05 8.0403e-05 8.5214e-05 4.5006e-08 4.4134e-05 0:00:10 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
299 2.3531e-03 7.8525e-05 7.6658e-05 8.0867e-05 3.5343e-08 4.1840e-05 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
300 2.3199e-03 7.5245e-05 7.3529e-05 7.7281e-05 2.8706e-08 3.9900e-05 0:00:08 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
301 2.2911e-03 7.2449e-05 7.0875e-05 7.4270e-05 2.3806e-08 3.8201e-05 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
302 2.2654e-03 7.0031e-05 6.8587e-05 7.1707e-05 2.0026e-08 3.6678e-05 0:00:07 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
303 2.2421e-03 6.7908e-05 6.6589e-05 6.9476e-05 1.7025e-08 3.5299e-05 0:00:06 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
304 2.2209e-03 6.6032e-05 6.4824e-05 6.7510e-05 1.4596e-08 3.4044e-05 0:00:05 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
305 2.2014e-03 6.4363e-05 6.3250e-05 6.5758e-05 1.2598e-08 3.2901e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
306 2.1833e-03 6.2864e-05 6.1826e-05 6.4188e-05 1.0935e-08 3.1861e-05 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
307 2.1663e-03 6.1503e-05 6.0536e-05 6.2764e-05 9.5362e-09 3.0918e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 18 cells
308 2.1504e-03 6.0262e-05 5.9360e-05 6.1472e-05 8.3487e-09 3.0064e-05 0:00:00 0
Flow time = 0.008000000000000004s, time step = 16
3984 more time stepsUpdating solution at time levels N and N-1.
Time = 0.16 seconds.
Cell count 70622 70654 353168
Partition boundary cell count 1719 3014 11169
Partition boundary cell count ratio 2.4% 4.3% 3.2%Face count 145673 147164 725554
Mean face count deviation -0.5% 0.6%
Partition boundary face count 1918 3335 6203
Partition boundary face count ratio 1.3% 2.3% 0.9%Cell weights 7e+05 7e+05 4e+06
Mean cell weight deviation -0.0% 0.0%Partition neighbor count 2 4
done.iter continuity x-velocity y-velocity z-velocity k omega time/iter
308 2.1504e-03 6.0262e-05 5.9360e-05 6.1472e-05 8.3487e-09 3.0064e-05 0:00:21 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 15 cells
309 3.9188e-03 1.2064e-03 1.1553e-03 4.9341e-03 3.9836e-04 2.3664e-02 0:00:20 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 14 cells
310 3.7433e-03 3.8076e-04 3.6001e-04 1.2981e-03 8.6831e-05 5.8699e-03 0:00:19 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13 cells
311 3.3402e-03 1.7298e-04 1.6278e-04 3.8589e-04 1.9537e-05 1.4339e-03 0:00:17 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13 cells
312 3.0788e-03 1.2267e-04 1.1675e-04 1.5249e-04 4.6684e-06 3.9749e-04 0:00:20 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13 cells
313 2.8967e-03 1.0652e-04 1.0239e-04 1.1014e-04 1.2414e-06 1.3746e-04 0:00:18 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 13 cells
314 2.7488e-03 9.7165e-05 9.3946e-05 9.9722e-05 3.9691e-07 6.7615e-05 0:00:16 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
315 2.6368e-03 9.0245e-05 8.7578e-05 9.2786e-05 1.6574e-07 4.6431e-05 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
316 2.5535e-03 8.4858e-05 8.2581e-05 8.7272e-05 9.1413e-08 3.8494e-05 0:00:13 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
317 2.4882e-03 8.0593e-05 7.8591e-05 8.2856e-05 5.9938e-08 3.4560e-05 0:00:12 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
318 2.4353e-03 7.7133e-05 7.5337e-05 7.9264e-05 4.3957e-08 3.2064e-05 0:00:11 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
319 2.3912e-03 7.4265e-05 7.2630e-05 7.6283e-05 3.4246e-08 3.0209e-05 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
320 2.3535e-03 7.1811e-05 7.0336e-05 7.3750e-05 2.7607e-08 2.8702e-05 0:00:08 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
321 2.3207e-03 6.9671e-05 6.8342e-05 7.1546e-05 2.2734e-08 2.7410e-05 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
322 2.2916e-03 6.7788e-05 6.6581e-05 6.9603e-05 1.8999e-08 2.6253e-05 0:00:06 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
323 2.2656e-03 6.6118e-05 6.5009e-05 6.7871e-05 1.6052e-08 2.5193e-05 0:00:05 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 12 cells
324 2.2420e-03 6.4614e-05 6.3595e-05 6.6307e-05 1.3681e-08 2.4212e-05 0:00:04 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
325 2.2204e-03 6.3247e-05 6.2307e-05 6.4881e-05 1.1743e-08 2.3291e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
326 2.2004e-03 6.2004e-05 6.1125e-05 6.3571e-05 1.0140e-08 2.2416e-05 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
327 2.1816e-03 6.0862e-05 6.0041e-05 6.2366e-05 8.8025e-09 2.1577e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
328 2.1640e-03 5.9812e-05 5.9043e-05 6.1245e-05 7.6742e-09 2.0771e-05 0:00:00 0
Flow time = 0.008500000000000004s, time step = 17
3983 more time stepsUpdating solution at time levels N and N-1.
done.Updating mesh at time level N... done.
328 2.1640e-03 5.9812e-05 5.9043e-05 6.1245e-05 7.6742e-09 2.0771e-05 0:00:20 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
329 4.0142e-03 4.5963e-04 4.3376e-04 3.5314e-03 3.9808e-04 2.2721e-02 0:00:19 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
330 3.6138e-03 2.0205e-04 1.8807e-04 9.8809e-04 8.6863e-05 5.6961e-03 0:00:18 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 9 cells
331 3.1078e-03 1.2767e-04 1.1874e-04 3.0414e-04 1.9565e-05 1.3775e-03 0:00:17 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 9 cells
332 2.8255e-03 1.0381e-04 9.8258e-05 1.3333e-04 4.6784e-06 3.7468e-04 0:00:19 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 9 cells
333 2.6363e-03 9.2653e-05 8.8743e-05 9.9107e-05 1.2439e-06 1.2291e-04 0:00:17 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
334 2.4843e-03 8.5180e-05 8.2146e-05 8.8673e-05 3.9693e-07 5.5213e-05 0:00:16 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
335 2.3695e-03 7.9451e-05 7.6947e-05 8.2298e-05 1.6522e-07 3.4707e-05 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
336 2.2856e-03 7.4873e-05 7.2750e-05 7.7416e-05 9.0558e-08 2.7104e-05 0:00:13 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
337 2.2210e-03 7.1146e-05 6.9306e-05 7.3460e-05 5.8877e-08 2.3416e-05 0:00:12 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
338 2.1692e-03 6.8051e-05 6.6446e-05 7.0171e-05 4.2823e-08 2.1060e-05 0:00:11 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
339 2.1268e-03 6.5437e-05 6.4029e-05 6.7387e-05 3.3090e-08 1.9493e-05 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
340 2.0911e-03 6.3197e-05 6.1952e-05 6.4999e-05 2.6458e-08 1.8325e-05 0:00:08 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 8 cells
341 2.0606e-03 6.1248e-05 6.0144e-05 6.2924e-05 2.1611e-08 1.7413e-05 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
342 2.0340e-03 5.9543e-05 5.8557e-05 6.1106e-05 1.7914e-08 1.6668e-05 0:00:06 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
343 2.0105e-03 5.8036e-05 5.7155e-05 5.9497e-05 1.5018e-08 1.6038e-05 0:00:05 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
344 1.9894e-03 5.6695e-05 5.5899e-05 5.8060e-05 1.2707e-08 1.5487e-05 0:00:04 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
345 1.9702e-03 5.5493e-05 5.4771e-05 5.6773e-05 1.0829e-08 1.4981e-05 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
346 1.9526e-03 5.4410e-05 5.3750e-05 5.5615e-05 9.2885e-09 1.4494e-05 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
347 1.9362e-03 5.3426e-05 5.2817e-05 5.4564e-05 8.0125e-09 1.4010e-05 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
348 1.9209e-03 5.2529e-05 5.1968e-05 5.3613e-05 6.9455e-09 1.3517e-05 0:00:00 0
Flow time = 0.009000000000000005s, time step = 18
3982 more time stepsUpdating solution at time levels N and N-1.
348 1.9209e-03 5.2529e-05 5.1968e-05 5.3613e-05 6.9455e-09 1.3517e-05 0:00:20 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 7 cells
349 3.8802e-03 7.7460e-04 7.1732e-04 9.6757e-03 3.9776e-04 2.1947e-02 0:00:23 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
350 3.2232e-03 2.7983e-04 2.5817e-04 2.7136e-03 8.6889e-05 5.5172e-03 0:00:21 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
351 2.6493e-03 1.4009e-04 1.3024e-04 7.5676e-04 1.9593e-05 1.3313e-03 0:00:19 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
352 2.3490e-03 1.0418e-04 9.8804e-05 2.3849e-04 4.6884e-06 3.5746e-04 0:00:18 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
353 2.1576e-03 8.9523e-05 8.5856e-05 1.1368e-04 1.2457e-06 1.1288e-04 0:00:16 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6 cells
354 2.0066e-03 8.0272e-05 7.7362e-05 8.7926e-05 3.9616e-07 4.7284e-05 0:00:15 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
355 1.8954e-03 7.3574e-05 7.1107e-05 7.8419e-05 1.6358e-07 2.7586e-05 0:00:14 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
356 1.8150e-03 6.8484e-05 6.6343e-05 7.2296e-05 8.9022e-08 2.0395e-05 0:00:13 12
(cx-use-window-id 5)turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
357 1.7530e-03 6.4510e-05 6.2644e-05 6.7680e-05 5.7484e-08 1.6984e-05 0:00:11 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
358 1.7033e-03 6.1331e-05 5.9705e-05 6.4055e-05 4.1536e-08 1.4931e-05 0:00:10 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
359 1.6627e-03 5.8722e-05 5.7295e-05 6.1097e-05 3.1901e-08 1.3494e-05 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
360 1.6288e-03 5.6547e-05 5.5276e-05 5.8630e-05 2.5363e-08 1.2399e-05 0:00:08 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
361 1.5998e-03 5.4698e-05 5.3562e-05 5.6538e-05 2.0605e-08 1.1520e-05 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
362 1.5746e-03 5.3100e-05 5.2091e-05 5.4740e-05 1.6992e-08 1.0788e-05 0:00:06 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
363 1.5525e-03 5.1705e-05 5.0807e-05 5.3181e-05 1.4169e-08 1.0155e-05 0:00:05 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
364 1.5327e-03 5.0472e-05 4.9671e-05 5.1819e-05 1.1919e-08 9.5979e-06 0:00:04 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
365 1.5149e-03 4.9373e-05 4.8661e-05 5.0619e-05 1.0097e-08 9.1055e-06 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
366 1.4988e-03 4.8382e-05 4.7757e-05 4.9548e-05 8.6030e-09 8.6724e-06 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
367 1.4840e-03 4.7489e-05 4.6943e-05 4.8586e-05 7.3653e-09 8.2990e-06 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 5 cells
368 1.4704e-03 4.6680e-05 4.6204e-05 4.7720e-05 6.3313e-09 7.9789e-06 0:00:00 0
Flow time = 0.009500000000000005s, time step = 19
3981 more time stepsUpdating solution at time levels N and N-1.
368 1.4704e-03 4.6680e-05 4.6204e-05 4.7720e-05 6.3313e-09 7.9789e-06 0:00:20 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 4 cells
369 3.5042e-03 1.2158e-03 1.1499e-03 1.6520e-02 3.9742e-04 2.1042e-02 0:00:23 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
370 2.7519e-03 4.1969e-04 3.9359e-04 4.8362e-03 8.6908e-05 5.3015e-03 0:00:21 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
371 2.1320e-03 1.8118e-04 1.6932e-04 1.3371e-03 1.9617e-05 1.2689e-03 0:00:19 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
372 1.8174e-03 1.2163e-04 1.1535e-04 3.9680e-04 4.6969e-06 3.3680e-04 0:00:18 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
373 1.6167e-03 9.9857e-05 9.5638e-05 1.5826e-04 1.2472e-06 1.0361e-04 0:00:13 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
374 1.4611e-03 8.6595e-05 8.3322e-05 1.0163e-04 3.9558e-07 4.1512e-05 0:00:13 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
375 1.3479e-03 7.7129e-05 7.4388e-05 8.5128e-05 1.6245e-07 2.3105e-05 0:00:12 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
376 1.2667e-03 7.0044e-05 6.7686e-05 7.6060e-05 8.7639e-08 1.6512e-05 0:00:11 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
377 1.2052e-03 6.4600e-05 6.2565e-05 6.9468e-05 5.6130e-08 1.3430e-05 0:00:10 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
378 1.1566e-03 6.0299e-05 5.8540e-05 6.4359e-05 4.0292e-08 1.1577e-05 0:00:10 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
379 1.1170e-03 5.6808e-05 5.5303e-05 6.0276e-05 3.0767e-08 1.0267e-05 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
380 1.0840e-03 5.3924e-05 5.2641e-05 5.6929e-05 2.4322e-08 9.2653e-06 0:00:08 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
381 1.0560e-03 5.1488e-05 5.0400e-05 5.4122e-05 1.9643e-08 8.4713e-06 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
382 1.0318e-03 4.9398e-05 4.8474e-05 5.1731e-05 1.6097e-08 7.8340e-06 0:00:06 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
383 1.0108e-03 4.7587e-05 4.6800e-05 4.9671e-05 1.3335e-08 7.3161e-06 0:00:05 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
384 9.9226e-04 4.5997e-05 4.5326e-05 4.7874e-05 1.1142e-08 6.8946e-06 0:00:04 4
! 384 solution is converged
Flow time = 0.01000000000000001s, time step = 20
3980 more time stepsUpdating solution at time levels N and N-1.
384 9.9226e-04 4.5997e-05 4.5326e-05 4.7874e-05 1.1142e-08 6.8946e-06 0:00:20 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
385 3.4427e-03 1.4866e-03 1.4037e-03 2.3729e-02 3.9704e-04 2.0391e-02 0:00:23 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 3 cells
386 2.5305e-03 5.3633e-04 5.0228e-04 7.2714e-03 8.6919e-05 5.1510e-03 0:00:21 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
387 1.8373e-03 2.3240e-04 2.1608e-04 2.0263e-03 1.9638e-05 1.2331e-03 0:00:19 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
388 1.4886e-03 1.5465e-04 1.4560e-04 5.9152e-04 4.7031e-06 3.2586e-04 0:00:18 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
389 1.2653e-03 1.2604e-04 1.1998e-04 2.2293e-04 1.2479e-06 9.8553e-05 0:00:16 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
390 1.0884e-03 1.0830e-04 1.0374e-04 1.3320e-04 3.9448e-07 3.8025e-05 0:00:12 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
391 9.5983e-04 9.5650e-05 9.1941e-05 1.0842e-04 1.6092e-07 2.0166e-05 0:00:12 13
! 391 solution is converged
Flow time = 0.01050000000000001s, time step = 21
3979 more time stepsUpdating solution at time levels N and N-1.
Time = 0.146 seconds.
Cell count 70910 70934 354592
Partition boundary cell count 1620 3018 10910
Partition boundary cell count ratio 2.3% 4.3% 3.1%Face count 146153 147650 728402
Mean face count deviation -0.5% 0.5%
Partition boundary face count 1781 3265 5933
Partition boundary face count ratio 1.2% 2.2% 0.8%Cell weights 7e+05 7e+05 4e+06
391 9.5983e-04 9.5650e-05 9.1941e-05 1.0842e-04 1.6092e-07 2.0166e-05 0:00:18 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
392 3.5282e-03 1.7329e-03 1.6238e-03 3.1225e-02 3.9661e-04 1.9808e-02 0:00:21 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
393 2.7477e-03 5.7653e-04 5.3641e-04 8.5621e-03 8.6905e-05 5.0729e-03 0:00:20 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
394 2.0698e-03 2.5289e-04 2.3518e-04 2.2232e-03 1.9647e-05 1.2092e-03 0:00:15 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
395 1.6793e-03 1.7866e-04 1.6895e-04 6.4271e-04 4.7024e-06 3.2066e-04 0:00:14 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
396 1.4290e-03 1.4938e-04 1.4245e-04 2.4416e-04 1.2426e-06 9.7470e-05 0:00:14 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
397 1.2345e-03 1.3039e-04 1.2492e-04 1.5390e-04 3.8876e-07 3.7833e-05 0:00:13 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
398 1.0934e-03 1.1657e-04 1.1204e-04 1.3106e-04 1.5587e-07 2.0238e-05 0:00:12 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
399 9.9386e-04 1.0611e-04 1.0226e-04 1.1783e-04 8.1788e-08 1.4012e-05 0:00:11 12
! 399 solution is converged
Flow time = 0.01100000000000001s, time step = 22
3978 more time stepsUpdating solution at time levels N and N-1.
399 9.9386e-04 1.0611e-04 1.0226e-04 1.1783e-04 8.1788e-08 1.4012e-05 0:00:19 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
400 3.6642e-03 1.5324e-03 1.4209e-03 3.1937e-02 3.9620e-04 1.9288e-02 0:00:18 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
401 3.1618e-03 4.2595e-04 3.9354e-04 7.0294e-03 8.6904e-05 4.9502e-03 0:00:18 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
402 2.5091e-03 1.9522e-04 1.8161e-04 1.7891e-03 1.9666e-05 1.1839e-03 0:00:17 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
403 2.1326e-03 1.4241e-04 1.3485e-04 5.1169e-04 4.7099e-06 3.1402e-04 0:00:16 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
404 1.8837e-03 1.2135e-04 1.1589e-04 1.9075e-04 1.2445e-06 9.4230e-05 0:00:15 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
405 1.6846e-03 1.0781e-04 1.0344e-04 1.2411e-04 3.8893e-07 3.5310e-05 0:00:14 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
406 1.5403e-03 9.7983e-05 9.4308e-05 1.0847e-04 1.5559e-07 1.7940e-05 0:00:13 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
407 1.4395e-03 9.0488e-05 8.7257e-05 9.9290e-05 8.1410e-08 1.1922e-05 0:00:12 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
408 1.3653e-03 8.4567e-05 8.1678e-05 9.2034e-05 5.2274e-08 9.2930e-06 0:00:09 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
409 1.3082e-03 7.9768e-05 7.7158e-05 8.6129e-05 3.6686e-08 7.8392e-06 0:00:08 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
410 1.2624e-03 7.5762e-05 7.3429e-05 8.1227e-05 2.7452e-08 6.8924e-06 0:00:08 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
411 1.2246e-03 7.2339e-05 7.0253e-05 7.7093e-05 2.1305e-08 6.2173e-06 0:00:07 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
412 1.1925e-03 6.9368e-05 6.7489e-05 7.3547e-05 1.6913e-08 5.7110e-06 0:00:06 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
413 1.1648e-03 6.6741e-05 6.5040e-05 7.0456e-05 1.3639e-08 5.3188e-06 0:00:06 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
414 1.1404e-03 6.4386e-05 6.2837e-05 6.7731e-05 1.1128e-08 5.0120e-06 0:00:05 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
415 1.1186e-03 6.2264e-05 6.0843e-05 6.5308e-05 9.1632e-09 4.7668e-06 0:00:04 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
416 1.0989e-03 6.0342e-05 5.9027e-05 6.3132e-05 7.6030e-09 4.5674e-06 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
417 1.0810e-03 5.8591e-05 5.7364e-05 6.1156e-05 6.3488e-09 4.4027e-06 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
418 1.0644e-03 5.6983e-05 5.5828e-05 5.9346e-05 5.3306e-09 4.2642e-06 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
419 1.0492e-03 5.5502e-05 5.4406e-05 5.7685e-05 4.4969e-09 4.1465e-06 0:00:00 0
Flow time = 0.01150000000000001s, time step = 23
3977 more time stepsUpdating solution at time levels N and N-1.
419 1.0492e-03 5.5502e-05 5.4406e-05 5.7685e-05 4.4969e-09 4.1465e-06 0:00:20 20turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
420 3.9989e-03 1.1525e-03 1.0582e-03 2.2943e-02 3.9581e-04 1.8459e-02 0:00:19 19turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
421 3.6649e-03 3.3694e-04 3.0809e-04 5.1351e-03 8.6912e-05 4.7955e-03 0:00:18 18turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
422 2.9733e-03 1.5998e-04 1.4737e-04 1.3304e-03 1.9693e-05 1.1361e-03 0:00:17 17turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
423 2.5584e-03 1.1534e-04 1.0851e-04 3.8688e-04 4.7232e-06 3.0067e-04 0:00:16 16turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
424 2.2816e-03 9.7253e-05 9.2676e-05 1.4614e-04 1.2509e-06 9.0954e-05 0:00:15 15turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
425 2.0609e-03 8.5701e-05 8.2237e-05 9.5524e-05 3.9261e-07 3.5011e-05 0:00:14 14turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
426 1.8985e-03 7.7217e-05 7.4421e-05 8.3130e-05 1.5814e-07 1.8519e-05 0:00:13 13turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
427 1.7825e-03 7.0703e-05 6.8376e-05 7.5680e-05 8.3338e-08 1.2701e-05 0:00:12 12turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
428 1.6953e-03 6.5554e-05 6.3574e-05 6.9752e-05 5.3778e-08 1.0027e-05 0:00:11 11turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
429 1.6267e-03 6.1394e-05 5.9692e-05 6.4916e-05 3.7825e-08 8.4236e-06 0:00:10 10turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
430 1.5708e-03 5.7962e-05 5.6508e-05 6.0937e-05 2.8317e-08 7.2949e-06 0:00:09 9turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
431 1.5242e-03 5.5093e-05 5.3844e-05 5.7640e-05 2.1960e-08 6.4363e-06 0:00:08 8turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
432 1.4847e-03 5.2666e-05 5.1588e-05 5.4865e-05 1.7408e-08 5.7600e-06 0:00:07 7turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
433 1.4506e-03 5.0583e-05 4.9657e-05 5.2505e-05 1.4010e-08 5.2194e-06 0:00:05 6turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
434 1.4208e-03 4.8788e-05 4.7981e-05 5.0486e-05 1.1403e-08 4.7884e-06 0:00:04 5turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
435 1.3944e-03 4.7230e-05 4.6520e-05 4.8738e-05 9.3637e-09 4.4379e-06 0:00:03 4turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
436 1.3709e-03 4.5859e-05 4.5237e-05 4.7216e-05 7.7458e-09 4.1580e-06 0:00:03 3turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
437 1.3498e-03 4.4652e-05 4.4102e-05 4.5880e-05 6.4471e-09 3.9330e-06 0:00:02 2turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
438 1.3307e-03 4.3579e-05 4.3090e-05 4.4696e-05 5.3945e-09 3.7521e-06 0:00:01 1turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 1 cells
439 1.3133e-03 4.2621e-05 4.2181e-05 4.3648e-05 4.5346e-09 3.6060e-06 0:00:00 0
Flow time = 0.01200000000000001s, time step = 24
3976 more time stepsUpdating solution at time levels N and N-1.
439 1.3133e-03 4.2621e-05 4.2181e-05 4.3648e-05 4.5346e-09 3.6060e-06 0:00:19 20
440 4.6688e-03 1.0487e-03 9.7967e-04 1.4980e-02 3.9540e-04 1.8125e-02 0:00:22 19
441 4.0842e-03 3.1476e-04 2.9234e-04 3.5340e-03 8.6909e-05 4.7863e-03 0:00:20 18
442 3.3074e-03 1.4469e-04 1.3425e-04 9.3510e-04 1.9711e-05 1.1344e-03 0:00:19 17
443 2.8606e-03 1.0298e-04 9.7306e-05 2.7967e-04 4.7310e-06 3.0048e-04 0:00:17 16
444 2.5632e-03 8.7347e-05 8.3708e-05 1.1385e-04 1.2531e-06 8.9432e-05 0:00:16 15
445 2.3252e-03 7.7834e-05 7.5211e-05 8.3835e-05 3.9291e-07 3.2803e-05 0:00:15 14
446 2.1505e-03 7.1032e-05 6.9007e-05 7.5542e-05 1.5788e-07 1.6175e-05 0:00:14 13
447 2.0259e-03 6.5914e-05 6.4277e-05 6.9738e-05 8.2899e-08 1.0429e-05 0:00:12 12
448 1.9325e-03 6.1953e-05 6.0613e-05 6.5105e-05 5.3270e-08 7.8966e-06 0:00:09 11
449 1.8593e-03 5.8822e-05 5.7709e-05 6.1409e-05 3.7291e-08 6.4733e-06 0:00:09 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
450 1.8002e-03 5.6285e-05 5.5345e-05 5.8423e-05 2.7780e-08 5.5404e-06 0:00:08 9
451 1.7514e-03 5.4178e-05 5.3385e-05 5.5960e-05 2.1438e-08 4.8778e-06 0:00:07 8
452 1.7102e-03 5.2386e-05 5.1729e-05 5.3895e-05 1.6910e-08 4.3987e-06 0:00:07 7
453 1.6746e-03 5.0832e-05 5.0292e-05 5.2144e-05 1.3543e-08 4.0346e-06 0:00:06 6
454 1.6435e-03 4.9465e-05 4.9029e-05 5.0630e-05 1.0970e-08 3.6351e-06 0:00:05 5
455 1.6162e-03 4.8252e-05 4.7905e-05 4.9301e-05 8.9656e-09 3.3881e-06 0:00:04 4
456 1.5917e-03 4.7167e-05 4.6898e-05 4.8129e-05 7.3818e-09 3.1921e-06 0:00:03 3
457 1.5697e-03 4.6194e-05 4.5990e-05 4.7088e-05 6.1158e-09 3.0331e-06 0:00:02 2
458 1.5499e-03 4.5318e-05 4.5167e-05 4.6156e-05 5.0939e-09 2.9010e-06 0:00:01 1
459 1.5317e-03 4.4522e-05 4.4419e-05 4.5314e-05 4.2624e-09 2.7889e-06 0:00:00 0
Flow time = 0.01250000000000001s, time step = 25
3975 more time stepsUpdating solution at time levels N and N-1.
459 1.5317e-03 4.4522e-05 4.4419e-05 4.5314e-05 4.2624e-09 2.7889e-06 0:00:20 20
460 4.9664e-03 8.5131e-04 7.9221e-04 8.4378e-03 3.9499e-04 1.7570e-02 0:00:19 19
461 4.3547e-03 2.7208e-04 2.5147e-04 2.1002e-03 8.6903e-05 4.6033e-03 0:00:18 18
462 3.5299e-03 1.3085e-04 1.2143e-04 5.7788e-04 1.9727e-05 1.0990e-03 0:00:17 17
463 3.0627e-03 9.6082e-05 9.1065e-05 1.8645e-04 4.7367e-06 2.9111e-04 0:00:16 16
464 2.7509e-03 8.2935e-05 7.9701e-05 9.3411e-05 1.2538e-06 8.6418e-05 0:00:15 15
465 2.4989e-03 7.4850e-05 7.2464e-05 7.8303e-05 3.9213e-07 3.1561e-05 0:00:14 14
466 2.3142e-03 6.8993e-05 6.7098e-05 7.1947e-05 1.5679e-07 1.5538e-05 0:00:13 13
467 2.1824e-03 6.4541e-05 6.3007e-05 6.7077e-05 8.1798e-08 1.0065e-05 0:00:12 12
468 2.0831e-03 6.1078e-05 5.9815e-05 6.3179e-05 5.2229e-08 7.7031e-06 0:00:11 11
469 2.0050e-03 5.8331e-05 5.7269e-05 6.0081e-05 3.6336e-08 6.3677e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
470 1.9418e-03 5.6081e-05 5.5183e-05 5.7591e-05 2.6912e-08 5.4820e-06 0:00:09 9
471 1.8895e-03 5.4196e-05 5.3426e-05 5.5529e-05 2.0652e-08 4.8448e-06 0:00:08 8
472 1.8454e-03 5.2581e-05 5.1910e-05 5.3787e-05 1.6203e-08 4.3849e-06 0:00:07 7
473 1.8076e-03 5.1177e-05 5.0590e-05 5.2290e-05 1.2908e-08 4.0339e-06 0:00:05 6
474 1.7749e-03 4.9940e-05 4.9423e-05 5.0976e-05 1.0401e-08 3.7606e-06 0:00:04 5
475 1.7464e-03 4.8835e-05 4.8382e-05 4.9807e-05 8.4577e-09 3.5435e-06 0:00:03 4
476 1.7211e-03 4.7838e-05 4.7447e-05 4.8756e-05 6.9287e-09 3.3692e-06 0:00:03 3
477 1.6984e-03 4.6936e-05 4.6599e-05 4.7807e-05 5.7119e-09 3.2285e-06 0:00:02 2
478 1.6778e-03 4.6114e-05 4.5824e-05 4.6945e-05 4.7342e-09 3.1112e-06 0:00:01 1
479 1.6590e-03 4.5359e-05 4.5110e-05 4.6157e-05 3.9421e-09 3.0125e-06 0:00:00 0
Flow time = 0.01300000000000001s, time step = 26
3974 more time stepsUpdating solution at time levels N and N-1.
>> Dividing domain into 5 partitions using Metis.
Time = 0.145 seconds.
Done.>> 5 Stored Partitions:
Collective Partition Statistics: Minimum Maximum Total
Cell count 71431 71614 357560
Mean cell count deviation -0.1% 0.1%
Partition boundary cell count 1666 2885 10820
Partition boundary cell count ratio 2.3% 4.0% 3.0%Face count 147304 149078 734338
Mean face count deviation -0.5% 0.7%
Partition boundary face count 1825 3109 5899
Partition boundary face count ratio 1.2% 2.1% 0.8%Cell weights 7e+05 7e+05 4e+06
Mean cell weight deviation -0.1% 0.1%Partition neighbor count 2 4
Partition Method Metis
Stored Partition Count 5
Done.Smoothing partition boundaries...done.
479 1.6590e-03 4.5359e-05 4.5110e-05 4.6157e-05 3.9421e-09 3.0125e-06 0:00:19 20
480 5.3406e-03 6.4482e-04 5.9071e-04 3.1603e-03 3.9459e-04 1.6985e-02 0:00:18 19
481 4.5556e-03 2.3104e-04 2.1186e-04 8.5735e-04 8.6894e-05 4.4686e-03 0:00:17 18
482 3.6972e-03 1.2263e-04 1.1388e-04 2.6952e-04 1.9742e-05 1.0606e-03 0:00:17 17
483 3.1807e-03 9.2918e-05 8.8256e-05 1.1496e-04 4.7417e-06 2.7982e-04 0:00:16 16
484 2.8410e-03 8.0583e-05 7.7615e-05 8.4264e-05 1.2541e-06 8.2444e-05 0:00:15 15
485 2.5765e-03 7.2707e-05 7.0532e-05 7.5256e-05 3.9104e-07 2.9621e-05 0:00:14 14
486 2.3831e-03 6.6835e-05 6.5137e-05 6.9206e-05 1.5546e-07 1.4205e-05 0:00:13 13
487 2.2415e-03 6.2282e-05 6.0916e-05 6.4391e-05 8.0514e-08 8.9173e-06 0:00:12 12
488 2.1325e-03 5.8678e-05 5.7577e-05 6.0495e-05 5.1046e-08 6.5879e-06 0:00:11 11
489 2.0456e-03 5.5786e-05 5.4873e-05 5.7357e-05 3.5279e-08 5.2760e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
490 1.9747e-03 5.3402e-05 5.2630e-05 5.4789e-05 2.5971e-08 4.4074e-06 0:00:09 9
491 1.9155e-03 5.1394e-05 5.0744e-05 5.2642e-05 1.9817e-08 3.7719e-06 0:00:06 8
492 1.8653e-03 4.9688e-05 4.9137e-05 5.0827e-05 1.5464e-08 3.3055e-06 0:00:06 7
493 1.8219e-03 4.8221e-05 4.7753e-05 4.9277e-05 1.2255e-08 2.9491e-06 0:00:05 6
494 1.7839e-03 4.6947e-05 4.6542e-05 4.7929e-05 9.8250e-09 2.6668e-06 0:00:04 5
495 1.7503e-03 4.5824e-05 4.5471e-05 4.6746e-05 7.9494e-09 2.4396e-06 0:00:04 4
496 1.7204e-03 4.4829e-05 4.4524e-05 4.5701e-05 6.4807e-09 2.2543e-06 0:00:03 3
497 1.6935e-03 4.3943e-05 4.3679e-05 4.4770e-05 5.3173e-09 2.1086e-06 0:00:02 2
498 1.6692e-03 4.3151e-05 4.2923e-05 4.3938e-05 4.3866e-09 1.9864e-06 0:00:01 1
499 1.6471e-03 4.2440e-05 4.2244e-05 4.3189e-05 3.6361e-09 1.8840e-06 0:00:00 0
Flow time = 0.01350000000000001s, time step = 27
3973 more time stepsUpdating solution at time levels N and N-1.
499 1.6471e-03 4.2440e-05 4.2244e-05 4.3189e-05 3.6361e-09 1.8840e-06 0:00:19 20
500 5.7401e-03 4.8259e-04 4.3856e-04 2.6686e-03 3.9419e-04 1.6516e-02 0:00:18 19
501 4.6858e-03 1.9828e-04 1.8133e-04 7.5732e-04 8.6883e-05 4.3962e-03 0:00:18 18
502 3.6775e-03 1.1404e-04 1.0557e-04 2.4543e-04 1.9755e-05 1.0413e-03 0:00:17 17
503 3.1257e-03 8.7561e-05 8.2730e-05 1.1396e-04 4.7461e-06 2.7474e-04 0:00:16 16
504 2.7713e-03 7.5865e-05 7.2643e-05 8.2214e-05 1.2541e-06 8.0849e-05 0:00:15 15
505 2.4870e-03 6.8429e-05 6.5986e-05 7.1861e-05 3.8983e-07 2.8964e-05 0:00:14 14
506 2.2766e-03 6.3035e-05 6.1030e-05 6.5778e-05 1.5407e-07 1.3826e-05 0:00:13 13
507 2.1235e-03 5.8910e-05 5.7222e-05 6.1232e-05 7.9204e-08 8.6684e-06 0:00:12 12
508 2.0072e-03 5.5674e-05 5.4255e-05 5.7644e-05 4.9858e-08 6.4176e-06 0:00:11 11
509 1.9154e-03 5.3071e-05 5.1886e-05 5.4783e-05 3.4231e-08 5.1291e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
510 1.8409e-03 5.0922e-05 4.9923e-05 5.2439e-05 2.5048e-08 4.2592e-06 0:00:09 9
511 1.7792e-03 4.9104e-05 4.8267e-05 5.0476e-05 1.9006e-08 3.6479e-06 0:00:08 8
512 1.7276e-03 4.7535e-05 4.6836e-05 4.8793e-05 1.4751e-08 3.2062e-06 0:00:07 7
513 1.6836e-03 4.6162e-05 4.5583e-05 4.7327e-05 1.1629e-08 2.8598e-06 0:00:06 6
514 1.6455e-03 4.4943e-05 4.4469e-05 4.6038e-05 9.2750e-09 2.5725e-06 0:00:05 5
515 1.6120e-03 4.3853e-05 4.3466e-05 4.4888e-05 7.4667e-09 2.3537e-06 0:00:04 4
516 1.5824e-03 4.2871e-05 4.2555e-05 4.3856e-05 6.0568e-09 2.2081e-06 0:00:02 3
517 1.5561e-03 4.1979e-05 4.1722e-05 4.2918e-05 4.9449e-09 2.0845e-06 0:00:02 2
518 1.5323e-03 4.1164e-05 4.0958e-05 4.2060e-05 4.0595e-09 1.9751e-06 0:00:01 1
519 1.5107e-03 4.0414e-05 4.0251e-05 4.1277e-05 3.3485e-09 1.8776e-06 0:00:00 0
Flow time = 0.01400000000000001s, time step = 28
3972 more time stepsUpdating solution at time levels N and N-1.
519 1.5107e-03 4.0414e-05 4.0251e-05 4.1277e-05 3.3485e-09 1.8776e-06 0:00:18 20
520 5.7172e-03 6.0355e-04 5.4622e-04 7.2305e-03 3.9380e-04 1.6064e-02 0:00:21 19
521 4.5348e-03 2.3207e-04 2.1051e-04 1.9997e-03 8.6872e-05 4.2676e-03 0:00:20 18
522 3.4323e-03 1.2408e-04 1.1398e-04 5.7242e-04 1.9767e-05 1.0118e-03 0:00:18 17
523 2.8290e-03 9.2605e-05 8.7169e-05 1.9189e-04 4.7502e-06 2.6746e-04 0:00:17 16
524 2.4433e-03 7.8525e-05 7.4942e-05 9.6251e-05 1.2540e-06 7.8744e-05 0:00:16 15
525 2.1409e-03 6.9354e-05 6.6609e-05 7.5223e-05 3.8860e-07 2.8182e-05 0:00:15 14
526 1.9202e-03 6.2580e-05 6.0323e-05 6.6501e-05 1.5269e-07 1.3428e-05 0:00:11 13
527 1.7646e-03 5.7342e-05 5.5436e-05 6.0439e-05 7.7922e-08 8.3690e-06 0:00:10 12
528 1.6492e-03 5.3194e-05 5.1573e-05 5.5710e-05 4.8706e-08 6.1607e-06 0:00:10 11
529 1.5601e-03 4.9845e-05 4.8456e-05 5.1938e-05 3.3223e-08 4.9340e-06 0:00:09 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
530 1.4893e-03 4.7065e-05 4.5876e-05 4.8848e-05 2.4169e-08 4.1335e-06 0:00:08 9
531 1.4319e-03 4.4728e-05 4.3703e-05 4.6276e-05 1.8238e-08 3.5605e-06 0:00:08 8
532 1.3844e-03 4.2743e-05 4.1849e-05 4.4104e-05 1.4081e-08 3.1241e-06 0:00:07 7
533 1.3442e-03 4.1028e-05 4.0245e-05 4.2239e-05 1.1044e-08 2.7964e-06 0:00:06 6
534 1.3099e-03 3.9532e-05 3.8845e-05 4.0623e-05 8.7654e-09 2.5428e-06 0:00:05 5
535 1.2804e-03 3.8216e-05 3.7614e-05 3.9214e-05 7.0223e-09 2.3403e-06 0:00:04 4
536 1.2546e-03 3.7046e-05 3.6526e-05 3.7974e-05 5.6694e-09 2.1789e-06 0:00:03 3
537 1.2317e-03 3.6012e-05 3.5558e-05 3.6873e-05 4.6071e-09 2.0518e-06 0:00:02 2
538 1.2115e-03 3.5092e-05 3.4695e-05 3.5896e-05 3.7648e-09 1.9462e-06 0:00:01 1
539 1.1935e-03 3.4270e-05 3.3922e-05 3.5023e-05 3.0915e-09 1.8576e-06 0:00:00 0
Flow time = 0.01450000000000001s, time step = 29
3971 more time stepsUpdating solution at time levels N and N-1.
539 1.1935e-03 3.4270e-05 3.3922e-05 3.5023e-05 3.0915e-09 1.8576e-06 0:00:20 20
540 5.5545e-03 7.9779e-04 7.2700e-04 1.1528e-02 3.9341e-04 1.5675e-02 0:00:23 19
541 4.2910e-03 2.8741e-04 2.6174e-04 3.2348e-03 8.6859e-05 4.2217e-03 0:00:17 18
542 3.1655e-03 1.3695e-04 1.2560e-04 9.0094e-04 1.9778e-05 9.9720e-04 0:00:16 17
543 2.5555e-03 9.5376e-05 8.9303e-05 2.7785e-04 4.7539e-06 2.6464e-04 0:00:16 16
544 2.1640e-03 7.7877e-05 7.3761e-05 1.1437e-04 1.2538e-06 7.8472e-05 0:00:15 15
545 1.8586e-03 6.6737e-05 6.3580e-05 7.6307e-05 3.8737e-07 2.8241e-05 0:00:14 14
546 1.6379e-03 5.8736e-05 5.6179e-05 6.4332e-05 1.5135e-07 1.3466e-05 0:00:13 13
547 1.4826e-03 5.2756e-05 5.0640e-05 5.7059e-05 7.6687e-08 8.3924e-06 0:00:12 12
548 1.3669e-03 4.8215e-05 4.6440e-05 5.1677e-05 4.7606e-08 6.1700e-06 0:00:11 11
549 1.2777e-03 4.4705e-05 4.3187e-05 4.7555e-05 3.2269e-08 4.9010e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
550 1.2070e-03 4.1919e-05 4.0612e-05 4.4317e-05 2.3341e-08 4.0297e-06 0:00:09 9
551 1.1499e-03 3.9667e-05 3.8532e-05 4.1705e-05 1.7520e-08 3.3980e-06 0:00:08 8
552 1.1028e-03 3.7812e-05 3.6829e-05 3.9570e-05 1.3458e-08 2.9367e-06 0:00:07 7
553 1.0633e-03 3.6262e-05 3.5407e-05 3.7796e-05 1.0504e-08 2.5962e-06 0:00:06 6
554 1.0297e-03 3.4951e-05 3.4202e-05 3.6305e-05 8.2968e-09 2.3350e-06 0:00:05 5
555 1.0007e-03 3.3819e-05 3.3161e-05 3.5038e-05 6.6159e-09 2.1355e-06 0:00:04 4
556 9.7525e-04 3.2835e-05 3.2254e-05 3.3944e-05 5.3170e-09 1.9741e-06 0:00:03 3
! 556 solution is converged
Flow time = 0.01500000000000001s, time step = 30
3970 more time stepsUpdating solution at time levels N and N-1.
556 9.7525e-04 3.2835e-05 3.2254e-05 3.3944e-05 5.3170e-09 1.9741e-06 0:00:20 20
557 5.6758e-03 9.5324e-04 8.6983e-04 1.5251e-02 3.9303e-04 1.5386e-02 0:00:23 19
558 4.2305e-03 3.4562e-04 3.1565e-04 4.3790e-03 8.6846e-05 4.2115e-03 0:00:21 18
559 2.9854e-03 1.6098e-04 1.4809e-04 1.2189e-03 1.9789e-05 9.9524e-04 0:00:19 17
560 2.3266e-03 1.1059e-04 1.0359e-04 3.7119e-04 4.7569e-06 2.6525e-04 0:00:18 16
561 1.9127e-03 8.9566e-05 8.4759e-05 1.4771e-04 1.2532e-06 7.8250e-05 0:00:16 15
562 1.5868e-03 7.6032e-05 7.2276e-05 9.1430e-05 3.8590e-07 2.7603e-05 0:00:15 14
563 1.3501e-03 6.6276e-05 6.3145e-05 7.4220e-05 1.4984e-07 1.2736e-05 0:00:14 13
564 1.1826e-03 5.8910e-05 5.6253e-05 6.4846e-05 7.5330e-08 7.6672e-06 0:00:13 12
565 1.0583e-03 5.3176e-05 5.0898e-05 5.7914e-05 4.6415e-08 5.4623e-06 0:00:11 11
566 9.6284e-04 4.8595e-05 4.6619e-05 5.2473e-05 3.1252e-08 4.2320e-06 0:00:10 10
! 566 solution is converged
Flow time = 0.01550000000000001s, time step = 31
3969 more time stepsUpdating solution at time levels N and N-1.
Cell count 71706 72934 363362
Mean cell count deviation -1.3% 0.4%
Partition boundary cell count 1847 2918 11490
Partition boundary cell count ratio 2.6% 4.0% 3.2%Face count 147967 151627 745942
Mean face count deviation -1.7% 0.8%
Partition boundary face count 2067 3173 6331
Partition boundary face count ratio 1.4% 2.1% 0.8%Cell weights 7e+05 7e+05 4e+06
Mean cell weight deviation -1.3% 0.4%Partition neighbor count 3 4
566 9.6284e-04 4.8595e-05 4.6619e-05 5.2473e-05 3.1252e-08 4.2320e-06 0:00:21 20
567 5.7253e-03 1.1674e-03 1.0674e-03 1.8367e-02 3.9266e-04 1.5036e-02 0:00:19 19
568 4.1442e-03 4.1127e-04 3.7420e-04 5.1615e-03 8.6829e-05 4.1313e-03 0:00:18 18
569 2.9325e-03 1.8778e-04 1.7137e-04 1.3929e-03 1.9795e-05 9.7147e-04 0:00:17 17
570 2.2682e-03 1.2975e-04 1.2055e-04 4.2207e-04 4.7574e-06 2.5954e-04 0:00:16 16
571 1.8483e-03 1.0642e-04 1.0000e-04 1.6993e-04 1.2509e-06 7.7456e-05 0:00:15 15
572 1.5242e-03 9.1519e-05 8.6586e-05 1.0803e-04 3.8309e-07 2.8184e-05 0:00:14 14
573 1.2952e-03 8.0741e-05 7.6776e-05 9.0438e-05 1.4731e-07 1.3755e-05 0:00:13 13
574 1.1375e-03 7.2645e-05 6.9336e-05 8.0547e-05 7.3182e-08 8.8473e-06 0:00:12 12
575 1.0215e-03 6.6368e-05 6.3544e-05 7.2948e-05 4.4606e-08 6.7533e-06 0:00:11 11
576 9.3234e-04 6.1369e-05 5.8948e-05 6.6871e-05 2.9767e-08 5.6057e-06 0:00:10 10
! 576 solution is converged
Flow time = 0.01600000000000001s, time step = 32
3968 more time stepsUpdating solution at time levels N and N-1.
576 9.3234e-04 6.1369e-05 5.8948e-05 6.6871e-05 2.9767e-08 5.6057e-06 0:00:20 20
577 5.8717e-03 1.3335e-03 1.2274e-03 1.9714e-02 3.9230e-04 1.4454e-02 0:00:23 19
578 4.5413e-03 4.0240e-04 3.6781e-04 4.6964e-03 8.6816e-05 3.9682e-03 0:00:21 18
579 3.2425e-03 1.8163e-04 1.6618e-04 1.2448e-03 1.9804e-05 9.4136e-04 0:00:19 17
580 2.5346e-03 1.2615e-04 1.1756e-04 3.7988e-04 4.7600e-06 2.5278e-04 0:00:18 16
581 2.0889e-03 1.0388e-04 9.8052e-05 1.5610e-04 1.2503e-06 7.6266e-05 0:00:16 15
582 1.7408e-03 8.9591e-05 8.5251e-05 1.0268e-04 3.8184e-07 2.8369e-05 0:00:15 14
583 1.4905e-03 7.9060e-05 7.5766e-05 8.7252e-05 1.4608e-07 1.4262e-05 0:00:14 13
584 1.3175e-03 7.0990e-05 6.8441e-05 7.7732e-05 7.2114e-08 9.4325e-06 0:00:13 12
585 1.1919e-03 6.4616e-05 6.2636e-05 7.0171e-05 4.3700e-08 7.3556e-06 0:00:11 11
586 1.0958e-03 5.9491e-05 5.7922e-05 6.4060e-05 2.9015e-08 6.2162e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
587 1.0196e-03 5.5282e-05 5.4004e-05 5.9058e-05 2.0618e-08 5.4881e-06 0:00:09 9
588 9.5736e-04 5.1752e-05 5.0694e-05 5.4894e-05 1.5232e-08 4.9801e-06 0:00:08 8
! 588 solution is converged
Flow time = 0.01650000000000001s, time step = 33
3967 more time stepsUpdating solution at time levels N and N-1.
588 9.5736e-04 5.1752e-05 5.0694e-05 5.4894e-05 1.5232e-08 4.9801e-06 0:00:20 20
589 6.1257e-03 1.1727e-03 1.0878e-03 1.6549e-02 3.9196e-04 1.4202e-02 0:00:23 19
590 4.9233e-03 3.4748e-04 3.2138e-04 3.9196e-03 8.6807e-05 3.9299e-03 0:00:21 18
591 3.6409e-03 1.5444e-04 1.4325e-04 1.0418e-03 1.9815e-05 9.2779e-04 0:00:19 17
592 2.9204e-03 1.0578e-04 9.9695e-05 3.1582e-04 4.7641e-06 2.4865e-04 0:00:18 16
593 2.4584e-03 8.7175e-05 8.3146e-05 1.2813e-04 1.2510e-06 7.4368e-05 0:00:16 15
594 2.0941e-03 7.5761e-05 7.2746e-05 8.5657e-05 3.8156e-07 2.7071e-05 0:00:15 14
595 1.8293e-03 6.7576e-05 6.5226e-05 7.3661e-05 1.4562e-07 1.3115e-05 0:00:11 13
596 1.6426e-03 6.1423e-05 5.9557e-05 6.6348e-05 7.1672e-08 8.3170e-06 0:00:11 12
597 1.5046e-03 5.6717e-05 5.5189e-05 6.0679e-05 4.3299e-08 6.2371e-06 0:00:10 11
598 1.3988e-03 5.2969e-05 5.1720e-05 5.6152e-05 2.8662e-08 5.0899e-06 0:00:09 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
599 1.3154e-03 4.9907e-05 4.8887e-05 5.2527e-05 2.0306e-08 4.3419e-06 0:00:08 9
600 1.2480e-03 4.7346e-05 4.6522e-05 4.9549e-05 1.4959e-08 3.8137e-06 0:00:08 8
601 1.1921e-03 4.5164e-05 4.4512e-05 4.7048e-05 1.1291e-08 3.4237e-06 0:00:07 7
602 1.1456e-03 4.3278e-05 4.2760e-05 4.4914e-05 8.6666e-09 3.1297e-06 0:00:06 6
603 1.1058e-03 4.1621e-05 4.1210e-05 4.3077e-05 6.7358e-09 2.9022e-06 0:00:05 5
604 1.0714e-03 4.0144e-05 3.9825e-05 4.1452e-05 5.2876e-09 2.7196e-06 0:00:04 4
605 1.0414e-03 3.8808e-05 3.8570e-05 4.0009e-05 4.1851e-09 2.5741e-06 0:00:03 3
606 1.0149e-03 3.7603e-05 3.7428e-05 3.8720e-05 3.3356e-09 2.4555e-06 0:00:02 2
607 9.9133e-04 3.6500e-05 3.6381e-05 3.7538e-05 2.6744e-09 2.3572e-06 0:00:01 1
! 607 solution is converged
Flow time = 0.01700000000000001s, time step = 34
3966 more time stepsUpdating solution at time levels N and N-1.
607 9.9133e-04 3.6500e-05 3.6381e-05 3.7538e-05 2.6744e-09 2.3572e-06 0:00:20 20
608 6.5977e-03 9.2902e-04 8.6768e-04 1.2429e-02 3.9164e-04 1.3831e-02 0:00:23 19
609 5.3372e-03 2.8833e-04 2.6680e-04 3.0251e-03 8.6800e-05 3.8219e-03 0:00:21 18
610 3.9970e-03 1.3252e-04 1.2259e-04 8.1576e-04 1.9826e-05 9.0701e-04 0:00:19 17
611 3.2478e-03 9.2811e-05 8.7361e-05 2.5175e-04 4.7685e-06 2.4422e-04 0:00:18 16
612 2.7625e-03 7.7542e-05 7.4042e-05 1.0630e-04 1.2520e-06 7.4269e-05 0:00:16 15
613 2.3811e-03 6.8154e-05 6.5584e-05 7.5014e-05 3.8153e-07 2.8118e-05 0:00:15 14
614 2.1064e-03 6.1381e-05 5.9367e-05 6.5924e-05 1.4538e-07 1.4507e-05 0:00:14 13
615 1.9144e-03 5.6269e-05 5.4649e-05 6.0055e-05 7.1396e-08 9.8026e-06 0:00:12 12
616 1.7730e-03 5.2315e-05 5.0996e-05 5.5420e-05 4.3031e-08 7.7190e-06 0:00:11 11
617 1.6645e-03 4.9197e-05 4.8097e-05 5.1756e-05 2.8412e-08 6.5604e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
618 1.5786e-03 4.6657e-05 4.5725e-05 4.8818e-05 2.0077e-08 5.8022e-06 0:00:09 9
619 1.5092e-03 4.4547e-05 4.3734e-05 4.6411e-05 1.4749e-08 5.2678e-06 0:00:08 8
620 1.4524e-03 4.2759e-05 4.2030e-05 4.4393e-05 1.1102e-08 4.8949e-06 0:00:08 7
621 1.4046e-03 4.1217e-05 4.0564e-05 4.2677e-05 8.4976e-09 4.6161e-06 0:00:07 6
622 1.3638e-03 3.9864e-05 3.9288e-05 4.1195e-05 6.5859e-09 4.4041e-06 0:00:06 5
623 1.3286e-03 3.8660e-05 3.8151e-05 3.9885e-05 5.1551e-09 4.2258e-06 0:00:04 4
624 1.2979e-03 3.7583e-05 3.7135e-05 3.8720e-05 4.0683e-09 4.0818e-06 0:00:03 3
625 1.2706e-03 3.6614e-05 3.6222e-05 3.7678e-05 3.2328e-09 3.9642e-06 0:00:02 2
626 1.2460e-03 3.5732e-05 3.5396e-05 3.6734e-05 2.5843e-09 3.8669e-06 0:00:01 1
627 1.2238e-03 3.4934e-05 3.4644e-05 3.5873e-05 2.0764e-09 3.7860e-06 0:00:00 0
Flow time = 0.01750000000000001s, time step = 35
3965 more time stepsUpdating solution at time levels N and N-1.
627 1.2238e-03 3.4934e-05 3.4644e-05 3.5873e-05 2.0764e-09 3.7860e-06 0:00:21 20
628 7.0294e-03 7.2056e-04 6.7065e-04 8.3058e-03 3.9132e-04 1.3584e-02 0:00:20 19
629 5.7576e-03 2.4383e-04 2.2445e-04 2.0895e-03 8.6791e-05 3.7587e-03 0:00:19 18
630 4.3093e-03 1.2170e-04 1.1223e-04 5.8222e-04 1.9835e-05 8.9368e-04 0:00:21 17
631 3.5085e-03 8.9289e-05 8.3825e-05 1.9131e-04 4.7715e-06 2.4076e-04 0:00:19 16
632 2.9994e-03 7.5338e-05 7.1638e-05 9.1277e-05 1.2519e-06 7.2129e-05 0:00:17 15
633 2.6003e-03 6.6355e-05 6.3518e-05 7.1041e-05 3.8066e-07 2.6014e-05 0:00:16 14
634 2.3091e-03 5.9827e-05 5.7463e-05 6.3428e-05 1.4445e-07 1.2314e-05 0:00:14 13
635 2.1023e-03 5.4861e-05 5.2837e-05 5.7827e-05 7.0567e-08 7.5813e-06 0:00:13 12
636 1.9503e-03 5.0969e-05 4.9235e-05 5.3341e-05 4.2310e-08 5.5081e-06 0:00:12 11
637 1.8329e-03 4.7865e-05 4.6372e-05 4.9767e-05 2.7802e-08 4.3525e-06 0:00:10 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
638 1.7394e-03 4.5345e-05 4.4043e-05 4.6886e-05 1.9559e-08 3.6002e-06 0:00:09 9
639 1.6637e-03 4.3251e-05 4.2109e-05 4.4533e-05 1.4309e-08 3.0696e-06 0:00:08 8
640 1.6008e-03 4.1477e-05 4.0475e-05 4.2571e-05 1.0728e-08 2.6766e-06 0:00:07 7
641 1.5477e-03 3.9958e-05 3.9071e-05 4.0910e-05 8.1802e-09 2.3794e-06 0:00:07 6
642 1.5019e-03 3.8635e-05 3.7842e-05 3.9479e-05 6.3165e-09 2.1474e-06 0:00:06 5
643 1.4621e-03 3.7479e-05 3.6761e-05 3.8239e-05 4.9266e-09 1.9648e-06 0:00:05 4
644 1.4272e-03 3.6455e-05 3.5798e-05 3.7147e-05 3.8746e-09 1.8189e-06 0:00:03 3
645 1.3960e-03 3.5537e-05 3.4938e-05 3.6177e-05 3.0685e-09 1.7059e-06 0:00:02 2
646 1.3680e-03 3.4706e-05 3.4161e-05 3.5311e-05 2.4450e-09 1.6133e-06 0:00:01 1
647 1.3430e-03 3.3956e-05 3.3457e-05 3.4527e-05 1.9585e-09 1.5352e-06 0:00:00 0
Flow time = 0.01800000000000001s, time step = 36
3964 more time stepsUpdating solution at time levels N and N-1.
Time = 0.153 seconds.
Cell count 73723 75058 373942
Mean cell count deviation -1.4% 0.4%
Partition boundary cell count 1815 3106 12076
Partition boundary cell count ratio 2.4% 4.1% 3.2%Face count 152300 155973 767102
Mean face count deviation -1.6% 0.8%
Partition boundary face count 1994 3430 6705
Partition boundary face count ratio 1.3% 2.2% 0.9%Cell weights 7e+05 8e+05 4e+06
Mean cell weight deviation -1.4% 0.4%Partition neighbor count 2 4
647 1.3430e-03 3.3956e-05 3.3457e-05 3.4527e-05 1.9585e-09 1.5352e-06 0:00:21 20
648 7.6214e-03 6.1513e-04 5.5250e-04 4.5107e-03 3.9102e-04 1.3131e-02 0:00:20 19
649 5.9569e-03 2.1752e-04 1.9552e-04 1.1918e-03 8.6784e-05 3.6816e-03 0:00:19 18
650 4.4940e-03 1.1376e-04 1.0356e-04 3.5655e-04 1.9844e-05 8.6555e-04 0:00:18 17
651 3.6489e-03 8.4772e-05 7.8925e-05 1.3494e-04 4.7737e-06 2.3167e-04 0:00:16 16
652 3.1061e-03 7.1977e-05 6.8009e-05 7.9793e-05 1.2513e-06 6.9255e-05 0:00:18 15
653 2.6918e-03 6.3773e-05 6.0737e-05 6.7745e-05 3.7942e-07 2.5220e-05 0:00:16 14
654 2.3937e-03 5.7899e-05 5.5443e-05 6.1293e-05 1.4324e-07 1.2181e-05 0:00:15 13
655 2.1829e-03 5.3517e-05 5.1448e-05 5.6301e-05 6.9518e-08 7.6159e-06 0:00:13 12
656 2.0265e-03 5.0117e-05 4.8344e-05 5.2330e-05 4.1414e-08 5.5731e-06 0:00:12 11
657 1.9061e-03 4.7407e-05 4.5879e-05 4.9186e-05 2.7058e-08 4.4085e-06 0:00:11 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
658 1.8110e-03 4.5192e-05 4.3841e-05 4.6666e-05 1.8939e-08 3.6414e-06 0:00:10 9
659 1.7345e-03 4.3324e-05 4.2116e-05 4.4587e-05 1.3791e-08 3.0965e-06 0:00:08 8
660 1.6719e-03 4.1716e-05 4.0639e-05 4.2828e-05 1.0294e-08 2.6910e-06 0:00:07 7
661 1.6197e-03 4.0311e-05 3.9350e-05 4.1311e-05 7.8163e-09 2.3903e-06 0:00:06 6
662 1.5753e-03 3.9077e-05 3.8205e-05 3.9989e-05 6.0106e-09 2.1502e-06 0:00:06 5
663 1.5370e-03 3.7985e-05 3.7183e-05 3.8824e-05 4.6690e-09 1.9550e-06 0:00:05 4
664 1.5036e-03 3.7013e-05 3.6266e-05 3.7788e-05 3.6573e-09 1.7981e-06 0:00:03 3
665 1.4742e-03 3.6134e-05 3.5435e-05 3.6858e-05 2.8851e-09 1.6707e-06 0:00:02 2
666 1.4480e-03 3.5332e-05 3.4685e-05 3.6014e-05 2.2899e-09 1.5660e-06 0:00:01 1
667 1.4246e-03 3.4600e-05 3.4000e-05 3.5248e-05 1.8272e-09 1.4787e-06 0:00:00 0
Flow time = 0.01850000000000001s, time step = 37
3963 more time stepsUpdating solution at time levels N and N-1.
667 1.4246e-03 3.4600e-05 3.4000e-05 3.5248e-05 1.8272e-09 1.4787e-06 0:00:21 20
668 7.9654e-03 5.3861e-04 4.9478e-04 2.1999e-03 3.9074e-04 1.2940e-02 0:00:24 19
669 6.2791e-03 2.1136e-04 1.9402e-04 6.3980e-04 8.6777e-05 3.8560e-03 0:00:22 18
670 4.6809e-03 1.1673e-04 1.0686e-04 2.2148e-04 1.9852e-05 9.1722e-04 0:00:20 17
671 3.8071e-03 8.7950e-05 8.2134e-05 1.0819e-04 4.7757e-06 2.4521e-04 0:00:18 16
672 3.2586e-03 7.4151e-05 7.0211e-05 7.9633e-05 1.2506e-06 7.2712e-05 0:00:17 15
673 2.8323e-03 6.5074e-05 6.1966e-05 6.8643e-05 3.7816e-07 2.6206e-05 0:00:15 14
674 2.5213e-03 5.8501e-05 5.5861e-05 6.1419e-05 1.4204e-07 1.2593e-05 0:00:14 13
675 2.2968e-03 5.3548e-05 5.1294e-05 5.5857e-05 6.8488e-08 7.8782e-06 0:00:15 12
676 2.1275e-03 4.9703e-05 4.7766e-05 5.1511e-05 4.0546e-08 5.9202e-06 0:00:13 11
677 1.9950e-03 4.6635e-05 4.4953e-05 4.8069e-05 2.6344e-08 4.7328e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
678 1.8881e-03 4.4123e-05 4.2662e-05 4.5275e-05 1.8350e-08 3.9627e-06 0:00:10 9
679 1.7997e-03 4.2040e-05 4.0755e-05 4.2992e-05 1.3304e-08 3.4090e-06 0:00:09 8
680 1.7258e-03 4.0292e-05 3.9142e-05 4.1105e-05 9.8898e-09 3.0348e-06 0:00:08 7
681 1.6633e-03 3.8799e-05 3.7766e-05 3.9526e-05 7.4802e-09 2.7074e-06 0:00:06 6
682 1.6095e-03 3.7508e-05 3.6578e-05 3.8179e-05 5.7311e-09 2.4822e-06 0:00:05 5
683 1.5628e-03 3.6384e-05 3.5541e-05 3.7012e-05 4.4364e-09 2.3181e-06 0:00:04 4
684 1.5216e-03 3.5395e-05 3.4628e-05 3.5988e-05 3.4636e-09 2.1998e-06 0:00:03 3
685 1.4851e-03 3.4519e-05 3.3813e-05 3.5081e-05 2.7238e-09 2.0340e-06 0:00:02 2
686 1.4526e-03 3.3732e-05 3.3083e-05 3.4272e-05 2.1556e-09 1.9335e-06 0:00:01 1
687 1.4235e-03 3.3025e-05 3.2428e-05 3.3547e-05 1.7153e-09 1.8339e-06 0:00:00 0
Flow time = 0.01900000000000001s, time step = 38
3962 more time stepsUpdating solution at time levels N and N-1.
687 1.4235e-03 3.3025e-05 3.2428e-05 3.3547e-05 1.7153e-09 1.8339e-06 0:00:24 20
688 8.3116e-03 5.3236e-04 4.9937e-04 3.3020e-03 3.9047e-04 1.2700e-02 0:00:25 19
689 6.4507e-03 2.2501e-04 2.1097e-04 9.4916e-04 8.6772e-05 3.5852e-03 0:00:23 18
690 4.6725e-03 1.2626e-04 1.1697e-04 3.0865e-04 1.9860e-05 8.5006e-04 0:00:21 17
691 3.7161e-03 9.4458e-05 8.8703e-05 1.3515e-04 4.7776e-06 2.2984e-04 0:00:19 16
692 3.1279e-03 7.8059e-05 7.4474e-05 8.7811e-05 1.2498e-06 6.9082e-05 0:00:17 15
693 2.6815e-03 6.6956e-05 6.4403e-05 7.1842e-05 3.7689e-07 2.4960e-05 0:00:16 14
694 2.3601e-03 5.9188e-05 5.7064e-05 6.2818e-05 1.4086e-07 1.1833e-05 0:00:14 13
695 2.1324e-03 5.3532e-05 5.1723e-05 5.6357e-05 6.7491e-08 7.2675e-06 0:00:15 12
696 1.9624e-03 4.9302e-05 4.7714e-05 5.1478e-05 3.9717e-08 5.2544e-06 0:00:13 11
697 1.8312e-03 4.5983e-05 4.4609e-05 4.7720e-05 2.5672e-08 4.1255e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
698 1.7275e-03 4.3334e-05 4.2145e-05 4.4783e-05 1.7802e-08 3.3862e-06 0:00:10 9
699 1.6435e-03 4.1101e-05 4.0061e-05 4.2398e-05 1.2854e-08 2.8639e-06 0:00:09 8
700 1.5740e-03 3.9160e-05 3.8337e-05 4.0336e-05 9.5198e-09 2.4796e-06 0:00:08 7
701 1.5150e-03 3.7589e-05 3.6857e-05 3.8665e-05 7.1746e-09 2.1845e-06 0:00:08 6
702 1.4647e-03 3.6188e-05 3.5557e-05 3.7214e-05 5.4782e-09 1.9525e-06 0:00:06 5
703 1.4208e-03 3.4959e-05 3.4432e-05 3.5928e-05 4.2265e-09 1.7801e-06 0:00:05 4
704 1.3823e-03 3.3882e-05 3.3412e-05 3.4805e-05 3.2890e-09 1.6400e-06 0:00:03 3
705 1.3482e-03 3.2908e-05 3.2514e-05 3.3796e-05 2.5778e-09 1.5236e-06 0:00:02 2
706 1.3178e-03 3.2001e-05 3.1694e-05 3.2832e-05 2.0336e-09 1.4267e-06 0:00:01 1
707 1.2902e-03 3.1255e-05 3.0940e-05 3.2075e-05 1.6130e-09 1.3451e-06 0:00:00 0
Flow time = 0.01950000000000001s, time step = 39
3961 more time stepsUpdating solution at time levels N and N-1.
707 1.2902e-03 3.1255e-05 3.0940e-05 3.2075e-05 1.6130e-09 1.3451e-06 0:00:21 20
708 8.5655e-03 5.9899e-04 5.3648e-04 6.3115e-03 3.9020e-04 1.2942e-02 0:00:20 19
709 6.4838e-03 2.4995e-04 2.2740e-04 1.7667e-03 8.6767e-05 5.0121e-02 0:00:22 18
710 4.5591e-03 1.3354e-04 1.2300e-04 5.2621e-04 1.9868e-05 1.8696e-02 0:00:20 17
711 3.5749e-03 9.8240e-05 9.3071e-05 1.9208e-04 4.7794e-06 6.5760e-03 0:00:19 16
712 2.9669e-03 8.0743e-05 7.7413e-05 1.0075e-04 1.2491e-06 2.1587e-03 0:00:17 15
713 2.4935e-03 6.8833e-05 6.6341e-05 7.6725e-05 3.7568e-07 6.4143e-04 0:00:15 14
714 2.1538e-03 6.0358e-05 5.8274e-05 6.5823e-05 1.3975e-07 1.7369e-04 0:00:17 13
715 1.9157e-03 5.4131e-05 5.2308e-05 5.8278e-05 6.6559e-08 5.0686e-05 0:00:15 12
716 1.7403e-03 4.9410e-05 4.7769e-05 5.2551e-05 3.8946e-08 1.9570e-05 0:00:13 11
717 1.6060e-03 4.5686e-05 4.4215e-05 4.8144e-05 2.5959e-08 1.4623e-05 0:00:11 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
718 1.5007e-03 4.2650e-05 4.1336e-05 4.4617e-05 1.7934e-08 1.1433e-05 0:00:10 9
719 1.4171e-03 4.0124e-05 3.8936e-05 4.1742e-05 1.2898e-08 9.9355e-06 0:00:09 8
720 1.3483e-03 3.7987e-05 3.6900e-05 3.9364e-05 9.5136e-09 1.0464e-05 0:00:08 7
721 1.2908e-03 3.6156e-05 3.5153e-05 3.7343e-05 7.1418e-09 1.0771e-05 0:00:08 6
722 1.2420e-03 3.4569e-05 3.3648e-05 3.5604e-05 5.4324e-09 9.2889e-06 0:00:06 5
723 1.1996e-03 3.3176e-05 3.2334e-05 3.4116e-05 4.1759e-09 8.9408e-06 0:00:05 4
724 1.1624e-03 3.1942e-05 3.1173e-05 3.2811e-05 3.2382e-09 9.0028e-06 0:00:03 3
725 1.1300e-03 3.0851e-05 3.0142e-05 3.1653e-05 2.5298e-09 8.9198e-06 0:00:02 2
726 1.1012e-03 2.9873e-05 2.9221e-05 3.0615e-05 1.9891e-09 8.6405e-06 0:00:01 1
727 1.0754e-03 2.8992e-05 2.8391e-05 2.9683e-05 1.5729e-09 8.3074e-06 0:00:00 0
Flow time = 0.02000000000000001s, time step = 40
3960 more time stepsUpdating solution at time levels N and N-1.
727 1.0754e-03 2.8992e-05 2.8391e-05 2.9683e-05 1.5729e-09 8.3074e-06 0:00:25 20
728 8.5697e-03 8.1286e-04 7.4310e-04 9.0916e-03 3.8996e-04 1.2178e-02 0:00:23 19
729 6.4193e-03 3.0346e-04 2.7801e-04 2.5267e-03 8.6764e-05 3.4809e-03 0:00:21 18
730 4.4774e-03 1.4983e-04 1.3706e-04 7.2741e-04 1.9875e-05 8.2157e-04 0:00:23 17
731 3.4614e-03 1.0468e-04 9.7499e-05 2.4576e-04 4.7810e-06 2.2341e-04 0:00:20 16
732 2.8387e-03 8.4490e-05 7.9594e-05 1.1497e-04 1.2484e-06 6.8249e-05 0:00:18 15
733 2.3529e-03 7.1081e-05 6.7479e-05 8.0308e-05 3.7448e-07 2.5555e-05 0:00:16 14
734 1.9995e-03 6.1532e-05 5.8582e-05 6.7136e-05 1.3864e-07 1.2720e-05 0:00:15 13
735 1.7501e-03 5.4314e-05 5.1896e-05 5.8568e-05 6.5634e-08 8.1986e-06 0:00:16 12
736 1.5634e-03 4.8730e-05 4.6690e-05 5.2023e-05 3.8182e-08 6.1712e-06 0:00:14 11
737 1.4186e-03 4.4356e-05 4.2590e-05 4.6978e-05 2.5324e-08 5.0227e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
738 1.3029e-03 4.0801e-05 3.9285e-05 4.2973e-05 1.7419e-08 4.2493e-06 0:00:10 9
739 1.2090e-03 3.7853e-05 3.6552e-05 3.9687e-05 1.2479e-08 3.6887e-06 0:00:09 8
740 1.1315e-03 3.5382e-05 3.4253e-05 3.6959e-05 9.1709e-09 3.2890e-06 0:00:08 7
741 1.0662e-03 3.3268e-05 3.2301e-05 3.4651e-05 6.8610e-09 2.9881e-06 0:00:08 6
742 1.0109e-03 3.1453e-05 3.0615e-05 3.2670e-05 5.2019e-09 2.7453e-06 0:00:06 5
743 9.6336e-04 2.9878e-05 2.9137e-05 3.0952e-05 3.9864e-09 2.5451e-06 0:00:05 4
! 743 solution is converged
Flow time = 0.02050000000000001s, time step = 41
3959 more time steps
(cx-use-window-id 1)Updating solution at time levels N and N-1.
Time = 0.163 seconds.
Cell count 77405 78681 392069
Mean cell count deviation -1.3% 0.3%
Partition boundary cell count 1863 3169 12574
Partition boundary cell count ratio 2.4% 4.0% 3.2%Face count 159670 163193 803356
Mean face count deviation -1.5% 0.7%
Partition boundary face count 2022 3493 6899
Partition boundary face count ratio 1.2% 2.1% 0.9%Cell weights 8e+05 8e+05 4e+06
Mean cell weight deviation -1.3% 0.3%Partition neighbor count 2 4
743 9.6336e-04 2.9878e-05 2.9137e-05 3.0952e-05 3.9864e-09 2.5451e-06 0:00:24 20
744 8.1001e-03 9.3353e-04 8.8151e-04 1.1130e-02 3.8973e-04 1.1819e-02 0:00:22 19
745 5.9270e-03 3.3014e-04 3.0737e-04 3.0952e-03 8.6761e-05 3.4577e-03 0:00:20 18
746 4.1336e-03 1.5455e-04 1.4327e-04 8.7633e-04 1.9882e-05 8.0900e-04 0:00:22 17
747 3.1008e-03 1.0453e-04 9.8362e-05 2.8348e-04 4.7823e-06 2.1853e-04 0:00:20 16
748 2.4613e-03 8.3017e-05 7.8714e-05 1.2433e-04 1.2473e-06 6.6142e-05 0:00:18 15
749 1.9836e-03 6.8855e-05 6.5346e-05 8.0483e-05 3.7309e-07 2.4403e-05 0:00:16 14
750 1.6370e-03 5.8512e-05 5.5518e-05 6.4692e-05 1.3741e-07 1.1913e-05 0:00:15 13
751 1.3898e-03 5.0753e-05 4.8173e-05 5.5200e-05 6.4618e-08 7.4993e-06 0:00:13 12
752 1.2048e-03 4.4807e-05 4.2553e-05 4.8119e-05 3.7349e-08 5.5104e-06 0:00:12 11
753 1.0609e-03 4.0129e-05 3.8138e-05 4.2639e-05 2.4637e-08 4.3767e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
754 9.4737e-04 3.6371e-05 3.4606e-05 3.8320e-05 1.6865e-08 3.6276e-06 0:00:11 9
! 754 solution is converged
Flow time = 0.02100000000000002s, time step = 42
3958 more time stepsUpdating solution at time levels N and N-1.
754 9.4737e-04 3.6371e-05 3.4606e-05 3.8320e-05 1.6865e-08 3.6276e-06 0:00:24 20
755 7.9482e-03 9.6096e-04 9.0552e-04 1.2531e-02 3.8951e-04 1.1733e-02 0:00:22 19
756 5.7897e-03 3.3016e-04 3.0677e-04 3.3999e-03 8.6759e-05 3.4441e-03 0:00:24 18
757 3.9894e-03 1.5018e-04 1.3753e-04 9.3395e-04 1.9888e-05 8.0842e-04 0:00:22 17
758 3.0128e-03 1.0142e-04 9.3534e-05 2.9557e-04 4.7825e-06 2.2238e-04 0:00:19 16
759 2.4010e-03 8.1498e-05 7.5883e-05 1.2602e-04 1.2456e-06 6.9192e-05 0:00:18 15
760 1.9219e-03 6.8727e-05 6.4434e-05 8.0755e-05 3.7121e-07 2.6741e-05 0:00:16 14
761 1.5757e-03 5.9428e-05 5.6007e-05 6.5917e-05 1.3580e-07 1.4033e-05 0:00:14 13
762 1.3359e-03 5.2418e-05 4.9629e-05 5.7380e-05 6.3320e-08 9.6126e-06 0:00:13 12
763 1.1623e-03 4.6979e-05 4.4680e-05 5.0935e-05 3.6303e-08 7.7180e-06 0:00:14 11
764 1.0309e-03 4.2670e-05 4.0739e-05 4.5901e-05 2.3788e-08 6.7461e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
765 9.2788e-04 3.9178e-05 3.7547e-05 4.1880e-05 1.6192e-08 6.1458e-06 0:00:11 9
! 765 solution is converged
Flow time = 0.02150000000000002s, time step = 43
3957 more time stepsUpdating solution at time levels N and N-1.
765 9.2788e-04 3.9178e-05 3.7547e-05 4.1880e-05 1.6192e-08 6.1458e-06 0:00:23 20
766 8.5159e-03 9.1145e-04 8.3352e-04 1.2632e-02 3.8930e-04 1.1469e-02 0:00:22 19
767 6.3976e-03 2.9949e-04 2.7346e-04 3.1078e-03 8.6759e-05 4.3590e-03 0:00:24 18
768 4.4550e-03 1.4483e-04 1.3182e-04 8.5492e-04 1.9895e-05 1.1617e-03 0:00:21 17
769 3.4180e-03 1.0205e-04 9.4361e-05 2.7574e-04 4.7838e-06 3.2154e-04 0:00:19 16
770 2.7785e-03 8.3121e-05 7.7719e-05 1.2118e-04 1.2447e-06 9.2469e-05 0:00:17 15
771 2.2764e-03 7.0774e-05 6.6636e-05 8.0940e-05 3.6998e-07 3.0809e-05 0:00:16 14
772 1.9113e-03 6.1945e-05 5.8567e-05 6.8190e-05 1.3474e-07 1.3780e-05 0:00:14 13
773 1.6552e-03 5.5322e-05 5.2513e-05 6.0282e-05 6.2462e-08 8.4627e-06 0:00:15 12
774 1.4670e-03 5.0190e-05 4.7804e-05 5.4169e-05 3.5619e-08 6.2480e-06 0:00:13 11
775 1.3219e-03 4.6092e-05 4.4019e-05 4.9301e-05 2.3238e-08 5.1109e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
776 1.2070e-03 4.2731e-05 4.0921e-05 4.5374e-05 1.5760e-08 4.2187e-06 0:00:10 9
777 1.1140e-03 3.9898e-05 3.8333e-05 4.2114e-05 1.1152e-08 3.7215e-06 0:00:09 8
778 1.0368e-03 3.7463e-05 3.6117e-05 3.9370e-05 8.1053e-09 3.2798e-06 0:00:08 7
779 9.7170e-04 3.5330e-05 3.4190e-05 3.7020e-05 6.0018e-09 2.9237e-06 0:00:08 6
! 779 solution is converged
Flow time = 0.02200000000000002s, time step = 44
3956 more time stepsUpdating solution at time levels N and N-1.
779 9.7170e-04 3.5330e-05 3.4190e-05 3.7020e-05 6.0018e-09 2.9237e-06 0:00:25 20
780 8.9407e-03 7.9588e-04 7.2605e-04 1.0668e-02 3.8911e-04 1.1268e-02 0:00:27 19
781 6.8196e-03 2.7394e-04 2.4979e-04 2.6535e-03 8.6763e-05 3.3117e-03 0:00:24 18
782 4.8254e-03 1.3609e-04 1.2530e-04 7.3707e-04 1.9904e-05 7.8333e-04 0:00:22 17
783 3.7620e-03 9.7054e-05 9.1279e-05 2.4273e-04 4.7861e-06 2.1599e-04 0:00:19 16
784 3.1033e-03 7.9253e-05 7.5593e-05 1.0979e-04 1.2447e-06 6.6714e-05 0:00:18 15
785 2.5898e-03 6.7714e-05 6.4841e-05 7.6399e-05 3.6947e-07 2.4919e-05 0:00:19 14
786 2.2213e-03 5.9552e-05 5.7043e-05 6.5282e-05 1.3423e-07 1.2239e-05 0:00:17 13
787 1.9644e-03 5.3507e-05 5.1306e-05 5.8020e-05 6.2050e-08 7.7680e-06 0:00:15 12
788 1.7752e-03 4.8900e-05 4.6967e-05 5.2432e-05 3.5287e-08 5.7809e-06 0:00:13 11
789 1.6287e-03 4.5254e-05 4.3554e-05 4.8055e-05 2.2968e-08 4.6828e-06 0:00:11 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
790 1.5125e-03 4.2272e-05 4.0771e-05 4.4558e-05 1.5543e-08 3.9644e-06 0:00:12 9
791 1.4180e-03 3.9787e-05 3.8448e-05 4.1678e-05 1.0976e-08 3.4602e-06 0:00:10 8
792 1.3398e-03 3.7678e-05 3.6456e-05 3.9268e-05 7.9627e-09 3.0884e-06 0:00:08 7
793 1.2736e-03 3.5845e-05 3.4733e-05 3.7210e-05 5.8859e-09 2.8022e-06 0:00:07 6
794 1.2170e-03 3.4239e-05 3.3228e-05 3.5434e-05 4.4145e-09 2.5709e-06 0:00:06 5
795 1.1679e-03 3.2926e-05 3.1893e-05 3.3877e-05 3.3481e-09 2.3845e-06 0:00:05 4
796 1.1251e-03 3.1694e-05 3.0723e-05 3.2544e-05 2.5620e-09 2.2298e-06 0:00:04 3
797 1.0866e-03 3.0437e-05 2.9628e-05 3.1249e-05 1.9776e-09 2.1008e-06 0:00:02 2
798 1.0527e-03 2.9372e-05 2.8617e-05 3.0099e-05 1.5376e-09 1.9911e-06 0:00:01 1
799 1.0220e-03 2.8404e-05 2.7698e-05 2.9069e-05 1.2033e-09 1.8975e-06 0:00:00 0
Flow time = 0.02250000000000002s, time step = 45
3955 more time stepsUpdating solution at time levels N and N-1.
799 1.0220e-03 2.8404e-05 2.7698e-05 2.9069e-05 1.2033e-09 1.8975e-06 0:00:22 20
800 9.5739e-03 8.9385e-04 7.9158e-04 7.9848e-03 3.8894e-04 1.1114e-02 0:00:25 19
801 7.3593e-03 2.9586e-04 2.6550e-04 2.0290e-03 8.6768e-05 5.1584e-03 0:00:22 18
802 5.2876e-03 1.3927e-04 1.2558e-04 5.7939e-04 1.9912e-05 1.3623e-03 0:00:20 17
803 4.1842e-03 9.6331e-05 8.8804e-05 2.0014e-04 4.7881e-06 3.7958e-04 0:00:18 16
804 3.4959e-03 7.8455e-05 7.3456e-05 9.8013e-05 1.2444e-06 1.0774e-04 0:00:17 15
805 2.9576e-03 6.7199e-05 6.3376e-05 7.3121e-05 3.6877e-07 3.2392e-05 0:00:18 14
806 2.5643e-03 5.9230e-05 5.6154e-05 6.3709e-05 1.3358e-07 1.7420e-05 0:00:16 13
807 2.2861e-03 5.3369e-05 5.0796e-05 5.7161e-05 6.1519e-08 1.3874e-05 0:00:14 12
808 2.0809e-03 4.8890e-05 4.6710e-05 5.2030e-05 3.4859e-08 1.2698e-05 0:00:13 11
809 1.9189e-03 4.5377e-05 4.3507e-05 4.8086e-05 2.2619e-08 1.1937e-05 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
810 1.7924e-03 4.2561e-05 4.0944e-05 4.4953e-05 1.5265e-08 1.1890e-05 0:00:11 9
811 1.6874e-03 4.0231e-05 3.8806e-05 4.2364e-05 1.0753e-08 1.1467e-05 0:00:10 8
812 1.5999e-03 3.8282e-05 3.7003e-05 4.0222e-05 7.7828e-09 1.0874e-05 0:00:08 7
813 1.5291e-03 3.6610e-05 3.5446e-05 3.8448e-05 5.7411e-09 1.0465e-05 0:00:07 6
814 1.4632e-03 3.5179e-05 3.4091e-05 3.6814e-05 4.2958e-09 1.0193e-05 0:00:07 5
815 1.4093e-03 3.3892e-05 3.2891e-05 3.5536e-05 3.2517e-09 1.0486e-05 0:00:05 4
816 1.3644e-03 3.2769e-05 3.1840e-05 3.4270e-05 2.4855e-09 1.0934e-05 0:00:04 3
817 1.3172e-03 3.1736e-05 3.0867e-05 3.3179e-05 1.9160e-09 1.0247e-05 0:00:02 2
818 1.2791e-03 3.0806e-05 3.0000e-05 3.2205e-05 1.4879e-09 1.0008e-05 0:00:01 1
819 1.2484e-03 2.9943e-05 2.9194e-05 3.1329e-05 1.1633e-09 9.9112e-06 0:00:00 0
Flow time = 0.02300000000000002s, time step = 46
3954 more time stepsUpdating solution at time levels N and N-1.
done.Updating mesh at time level N... (cx-use-window-id 1)
done.iter continuity x-velocity y-velocity z-velocity k omega time/iter
819 1.2484e-03 2.9943e-05 2.9194e-05 3.1329e-05 1.1633e-09 9.9112e-06 0:00:26 20
820 9.5145e-03 7.0040e-04 6.2854e-04 5.1968e-03 3.8878e-04 1.0790e-02 0:00:27 19
821 7.4785e-03 2.4420e-04 2.2035e-04 1.3661e-03 8.6774e-05 3.2062e-03 0:00:24 18
822 5.4313e-03 1.2161e-04 1.1129e-04 4.0886e-04 1.9919e-05 7.5540e-04 0:00:22 17
823 4.3034e-03 8.7826e-05 8.2111e-05 1.5352e-04 4.7894e-06 2.0892e-04 0:00:20 16
824 3.5918e-03 7.3502e-05 6.9679e-05 8.4883e-05 1.2436e-06 6.4822e-05 0:00:18 15
825 3.0410e-03 6.4165e-05 6.1204e-05 6.8844e-05 3.6767e-07 2.4474e-05 0:00:16 14
826 2.6436e-03 5.7336e-05 5.4898e-05 6.1157e-05 1.3263e-07 1.2202e-05 0:00:14 13
827 2.3623e-03 5.2121e-05 5.0094e-05 5.5237e-05 6.0745e-08 7.8170e-06 0:00:16 12
828 2.1538e-03 4.8024e-05 4.6338e-05 5.0508e-05 3.4235e-08 5.8354e-06 0:00:14 11
829 1.9913e-03 4.4741e-05 4.3331e-05 4.6739e-05 2.2111e-08 4.7137e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
830 1.8608e-03 4.2050e-05 4.0878e-05 4.3691e-05 1.4862e-08 3.9683e-06 0:00:10 9
831 1.7551e-03 3.9800e-05 3.8815e-05 4.1173e-05 1.0431e-08 3.4343e-06 0:00:09 8
832 1.6670e-03 3.7895e-05 3.7058e-05 3.9049e-05 7.5250e-09 3.0326e-06 0:00:09 7
833 1.5927e-03 3.6257e-05 3.5531e-05 3.7252e-05 5.5342e-09 2.7232e-06 0:00:07 6
834 1.5290e-03 3.4837e-05 3.4190e-05 3.5714e-05 4.1294e-09 2.4805e-06 0:00:06 5
835 1.4738e-03 3.3593e-05 3.3010e-05 3.4373e-05 3.1178e-09 2.2872e-06 0:00:05 4
836 1.4255e-03 3.2498e-05 3.1971e-05 3.3196e-05 2.3776e-09 2.1297e-06 0:00:04 3
837 1.3831e-03 3.1528e-05 3.1044e-05 3.2163e-05 1.8291e-09 2.0009e-06 0:00:02 2
838 1.3453e-03 3.0660e-05 3.0211e-05 3.1243e-05 1.4180e-09 1.8941e-06 0:00:01 1
839 1.3115e-03 2.9879e-05 2.9454e-05 3.0416e-05 1.1071e-09 1.8039e-06 0:00:00 0
Flow time = 0.02350000000000002s, time step = 47
3953 more time stepsUpdating solution at time levels N and N-1.
Time = 0.168 seconds.
Cell count 80414 80450 402142
Mean cell count deviation -0.0% 0.0%
Partition boundary cell count 1843 3289 12131
Partition boundary cell count ratio 2.3% 4.1% 3.0%Face count 165381 166622 823502
Mean face count deviation -0.4% 0.4%
Partition boundary face count 1981 3643 6666
Partition boundary face count ratio 1.2% 2.2% 0.8%Cell weights 8e+05 8e+05 4e+06
Mean cell weight deviation -0.0% 0.0%Partition neighbor count 2 4
839 1.3115e-03 2.9879e-05 2.9454e-05 3.0416e-05 1.1071e-09 1.8039e-06 0:00:23 20
840 9.8515e-03 6.2315e-04 5.6164e-04 2.8030e-03 3.8863e-04 1.0581e-02 0:00:25 19
841 7.5484e-03 2.2068e-04 1.9841e-04 7.7817e-04 8.6781e-05 3.1429e-03 0:00:23 18
842 5.5375e-03 1.1238e-04 1.0212e-04 2.5739e-04 1.9927e-05 7.3973e-04 0:00:20 17
843 4.3717e-03 8.1400e-05 7.5599e-05 1.1348e-04 4.7906e-06 2.0326e-04 0:00:22 16
844 3.6489e-03 6.7962e-05 6.4053e-05 7.4783e-05 1.2428e-06 6.2489e-05 0:00:19 15
845 3.1045e-03 5.9349e-05 5.6386e-05 6.3459e-05 3.6653e-07 2.3262e-05 0:00:17 14
846 2.7082e-03 5.3079e-05 5.0684e-05 5.6439e-05 1.3163e-07 1.1346e-05 0:00:15 13
847 2.4251e-03 4.8334e-05 4.6322e-05 5.0982e-05 5.9939e-08 7.0512e-06 0:00:14 12
848 2.2127e-03 4.4688e-05 4.2943e-05 4.6689e-05 3.3585e-08 5.0837e-06 0:00:12 11
849 2.0466e-03 4.1809e-05 4.0279e-05 4.3341e-05 2.1582e-08 3.9656e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
850 1.9137e-03 3.9465e-05 3.8127e-05 4.0700e-05 1.4442e-08 3.2218e-06 0:00:11 9
851 1.8055e-03 3.7524e-05 3.6345e-05 3.8556e-05 1.0095e-08 2.6923e-06 0:00:10 8
852 1.7154e-03 3.5885e-05 3.4845e-05 3.6781e-05 7.2555e-09 2.2956e-06 0:00:08 7
853 1.6393e-03 3.4476e-05 3.3560e-05 3.5275e-05 5.3170e-09 1.9916e-06 0:00:07 6
854 1.5740e-03 3.3249e-05 3.2440e-05 3.3979e-05 3.9544e-09 1.7545e-06 0:00:05 5
855 1.5174e-03 3.2163e-05 3.1449e-05 3.2842e-05 2.9765e-09 1.5644e-06 0:00:05 4
856 1.4678e-03 3.1195e-05 3.0565e-05 3.1829e-05 2.2636e-09 1.4108e-06 0:00:04 3
857 1.4244e-03 3.0331e-05 2.9770e-05 3.0919e-05 1.7369e-09 1.2813e-06 0:00:02 2
858 1.3860e-03 2.9552e-05 2.9050e-05 3.0100e-05 1.3435e-09 1.1733e-06 0:00:01 1
859 1.3516e-03 2.8850e-05 2.8390e-05 2.9362e-05 1.0469e-09 1.0831e-06 0:00:00 0
Flow time = 0.02400000000000002s, time step = 48
3952 more time stepsUpdating solution at time levels N and N-1.
done.Updating mesh at time level N... done.
859 1.3516e-03 2.8850e-05 2.8390e-05 2.9362e-05 1.0469e-09 1.0831e-06 0:00:22 20
860 1.0507e-02 6.3528e-04 5.6332e-04 1.5922e-03 3.8850e-04 1.0457e-02 0:00:25 19
861 7.8188e-03 2.4142e-04 2.1877e-04 4.9968e-04 8.6790e-05 3.1580e-03 0:00:22 18
862 5.6178e-03 1.2760e-04 1.1638e-04 1.9835e-04 1.9934e-05 7.4355e-04 0:00:20 17
863 4.4291e-03 9.2689e-05 8.6049e-05 1.1080e-04 4.7916e-06 2.0509e-04 0:00:22 16
864 3.6893e-03 7.6740e-05 7.2112e-05 8.3488e-05 1.2418e-06 6.3186e-05 0:00:19 15
865 3.1165e-03 6.6603e-05 6.2964e-05 7.1385e-05 3.6531e-07 2.3405e-05 0:00:17 14
866 2.6992e-03 5.9446e-05 5.6355e-05 6.3175e-05 1.3059e-07 1.1338e-05 0:00:15 13
867 2.4044e-03 5.4099e-05 5.1392e-05 5.6916e-05 5.9120e-08 7.0452e-06 0:00:14 12
868 2.1847e-03 4.9887e-05 4.7565e-05 5.1992e-05 3.2942e-08 5.1201e-06 0:00:12 11
869 2.0145e-03 4.6461e-05 4.4539e-05 4.8100e-05 2.1074e-08 4.0180e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
870 1.8790e-03 4.3605e-05 4.2011e-05 4.4962e-05 1.4051e-08 3.2840e-06 0:00:11 9
871 1.7687e-03 4.1183e-05 3.9871e-05 4.2357e-05 9.7936e-09 2.7603e-06 0:00:09 8
872 1.6761e-03 3.9119e-05 3.8018e-05 4.0170e-05 7.0217e-09 2.3694e-06 0:00:08 7
873 1.5974e-03 3.7328e-05 3.6392e-05 3.8288e-05 5.1353e-09 2.0696e-06 0:00:07 6
874 1.5297e-03 3.5767e-05 3.4950e-05 3.6653e-05 3.8130e-09 1.8343e-06 0:00:06 5
875 1.4709e-03 3.4385e-05 3.3666e-05 3.5220e-05 2.8663e-09 1.6460e-06 0:00:05 4
876 1.4190e-03 3.3156e-05 3.2505e-05 3.3938e-05 2.1775e-09 1.4921e-06 0:00:04 3
877 1.3728e-03 3.2039e-05 3.1446e-05 3.2779e-05 1.6696e-09 1.3641e-06 0:00:02 2
878 1.3314e-03 3.1014e-05 3.0477e-05 3.1718e-05 1.2909e-09 1.2573e-06 0:00:01 1
879 1.2942e-03 3.0084e-05 2.9593e-05 3.0746e-05 1.0056e-09 1.1665e-06 0:00:00 0
Flow time = 0.02450000000000002s, time step = 49
3951 more time stepsUpdating solution at time levels N and N-1.
879 1.2942e-03 3.0084e-05 2.9593e-05 3.0746e-05 1.0056e-09 1.1665e-06 0:00:26 20
880 1.0363e-02 5.5498e-04 4.9287e-04 2.9771e-03 3.8837e-04 1.0214e-02 0:00:24 19
881 7.8689e-03 2.1548e-04 1.9487e-04 8.5541e-04 8.6799e-05 3.1007e-03 0:00:25 18
882 5.5935e-03 1.1703e-04 1.0655e-04 2.8395e-04 1.9941e-05 7.2065e-04 0:00:22 17
883 4.3821e-03 8.6575e-05 8.0633e-05 1.2559e-04 4.7926e-06 1.9993e-04 0:00:20 16
884 3.6196e-03 7.1991e-05 6.8023e-05 8.1617e-05 1.2409e-06 6.2624e-05 0:00:18 15
885 3.0210e-03 6.2300e-05 5.9279e-05 6.7136e-05 3.6423e-07 2.4066e-05 0:00:16 14
886 2.5870e-03 5.5211e-05 5.2833e-05 5.8868e-05 1.2969e-07 1.2256e-05 0:00:17 13
887 2.2766e-03 4.9876e-05 4.7906e-05 5.2738e-05 5.8409e-08 7.9804e-06 0:00:15 12
888 2.0448e-03 4.5728e-05 4.4075e-05 4.7993e-05 3.2382e-08 6.0321e-06 0:00:13 11
889 1.8639e-03 4.2435e-05 4.1021e-05 4.4268e-05 2.0628e-08 4.9107e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
890 1.7198e-03 3.9752e-05 3.8527e-05 4.1282e-05 1.3703e-08 4.1601e-06 0:00:10 9
891 1.6027e-03 3.7504e-05 3.6426e-05 3.8821e-05 9.5201e-09 3.6286e-06 0:00:10 8
892 1.5060e-03 3.5595e-05 3.4624e-05 3.6743e-05 6.8054e-09 3.2415e-06 0:00:09 7
893 1.4249e-03 3.3947e-05 3.3066e-05 3.4969e-05 4.9636e-09 2.9417e-06 0:00:07 6
894 1.3559e-03 3.2502e-05 3.1699e-05 3.3424e-05 3.6761e-09 2.7002e-06 0:00:06 5
895 1.2967e-03 3.1217e-05 3.0487e-05 3.2066e-05 2.7568e-09 2.5110e-06 0:00:05 4
896 1.2453e-03 3.0066e-05 2.9417e-05 3.0860e-05 2.0897e-09 2.3552e-06 0:00:04 3
897 1.2002e-03 2.9027e-05 2.8454e-05 2.9784e-05 1.5990e-09 2.2240e-06 0:00:02 2
898 1.1603e-03 2.8075e-05 2.7585e-05 2.8800e-05 1.2339e-09 2.1131e-06 0:00:01 1
899 1.1247e-03 2.7202e-05 2.6790e-05 2.7909e-05 9.5964e-10 2.0196e-06 0:00:00 0
(update-animation-object "animation-3")
Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-3.cxa
(update-animation-object "animation-2")
Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-2.cxa
(update-animation-object "animation-1")
Creating animation sequence file: C:\\Users\\Alberto\\Desktop\\falling_seed\\seed_one_files\\dp0\\FFF\\Fluent\\\\.\\\\animation-1.cxa
Flow time = 0.02500000000000002s, time step = 50
3950 more time stepsUpdating solution at time levels N and N-1.
899 1.1247e-03 2.7202e-05 2.6790e-05 2.7909e-05 9.5964e-10 2.0196e-06 0:00:23 20
900 1.0683e-02 6.3609e-04 5.6429e-04 5.0837e-03 3.8826e-04 1.0046e-02 0:00:25 19
901 7.9097e-03 2.4297e-04 2.1703e-04 1.4170e-03 8.6810e-05 3.0236e-03 0:00:26 18
902 5.5127e-03 1.2500e-04 1.1338e-04 4.3256e-04 1.9948e-05 7.1298e-04 0:00:23 17
903 4.2027e-03 9.0219e-05 8.3843e-05 1.6445e-04 4.7935e-06 1.9824e-04 0:00:21 16
904 3.3874e-03 7.4054e-05 6.9651e-05 8.9673e-05 1.2399e-06 6.2148e-05 0:00:18 15
905 2.7653e-03 6.3139e-05 5.9599e-05 6.8568e-05 3.6306e-07 2.3957e-05 0:00:17 14
906 2.3143e-03 5.5053e-05 5.2103e-05 5.8674e-05 1.2871e-07 1.2294e-05 0:00:15 13
907 1.9947e-03 4.8851e-05 4.6390e-05 5.1609e-05 5.7634e-08 8.0727e-06 0:00:16 12
908 1.7584e-03 4.3988e-05 4.1955e-05 4.6115e-05 3.1774e-08 6.1307e-06 0:00:14 11
909 1.5765e-03 4.0133e-05 3.8426e-05 4.1815e-05 2.0146e-08 5.0386e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
910 1.4339e-03 3.7012e-05 3.5552e-05 3.8406e-05 1.3331e-08 4.2984e-06 0:00:10 9
911 1.3201e-03 3.4428e-05 3.3166e-05 3.5613e-05 9.2307e-09 3.7582e-06 0:00:09 8
912 1.2274e-03 3.2245e-05 3.1158e-05 3.3281e-05 6.5795e-09 3.3504e-06 0:00:08 7
913 1.1511e-03 3.0387e-05 2.9444e-05 3.1306e-05 4.7869e-09 3.0395e-06 0:00:06 6
914 1.0878e-03 2.8789e-05 2.7976e-05 2.9616e-05 3.5378e-09 2.7947e-06 0:00:06 5
915 1.0345e-03 2.7402e-05 2.6703e-05 2.8161e-05 2.6485e-09 2.6006e-06 0:00:05 4
916 9.8931e-04 2.6187e-05 2.5588e-05 2.6896e-05 2.0050e-09 2.4516e-06 0:00:04 3
! 916 solution is converged
Flow time = 0.02550000000000002s, time step = 51
3949 more time steps
(cx-set-camera-relative '(0.0242794 -0.0108583 -0.0440158) '(0 0 0) '(0.170573 -0.0395451 0.103049) 0 0)
(cx-set-camera-relative '(0.0188594 0.00197589 -0.0519243) '(0 0 0) '(0.178125 -0.0379114 0.0632562) 0 0)Updating solution at time levels N and N-1.
916 9.8931e-04 2.6187e-05 2.5588e-05 2.6896e-05 2.0050e-09 2.4516e-06 0:00:23 20
917 1.0686e-02 7.1218e-04 6.3453e-04 6.5392e-03 3.8816e-04 9.8942e-03 0:00:25 19
918 7.7671e-03 2.5961e-04 2.3352e-04 1.8118e-03 8.6822e-05 3.0608e-03 0:00:23 18
919 5.3280e-03 1.2821e-04 1.1516e-04 5.3601e-04 1.9955e-05 7.1594e-04 0:00:21 17
920 4.0357e-03 8.9447e-05 8.1392e-05 1.9142e-04 4.7940e-06 1.9955e-04 0:00:19 16
921 3.2399e-03 7.1852e-05 6.6154e-05 9.5016e-05 1.2386e-06 6.2865e-05 0:00:20 15
922 2.6163e-03 6.0311e-05 5.5970e-05 6.7594e-05 3.6170e-07 2.4362e-05 0:00:18 14
923 2.1627e-03 5.1985e-05 4.8604e-05 5.6523e-05 1.2761e-07 1.2559e-05 0:00:16 13
924 1.8423e-03 4.5800e-05 4.3059e-05 4.9166e-05 5.6786e-08 8.3005e-06 0:00:14 12
925 1.6064e-03 4.1077e-05 3.8769e-05 4.3558e-05 3.1119e-08 6.3462e-06 0:00:13 11
926 1.4242e-03 3.7360e-05 3.5373e-05 3.9196e-05 1.9634e-08 5.2341e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
927 1.2794e-03 3.4317e-05 3.2596e-05 3.5743e-05 1.2940e-08 4.4875e-06 0:00:11 9
928 1.1628e-03 3.1775e-05 3.0273e-05 3.2910e-05 8.9300e-09 3.9285e-06 0:00:10 8
929 1.0674e-03 2.9609e-05 2.8295e-05 3.0537e-05 6.3467e-09 3.5249e-06 0:00:08 7
930 9.8789e-04 2.7741e-05 2.6575e-05 2.8528e-05 4.6056e-09 3.2148e-06 0:00:07 6
! 930 solution is converged
Flow time = 0.02600000000000002s, time step = 52
3948 more time stepsUpdating solution at time levels N and N-1.
Time = 0.174 seconds.
Cell count 83535 84082 419567
Mean cell count deviation -0.5% 0.2%
Partition boundary cell count 1956 3219 12737
Partition boundary cell count ratio 2.3% 3.8% 3.0%Face count 172612 173720 858352
Mean face count deviation -0.3% 0.4%
Partition boundary face count 2101 3548 7003
Partition boundary face count ratio 1.2% 2.0% 0.8%Cell weights 8e+05 8e+05 4e+06
Mean cell weight deviation -0.5% 0.2%Partition neighbor count 2 4
930 9.8789e-04 2.7741e-05 2.6575e-05 2.8528e-05 4.6056e-09 3.2148e-06 0:00:23 20
931 1.1299e-02 8.5819e-04 7.3641e-04 7.4730e-03 3.8808e-04 9.6860e-03 0:00:25 19
932 7.8026e-03 3.1187e-04 2.6675e-04 2.0783e-03 8.6837e-05 2.9233e-03 0:00:22 18
933 5.2409e-03 1.5498e-04 1.3248e-04 6.2026e-04 1.9963e-05 6.8673e-04 0:00:20 17
934 3.8460e-03 1.0601e-04 9.2542e-05 2.2470e-04 4.7949e-06 1.9118e-04 0:00:18 16
935 3.0034e-03 8.3502e-05 7.4408e-05 1.1297e-04 1.2377e-06 6.0010e-05 0:00:17 15
936 2.3696e-03 6.8992e-05 6.2345e-05 7.8653e-05 3.6057e-07 2.3053e-05 0:00:18 14
937 1.9154e-03 5.8710e-05 5.3558e-05 6.4195e-05 1.2666e-07 1.1669e-05 0:00:16 13
938 1.5964e-03 5.1133e-05 4.6949e-05 5.5118e-05 5.6051e-08 7.5035e-06 0:00:14 12
939 1.3624e-03 4.5369e-05 4.1806e-05 4.8335e-05 3.0547e-08 5.5799e-06 0:00:13 11
940 1.1828e-03 4.0743e-05 3.7631e-05 4.3011e-05 1.9186e-08 4.4691e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
941 1.0423e-03 3.6925e-05 3.4208e-05 3.8728e-05 1.2598e-08 3.7272e-06 0:00:13 9
942 9.3025e-04 3.3736e-05 3.1328e-05 3.5205e-05 8.6676e-09 3.1996e-06 0:00:11 8
! 942 solution is converged
Flow time = 0.02650000000000002s, time step = 53
3947 more time stepsUpdating solution at time levels N and N-1.
942 9.3025e-04 3.3736e-05 3.1328e-05 3.5205e-05 8.6676e-09 3.1996e-06 0:00:27 20
943 1.0115e-02 7.8214e-04 7.0580e-04 7.9391e-03 3.8800e-04 9.4361e-03 0:00:28 19
944 7.4833e-03 2.8040e-04 2.5161e-04 2.1427e-03 8.6850e-05 2.9116e-03 0:00:25 18
945 5.1084e-03 1.3653e-04 1.2275e-04 6.1809e-04 1.9969e-05 6.7724e-04 0:00:22 17
946 3.8113e-03 9.5135e-05 8.6948e-05 2.1779e-04 4.7954e-06 1.8815e-04 0:00:20 16
947 3.0051e-03 7.7016e-05 7.1241e-05 1.0725e-04 1.2366e-06 5.9180e-05 0:00:18 15
948 2.3867e-03 6.5084e-05 6.0574e-05 7.5115e-05 3.5938e-07 2.2907e-05 0:00:16 14
949 1.9427e-03 5.6312e-05 5.2649e-05 6.2788e-05 1.2572e-07 1.1771e-05 0:00:17 13
950 1.6347e-03 4.9558e-05 4.6514e-05 5.4692e-05 5.5343e-08 7.6876e-06 0:00:15 12
951 1.4130e-03 4.4203e-05 4.1638e-05 4.8279e-05 3.0014e-08 5.8139e-06 0:00:13 11
952 1.2454e-03 3.9896e-05 3.7696e-05 4.3162e-05 1.8780e-08 4.7261e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
953 1.1149e-03 3.6370e-05 3.4454e-05 3.9024e-05 1.2298e-08 3.9947e-06 0:00:10 9
954 1.0109e-03 3.3430e-05 3.1743e-05 3.5601e-05 8.4445e-09 3.4745e-06 0:00:10 8
955 9.2630e-04 3.0927e-05 2.9447e-05 3.2742e-05 5.9781e-09 3.0938e-06 0:00:09 7
! 955 solution is converged
Flow time = 0.02700000000000002s, time step = 54
3946 more time stepsUpdating solution at time levels N and N-1.
955 9.2630e-04 3.0927e-05 2.9447e-05 3.2742e-05 5.9781e-09 3.0938e-06 0:00:25 20
956 1.1087e-02 8.8298e-04 7.7854e-04 7.8135e-03 3.8794e-04 9.4176e-03 0:00:27 19
957 8.0617e-03 3.1319e-04 2.7910e-04 2.0388e-03 8.6868e-05 2.9863e-03 0:00:24 18
958 5.4778e-03 1.5290e-04 1.3667e-04 6.0166e-04 1.9977e-05 6.9341e-04 0:00:21 17
959 4.1299e-03 1.0448e-04 9.5634e-05 2.2163e-04 4.7961e-06 1.9437e-04 0:00:22 16
960 3.3119e-03 8.2787e-05 7.6924e-05 1.1313e-04 1.2355e-06 6.1783e-05 0:00:20 15
961 2.6785e-03 6.8772e-05 6.4478e-05 8.0253e-05 3.5826e-07 2.4200e-05 0:00:18 14
962 2.2248e-03 5.9075e-05 5.5528e-05 6.6871e-05 1.2485e-07 1.2587e-05 0:00:16 13
963 1.9071e-03 5.1959e-05 4.9022e-05 5.7870e-05 5.4697e-08 8.3411e-06 0:00:16 12
964 1.6755e-03 4.6543e-05 4.4089e-05 5.1066e-05 2.9539e-08 6.3733e-06 0:00:14 11
965 1.4999e-03 4.2348e-05 4.0263e-05 4.5884e-05 1.8427e-08 5.2354e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
966 1.3623e-03 3.8999e-05 3.7209e-05 4.1819e-05 1.2043e-08 4.4781e-06 0:00:11 9
967 1.2519e-03 3.6247e-05 3.4697e-05 3.8538e-05 8.2597e-09 3.9339e-06 0:00:11 8
968 1.1614e-03 3.3920e-05 3.2551e-05 3.5867e-05 5.8433e-09 3.5305e-06 0:00:09 7
969 1.0852e-03 3.1929e-05 3.0683e-05 3.3586e-05 4.2265e-09 3.2207e-06 0:00:07 6
970 1.0200e-03 3.0184e-05 2.9046e-05 3.1608e-05 3.1102e-09 2.9787e-06 0:00:07 5
971 9.6367e-04 2.8651e-05 2.7599e-05 2.9922e-05 2.3217e-09 2.7852e-06 0:00:05 4
! 971 solution is converged
Flow time = 0.02750000000000002s, time step = 55
3945 more time stepsUpdating solution at time levels N and N-1.
971 9.6367e-04 2.8651e-05 2.7599e-05 2.9922e-05 2.3217e-09 2.7852e-06 0:00:26 20
972 1.1301e-02 7.8754e-04 7.2176e-04 6.7360e-03 3.8788e-04 9.3209e-03 0:00:27 19
973 8.4481e-03 2.6773e-04 2.4383e-04 1.7516e-03 8.6886e-05 2.9141e-03 0:00:24 18
974 5.8483e-03 1.2897e-04 1.1644e-04 5.1170e-04 1.9985e-05 6.8297e-04 0:00:22 17
975 4.4695e-03 8.9767e-05 8.2003e-05 1.8398e-04 4.7976e-06 1.9261e-04 0:00:20 16
976 3.6187e-03 7.3111e-05 6.7513e-05 9.3244e-05 1.2352e-06 6.1635e-05 0:00:21 15
977 2.9623e-03 6.2325e-05 5.7983e-05 6.8917e-05 3.5766e-07 2.4452e-05 0:00:18 14
978 2.4901e-03 5.4579e-05 5.1011e-05 5.9224e-05 1.2435e-07 1.2967e-05 0:00:16 13
979 2.1582e-03 4.8733e-05 4.5718e-05 5.2392e-05 5.4328e-08 8.7511e-06 0:00:17 12
980 1.9132e-03 4.4229e-05 4.1619e-05 4.7032e-05 2.9263e-08 6.7963e-06 0:00:14 11
981 1.7237e-03 4.0622e-05 3.8373e-05 4.2839e-05 1.8217e-08 5.6555e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
982 1.5734e-03 3.7652e-05 3.5725e-05 3.9477e-05 1.1887e-08 4.9052e-06 0:00:11 9
983 1.4515e-03 3.5171e-05 3.3503e-05 3.6722e-05 8.1429e-09 4.3533e-06 0:00:11 8
984 1.3502e-03 3.3059e-05 3.1599e-05 3.4419e-05 5.7556e-09 4.6863e-06 0:00:09 7
985 1.2651e-03 3.1235e-05 2.9948e-05 3.2463e-05 4.1609e-09 3.8683e-06 0:00:07 6
986 1.1927e-03 2.9639e-05 2.8497e-05 3.0770e-05 3.0613e-09 3.4264e-06 0:00:07 5
987 1.1303e-03 2.8231e-05 2.7204e-05 2.9271e-05 2.2855e-09 3.1644e-06 0:00:05 4
988 1.0762e-03 2.6974e-05 2.6040e-05 2.7936e-05 1.7285e-09 2.9813e-06 0:00:04 3
989 1.0289e-03 2.5849e-05 2.4994e-05 2.6735e-05 1.3224e-09 2.8400e-06 0:00:03 2
990 9.8740e-04 2.4811e-05 2.4043e-05 2.5645e-05 1.0228e-09 2.7251e-06 0:00:01 1
! 990 solution is converged
Flow time = 0.02800000000000002s, time step = 56
3944 more time stepsUpdating solution at time levels N and N-1.
990 9.8740e-04 2.4811e-05 2.4043e-05 2.5645e-05 1.0228e-09 2.7251e-06 0:00:26 20
991 1.1901e-02 8.2961e-04 7.3337e-04 5.4804e-03 3.8784e-04 9.0612e-03 0:00:27 19
992 8.8631e-03 2.8609e-04 2.5452e-04 1.4538e-03 8.6906e-05 2.8296e-03 0:00:24 18
993 6.2159e-03 1.3682e-04 1.2162e-04 4.3921e-04 1.9993e-05 6.6172e-04 0:00:25 17
994 4.7889e-03 9.3739e-05 8.5114e-05 1.6738e-04 4.7986e-06 1.8575e-04 0:00:22 16
995 3.9173e-03 7.5520e-05 6.9858e-05 9.0799e-05 1.2344e-06 5.8899e-05 0:00:20 15
996 3.2451e-03 6.4251e-05 5.9849e-05 6.9690e-05 3.5674e-07 2.2836e-05 0:00:20 14
997 2.7564e-03 5.6222e-05 5.2615e-05 6.0137e-05 1.2362e-07 1.1638e-05 0:00:18 13
998 2.4102e-03 5.0167e-05 4.7144e-05 5.3148e-05 5.3776e-08 7.4941e-06 0:00:15 12
999 2.1534e-03 4.5445e-05 4.2891e-05 4.7693e-05 2.8849e-08 5.5553e-06 0:00:16 11
1000 1.9530e-03 4.1661e-05 3.9511e-05 4.3403e-05 1.7902e-08 4.4224e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1001 1.7929e-03 3.8574e-05 3.6730e-05 3.9966e-05 1.2106e-08 3.6544e-06 0:00:11 9
1002 1.6631e-03 3.6020e-05 3.4415e-05 3.7187e-05 8.2792e-09 3.0990e-06 0:00:13 8
1003 1.5553e-03 3.3871e-05 3.2457e-05 3.4879e-05 5.8425e-09 2.6850e-06 0:00:10 7
1004 1.4643e-03 3.2029e-05 3.0779e-05 3.2906e-05 4.2177e-09 2.3681e-06 0:00:08 6
1005 1.3863e-03 3.0431e-05 2.9317e-05 3.1203e-05 3.0996e-09 2.1153e-06 0:00:08 5
1006 1.3192e-03 2.9034e-05 2.8038e-05 2.9724e-05 2.3126e-09 1.9105e-06 0:00:06 4
1007 1.2606e-03 2.7801e-05 2.6911e-05 2.8437e-05 1.7485e-09 1.7403e-06 0:00:04 3
1008 1.2089e-03 2.6705e-05 2.5912e-05 2.7309e-05 1.3380e-09 1.5969e-06 0:00:03 2
1009 1.1629e-03 2.5725e-05 2.5014e-05 2.6317e-05 1.0354e-09 1.4806e-06 0:00:01 1
1010 1.1216e-03 2.4830e-05 2.4187e-05 2.5422e-05 8.0960e-10 1.3857e-06 0:00:00 0
Flow time = 0.02850000000000002s, time step = 57
3943 more time stepsUpdating solution at time levels N and N-1.
Time = 0.177 seconds.
Cell count 85945 86176 430402
Mean cell count deviation -0.2% 0.1%
Partition boundary cell count 2076 3209 13616
Partition boundary cell count ratio 2.4% 3.7% 3.2%Face count 176814 178009 880022
Mean face count deviation -0.4% 0.3%
Partition boundary face count 2224 3524 7484
Partition boundary face count ratio 1.3% 2.0% 0.9%Cell weights 9e+05 9e+05 4e+06
Mean cell weight deviation -0.2% 0.1%Partition neighbor count 2 4
1010 1.1216e-03 2.4830e-05 2.4187e-05 2.5422e-05 8.0960e-10 1.3857e-06 0:00:26 20
1011 1.2357e-02 6.1944e-04 5.7173e-04 3.8533e-03 3.8781e-04 8.9220e-03 0:00:27 19
1012 9.0693e-03 2.1804e-04 1.9980e-04 1.0427e-03 8.6927e-05 2.8045e-03 0:00:28 18
1013 6.4031e-03 1.1041e-04 1.0077e-04 3.2774e-04 2.0001e-05 6.5584e-04 0:00:24 17
1014 4.9423e-03 7.9098e-05 7.3375e-05 1.3134e-04 4.7995e-06 1.8342e-04 0:00:22 16
1015 4.0497e-03 6.5249e-05 6.1421e-05 7.6290e-05 1.2336e-06 5.8128e-05 0:00:19 15
1016 3.3631e-03 5.6357e-05 5.3482e-05 6.1594e-05 3.5581e-07 2.2807e-05 0:00:20 14
1017 2.8643e-03 4.9969e-05 4.7665e-05 5.4107e-05 1.2287e-07 1.1923e-05 0:00:17 13
1018 2.5106e-03 4.5238e-05 4.3295e-05 4.8461e-05 5.3204e-08 7.8923e-06 0:00:15 12
1019 2.2486e-03 4.1608e-05 3.9970e-05 4.4103e-05 2.8411e-08 5.9917e-06 0:00:16 11
1020 2.0447e-03 3.8749e-05 3.7373e-05 4.0750e-05 1.7561e-08 4.8601e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1021 1.8816e-03 3.6443e-05 3.5244e-05 3.8094e-05 1.1835e-08 4.1015e-06 0:00:11 9
1022 1.7485e-03 3.4534e-05 3.3444e-05 3.5915e-05 8.0691e-09 3.5551e-06 0:00:11 8
1023 1.6379e-03 3.2896e-05 3.1902e-05 3.4085e-05 5.6777e-09 3.1453e-06 0:00:09 7
1024 1.5443e-03 3.1474e-05 3.0562e-05 3.2523e-05 4.0875e-09 2.8277e-06 0:00:08 6
1025 1.4641e-03 3.0216e-05 2.9368e-05 3.1147e-05 2.9961e-09 2.5755e-06 0:00:06 5
1026 1.3947e-03 2.9083e-05 2.8300e-05 2.9922e-05 2.2297e-09 2.3717e-06 0:00:05 4
1027 1.3343e-03 2.8058e-05 2.7337e-05 2.8822e-05 1.6818e-09 2.2027e-06 0:00:04 3
1028 1.2810e-03 2.7115e-05 2.6456e-05 2.7830e-05 1.2842e-09 2.0730e-06 0:00:02 2
1029 1.2338e-03 2.6254e-05 2.5647e-05 2.6930e-05 9.9161e-10 1.9752e-06 0:00:01 1
1030 1.1916e-03 2.5458e-05 2.4896e-05 2.6103e-05 7.7385e-10 1.8764e-06 0:00:00 0
Flow time = 0.02900000000000002s, time step = 58
3942 more time stepsUpdating solution at time levels N and N-1.
1030 1.1916e-03 2.5458e-05 2.4896e-05 2.6103e-05 7.7385e-10 1.8764e-06 0:00:26 20
1031 1.2419e-02 5.6654e-04 4.9459e-04 2.1468e-03 3.8779e-04 8.8851e-03 0:00:28 19
1032 9.1017e-03 2.1306e-04 1.8616e-04 6.2731e-04 8.6949e-05 2.8646e-03 0:00:24 18
1033 6.3289e-03 1.1389e-04 1.0060e-04 2.2567e-04 2.0008e-05 6.6097e-04 0:00:25 17
1034 4.8549e-03 8.3866e-05 7.5945e-05 1.0948e-04 4.8003e-06 1.8591e-04 0:00:22 16
1035 3.9608e-03 6.9451e-05 6.3853e-05 7.5128e-05 1.2326e-06 5.9030e-05 0:00:20 15
1036 3.2768e-03 5.9790e-05 5.5449e-05 6.3423e-05 3.5475e-07 2.2801e-05 0:00:20 14
1037 2.7884e-03 5.2821e-05 4.9300e-05 5.5819e-05 1.2201e-07 1.1504e-05 0:00:18 13
1038 2.4443e-03 4.7511e-05 4.4609e-05 4.9937e-05 5.2553e-08 7.3458e-06 0:00:15 12
1039 2.1914e-03 4.3355e-05 4.0943e-05 4.5276e-05 2.7911e-08 5.4132e-06 0:00:16 11
1040 1.9969e-03 4.0028e-05 3.8029e-05 4.1580e-05 1.7171e-08 4.2975e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1041 1.8433e-03 3.7313e-05 3.5612e-05 3.8596e-05 1.1528e-08 3.5409e-06 0:00:11 9
1042 1.7192e-03 3.5062e-05 3.3589e-05 3.6153e-05 7.8328e-09 2.9973e-06 0:00:11 8
1043 1.6167e-03 3.3163e-05 3.1859e-05 3.4111e-05 5.4944e-09 2.5912e-06 0:00:09 7
1044 1.5305e-03 3.1534e-05 3.0370e-05 3.2388e-05 3.9445e-09 2.2892e-06 0:00:08 6
1045 1.4574e-03 3.0127e-05 2.9071e-05 3.0903e-05 2.8838e-09 2.0325e-06 0:00:07 5
1046 1.3948e-03 2.8890e-05 2.7919e-05 2.9605e-05 2.1411e-09 1.8293e-06 0:00:05 4
1047 1.3407e-03 2.7786e-05 2.6891e-05 2.8448e-05 1.6117e-09 1.6626e-06 0:00:04 3
1048 1.2936e-03 2.6800e-05 2.5971e-05 2.7435e-05 1.2281e-09 1.5233e-06 0:00:03 2
1049 1.2524e-03 2.5899e-05 2.5136e-05 2.6484e-05 9.4654e-10 1.4055e-06 0:00:01 1
1050 1.2159e-03 2.5081e-05 2.4373e-05 2.5639e-05 7.3752e-10 1.3056e-06 0:00:00 0
Flow time = 0.02950000000000002s, time step = 59
3941 more time stepsUpdating solution at time levels N and N-1.
1050 1.2159e-03 2.5081e-05 2.4373e-05 2.5639e-05 7.3752e-10 1.3056e-06 0:00:25 20
1051 1.2985e-02 7.1272e-04 6.2200e-04 1.3446e-03 3.8778e-04 8.6923e-03 0:00:23 19
1052 9.3822e-03 2.6161e-04 2.3056e-04 4.3989e-04 8.6973e-05 2.7313e-03 0:00:25 18
1053 6.4780e-03 1.3391e-04 1.1920e-04 1.8948e-04 2.0016e-05 6.4263e-04 0:00:22 17
1054 4.9547e-03 9.4753e-05 8.6111e-05 1.1152e-04 4.8009e-06 1.8225e-04 0:00:20 16
1055 4.0330e-03 7.7124e-05 7.1056e-05 8.4302e-05 1.2316e-06 5.8464e-05 0:00:21 15
1056 3.3280e-03 6.5709e-05 6.1041e-05 7.1037e-05 3.5366e-07 2.2994e-05 0:00:18 14
1057 2.8213e-03 5.7569e-05 5.3737e-05 6.1925e-05 1.2115e-07 1.1915e-05 0:00:16 13
1058 2.4656e-03 5.1458e-05 4.8145e-05 5.4896e-05 5.1905e-08 7.8293e-06 0:00:17 12
1059 2.2036e-03 4.6662e-05 4.3788e-05 4.9356e-05 2.7425e-08 5.9059e-06 0:00:15 11
1060 2.0014e-03 4.2778e-05 4.0322e-05 4.4950e-05 1.6802e-08 4.7782e-06 0:00:13 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1061 1.8408e-03 3.9560e-05 3.7482e-05 4.1407e-05 1.1245e-08 4.0190e-06 0:00:13 9
1062 1.7116e-03 3.6858e-05 3.5117e-05 3.8499e-05 7.6232e-09 3.4658e-06 0:00:11 8
1063 1.6050e-03 3.4562e-05 3.3096e-05 3.6076e-05 5.3388e-09 3.0623e-06 0:00:09 7
1064 1.5153e-03 3.2603e-05 3.1360e-05 3.4018e-05 3.8290e-09 2.7479e-06 0:00:08 6
1065 1.4388e-03 3.0914e-05 2.9832e-05 3.2249e-05 2.7983e-09 2.4991e-06 0:00:07 5
1066 1.3729e-03 2.9448e-05 2.8482e-05 3.0695e-05 2.0781e-09 2.2984e-06 0:00:05 4
1067 1.3157e-03 2.8156e-05 2.7293e-05 2.9331e-05 1.5655e-09 2.1340e-06 0:00:04 3
1068 1.2656e-03 2.7010e-05 2.6255e-05 2.8125e-05 1.1949e-09 1.9986e-06 0:00:03 2
1069 1.2213e-03 2.5977e-05 2.5315e-05 2.7025e-05 9.2316e-10 1.8859e-06 0:00:01 1
1070 1.1819e-03 2.5041e-05 2.4454e-05 2.6020e-05 7.2146e-10 1.7899e-06 0:00:00 0
Flow time = 0.03000000000000002s, time step = 60
3940 more time stepsUpdating solution at time levels N and N-1.
1070 1.1819e-03 2.5041e-05 2.4454e-05 2.6020e-05 7.2146e-10 1.7899e-06 0:00:24 20
1071 1.2641e-02 6.2321e-04 5.5314e-04 2.1275e-03 3.8778e-04 8.5995e-03 0:00:26 19
1072 9.3712e-03 2.3202e-04 2.0716e-04 6.3496e-04 8.6996e-05 2.7724e-03 0:00:23 18
1073 6.5288e-03 1.1867e-04 1.0664e-04 2.3035e-04 2.0024e-05 6.4801e-04 0:00:24 17
1074 5.0201e-03 8.3739e-05 7.6600e-05 1.1286e-04 4.8016e-06 1.8373e-04 0:00:22 16
1075 4.1048e-03 6.8126e-05 6.3208e-05 7.7018e-05 1.2307e-06 5.8981e-05 0:00:19 15
1076 3.4006e-03 5.8048e-05 5.4291e-05 6.3407e-05 3.5268e-07 2.3259e-05 0:00:20 14
1077 2.8894e-03 5.0776e-05 4.7721e-05 5.4982e-05 1.2039e-07 1.2112e-05 0:00:17 13
1078 2.5267e-03 4.5313e-05 4.2742e-05 4.8548e-05 5.1347e-08 7.9951e-06 0:00:15 12
1079 2.2548e-03 4.1096e-05 3.8893e-05 4.3563e-05 2.7010e-08 6.0742e-06 0:00:13 11
1080 2.0413e-03 3.7740e-05 3.5836e-05 3.9696e-05 1.6488e-08 4.9574e-06 0:00:14 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1081 1.8698e-03 3.5009e-05 3.3361e-05 3.6632e-05 1.1005e-08 4.2055e-06 0:00:12 9
1082 1.7288e-03 3.2750e-05 3.1330e-05 3.4137e-05 7.4437e-09 3.6587e-06 0:00:12 8
1083 1.6108e-03 3.0844e-05 2.9614e-05 3.2064e-05 5.2038e-09 3.2539e-06 0:00:09 7
1084 1.5107e-03 2.9200e-05 2.8136e-05 3.0304e-05 3.7268e-09 2.9315e-06 0:00:08 6
1085 1.4246e-03 2.7783e-05 2.6839e-05 2.8787e-05 2.7208e-09 2.6735e-06 0:00:07 5
1086 1.3497e-03 2.6544e-05 2.5693e-05 2.7452e-05 2.0193e-09 2.4712e-06 0:00:05 4
1087 1.2844e-03 2.5443e-05 2.4677e-05 2.6275e-05 1.5209e-09 2.3047e-06 0:00:04 3
1088 1.2264e-03 2.4459e-05 2.3760e-05 2.5222e-05 1.1610e-09 2.1632e-06 0:00:03 2
1089 1.1748e-03 2.3570e-05 2.2930e-05 2.4270e-05 8.9761e-10 2.0335e-06 0:00:01 1
1090 1.1286e-03 2.2760e-05 2.2172e-05 2.3405e-05 7.0227e-10 1.9226e-06 0:00:00 0
Flow time = 0.03050000000000002s, time step = 61
3939 more time stepsUpdating solution at time levels N and N-1.
1090 1.1286e-03 2.2760e-05 2.2172e-05 2.3405e-05 7.0227e-10 1.9226e-06 0:00:25 20
1091 1.3139e-02 5.6394e-04 4.7837e-04 3.5168e-03 3.8779e-04 8.5083e-03 0:00:27 19
1092 9.4228e-03 2.2374e-04 1.9473e-04 1.0079e-03 8.7022e-05 2.8052e-03 0:00:24 18
1093 6.4358e-03 1.2209e-04 1.0810e-04 3.3384e-04 2.0032e-05 6.4433e-04 0:00:22 17
1094 4.8679e-03 8.8025e-05 8.0109e-05 1.4307e-04 4.8022e-06 1.8263e-04 0:00:23 16
1095 3.9202e-03 7.1076e-05 6.5683e-05 8.5857e-05 1.2296e-06 5.8906e-05 0:00:20 15
1096 3.1989e-03 6.0097e-05 5.5831e-05 6.7412e-05 3.5157e-07 2.3374e-05 0:00:18 14
1097 2.6805e-03 5.2244e-05 4.8760e-05 5.7527e-05 1.1952e-07 1.2164e-05 0:00:18 13
1098 2.3146e-03 4.6364e-05 4.3470e-05 5.0340e-05 5.0692e-08 7.9459e-06 0:00:16 12
1099 2.0442e-03 4.1831e-05 3.9357e-05 4.4826e-05 2.6516e-08 5.9470e-06 0:00:14 11
1100 1.8359e-03 3.8197e-05 3.6034e-05 4.0555e-05 1.6111e-08 4.7322e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1101 1.6702e-03 3.5203e-05 3.3303e-05 3.7118e-05 1.0712e-08 3.9450e-06 0:00:12 9
1102 1.5357e-03 3.2701e-05 3.0989e-05 3.4283e-05 7.2240e-09 3.3824e-06 0:00:10 8
1103 1.4252e-03 3.0583e-05 2.9026e-05 3.1898e-05 5.0373e-09 2.9728e-06 0:00:09 7
1104 1.3329e-03 2.8756e-05 2.7329e-05 2.9872e-05 3.5994e-09 2.6418e-06 0:00:08 6
1105 1.2548e-03 2.7179e-05 2.5850e-05 2.8142e-05 2.6225e-09 2.3755e-06 0:00:07 5
1106 1.1879e-03 2.5795e-05 2.4556e-05 2.6642e-05 1.9427e-09 2.1624e-06 0:00:05 4
1107 1.1306e-03 2.4562e-05 2.3408e-05 2.5322e-05 1.4608e-09 2.0095e-06 0:00:04 3
1108 1.0810e-03 2.3465e-05 2.2377e-05 2.4158e-05 1.1131e-09 1.8522e-06 0:00:03 2
1109 1.0378e-03 2.2465e-05 2.1457e-05 2.3106e-05 8.5880e-10 1.7227e-06 0:00:01 1
1110 9.9923e-04 2.1559e-05 2.0632e-05 2.2157e-05 6.7031e-10 1.7746e-06 0:00:00 0
! 1110 solution is converged
Flow time = 0.03100000000000002s, time step = 62
3938 more time stepsUpdating solution at time levels N and N-1.
1110 9.9923e-04 2.1559e-05 2.0632e-05 2.2157e-05 6.7031e-10 1.7746e-06 0:00:28 20
1111 1.2520e-02 6.2365e-04 5.6163e-04 4.4502e-03 3.8780e-04 8.3229e-03 0:00:29 19
1112 9.1933e-03 2.3217e-04 2.0835e-04 1.2462e-03 8.7047e-05 2.6947e-03 0:00:26 18
1113 6.2247e-03 1.1761e-04 1.0587e-04 3.8864e-04 2.0039e-05 6.3060e-04 0:00:23 17
1114 4.6585e-03 8.2690e-05 7.5752e-05 1.5234e-04 4.8024e-06 1.8013e-04 0:00:23 16
1115 3.7206e-03 6.6751e-05 6.1895e-05 8.3832e-05 1.2285e-06 5.8778e-05 0:00:21 15
1116 2.9925e-03 5.6262e-05 5.2502e-05 6.3218e-05 3.5051e-07 2.3894e-05 0:00:18 14
1117 2.4662e-03 4.8584e-05 4.5508e-05 5.3496e-05 1.1874e-07 1.2966e-05 0:00:19 13
1118 2.0959e-03 4.2710e-05 4.0132e-05 4.6412e-05 5.0135e-08 8.9235e-06 0:00:16 12
1119 1.8208e-03 3.8095e-05 3.5916e-05 4.0874e-05 2.6114e-08 7.0244e-06 0:00:14 11
1120 1.6077e-03 3.4398e-05 3.2528e-05 3.6518e-05 1.5815e-08 5.9494e-06 0:00:12 10iter continuity x-velocity y-velocity z-velocity k omega time/iter
1121 1.4381e-03 3.1360e-05 2.9732e-05 3.3015e-05 1.0491e-08 5.1594e-06 0:00:12 9
1122 1.3004e-03 2.8820e-05 2.7393e-05 3.0147e-05 7.0614e-09 4.5955e-06 0:00:10 8
1123 1.1868e-03 2.6665e-05 2.5400e-05 2.7757e-05 4.9166e-09 4.2141e-06 0:00:09 7
1124 1.0914e-03 2.4807e-05 2.3682e-05 2.5741e-05 3.5092e-09 3.9041e-06 0:00:08 6
1125 1.0103e-03 2.3189e-05 2.2177e-05 2.4008e-05 2.5550e-09 3.6435e-06 0:00:07 5
1126 9.4107e-04 2.1778e-05 2.0850e-05 2.2501e-05 1.8922e-09 3.4543e-06 0:00:05 4
! 1126 solution is converged
Flow time = 0.03150000000000002s, time step = 63
3937 more time stepsUpdating solution at time levels N and N-1.
>> Dividing domain into 5 partitions using Metis.
Time = 0.189 seconds.
Done.>> 5 Stored Partitions:
Collective Partition Statistics: Minimum Maximum Total
Cell count 85736 85765 428741
Partition boundary cell count 2127 2996 13206
Partition boundary cell count ratio 2.5% 3.5% 3.1%Face count 176239 177370 876700
Mean face count deviation -0.3% 0.3%
Partition boundary face count 2312 3310 7232
Partition boundary face count ratio 1.3% 1.9% 0.8%Cell weights 9e+05 9e+05 4e+06
Partition Method Metis
Stored Partition Count 5
Done.Smoothing partition boundaries...done.
WARNING: 1 cells with non-positive volume detected.
Error at host: Update-Dynamic-Mesh failed. Negative cell volume detected.===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: Update-Dynamic-Mesh failed. Negative cell volume detected.
Error Object: #f
Registering ReportDefFiles, ("C:\Users\Alberto\Desktop\falling_seed\seed_one_files\dp0\FFF\Fluent\.\\drag-rfile.out")Calculation complete.
(cx-gui-do cx-activate-item "Error*OK")
(cx-gui-do cx-activate-item "Information*OK")
- The topic ‘Simulation crash without error’ is closed to new replies.
- affinity not set
4167
1487
1358
1189
