May 24, 2024 at 2:56 pm
geff
SubscriberI am conducting a unit cell simulation of the 2DEG model to compare transmission results. One scenario uses a sheet with layered impedance as a boundary condition, and the other employs a rectangular box with material properties assigned based on 2DEG characteristics. The transmission results align with the analytical equation when using the sheet, but the rectangular box scenario results in zero transmission. Any suggestions would be welcome.
May 28, 2024 at 12:58 pm
Praneeth
Bbp_moderatorHi,
Thank you for reaching out to the Ansys learning forum.Â
Please let us know which design type of the AEDT you are using to help us serve you better.
If possible, please do share screenshots of the model for a better understanding.
Best regards,
Praneeth. -
July 18, 2024 at 2:31 am
- The topic ‘Simulation 2DEG using Drude model.’ is closed to new replies.
3492
1057
1051
965
942
