Electronics
Electronics
Simulating Inductive PCB Sensor at MHz
    • rhd94
      which tool (Maxwell or HFSS) is the best to simulate the signals (in voltage) generated by induced eddy currents with 3 MHz ? The sensor is composed of one primary excitation coil and two receiver coils (see attachment). The primary coil is inducing eddy currents within a copper plate.
      My goal is to see the reactions from the receiver coils due to the interference with the eddy currents.
    • rtk
      As you requirement is for simulate signals induced with 3 MHz, I would suggest to go with Ansys Maxwell, which will fulfill your requirement.
      For further procedural check please refer to Maxwell help document.
  • The topic ‘Simulating Inductive PCB Sensor at MHz’ is closed to new replies.
