Photonics
Photonics
Simulate two ports of MMI
    • minusunny
      I would like to simulate MMI , both ports. When i do the s-parameter extraction for the power  should i look at
      abs^2(S11),abs^2(S12),abs^2(S13),abs^2(S14) - For the power at output ports because of port 1
       and abs^2(S31),abs^2(S32),abs^2(S33),abs^2(S34) -For the power at output ports because of port 3?
      Also , the values i get for transmission is different from S- parameter sweep (Same as T expansion monitor value) but that values does not make sense, but the Transmission 'T' values look reasonable.
      How can i get that value?
      How can i get transmission values from the s parameter sweep?
       Is there an alternate way to do this simulation ?
      Thank you
    • Niki Papachristou
      Hi Minusunny,
      Thank you for reaching out to us. Have you gone through our application gallery example: Multi-Mode Interference (MMI) Coupler? I think the described procedure is very similar to what you want to achive.
      Kind Regards,
      Niki
    • minusunny
      I am using SWG based MMI.  Can i use EME? I used FDTD for that. Can i use the same s parameter extraction for FDTD? Also, i did an s parameter sweep in FDTD and saved the sparameter value in lumerical format and exported it to the interconnect i got this error:
      SPAR_1: Fitting for '256' coefficients...
      SPAR_1: Error in fit is '0.00109188'.
      SPAR_1: Calculating filter coefficients at '1.931e+14' Hz ...
      SPAR_1: Error in fit is '0.00171933'.
      SPAR_1: Error in fit is '0.0020334'.
      SPAR_1: Error in fit is '0.00203526'.
      Is it because i did not use the right format to export?
  • The topic ‘Simulate two ports of MMI’ is closed to new replies.
