November 12, 2024 at 3:07 pm
tahnguyen
SubscriberHello everyone,
I’m working on a simulation involving vacuum flow through a flexible hose rubber liner. My goal is to analyze how the rubber liner reacts to the vacuum flow. I would appreciate any suggestions or guidance on how to approach this simulation.
Thank you in advance for your help!
November 12, 2024 at 3:25 pm
Forum ModeratorStrictly we can't model vacuum in the CFD tools as the continuity assumption isn't valid. Technically there'a also nothing to flow? If you're looking at how a vacuum effects a hose shape I'd go with Mechanical and assign a pressure (force?) to the inner and outer walls. The Mechanical channel wil be able to give more comprehensive advice.Â
