Simulating the working principle of cylindrical heat pipe with wick stracture?
    • nagesh56
      heat pipe is hallow tube with both ends closed and charged with working fluid at optimum fill ratio.tube surface is divided into three sections heater,adiabatic and condensor.heat input is given at heater section(constant temp)and condensor is also maintained at constant temperature.liquid is evaporated at heater section and vapour travells towards condensor section through core section and it is condensed.condensed liquid from bottom is lifted to heater section by capillary action generated by the wick stracture(i.e.copper porous media),which is wrappped around the inner pheriphery of heat pipe . It inludes process like phase change of working fluid (evaporation and condensation)and flow through porous media.Iam using ANSYS fluent to simulate the process. so,please can anyone help me i
    • Keyur Kanade
      Can you please elaborate on what is exact question.
      Keyur
      Best practices to fully leverage the ANSYS Academic Community:
      • Be efficient - As our community grows it is becoming more likely that you are not the first to ask this question. Please search before creating a new post.
      • Be clear - Provide supporting screenshots, error messages, and background information. No simulation files will be opened by ANSYS support engineers.
      • Be precise  - Please use the right tags to help our engineers find your question.
      • Be patient - Please allow three days for someone to get back to you, if you have an urgent question, please email your ANSYS Account Manager.
      • Be helpful - Please help our community grow by answering other's questions and telling your academic colleagues about this resource.
    • nagesh56
      it is operated in a vertical position with evaporator section at the top and condenser at the bottom. the wick structure is porous media.half of the tube is filled initially
    • Keyur Kanade
      Is this same as in following thread?
      /forum/forums/topic/simulation-of-a-thermosyphon-heat-pipe/
    • Chaitanya
      sir, will you find the solution to simulate the problem? Please help me
      And don't cross post.
Viewing 5 reply threads
  • The topic ‘Simulating the working principle of cylindrical heat pipe with wick stracture?’ is closed to new replies.
