January 1, 2025 at 12:21 pm
Chen Yi
SubscriberI simulate seal ring contact max pressure by workbench,fluid pressure was applied during the simulation,then I check the maximum contact pressure.I find there are two ways,but I can't confirm which way is right.These two way result like below.If I want use the second way(the last pic),what need I do ? thank you.
January 2, 2025 at 10:00 am
Deepak
Ansys EmployeeHey,
These are different representations of the pressure contours.
You may refer to this material Applications of Contact | Ansys Innovation Courses; Analysis of an O-ring Seal — Lesson 3 | ANSYS Innovation Courses on o-ring.
Thanks,
Deepak
January 2, 2025 at 11:26 am
Chen Yi
SubscriberI have see this video,but I can't find how to set about maximum contact pressure,can you tell me how use pressure contours to show the maximum contact pressure(like last picture).Thank you.
January 2, 2025 at 11:52 am
Deepak
Ansys EmployeeCan u please share the source of the second plot?
January 3, 2025 at 7:37 am
Chen Yi
SubscriberThe second plot from one paper,there are many picture like this to show maximum contact pressure.I'm not sure this display is correct.Can you help me to confirm. Thank you.
from CNKI 《基于ANSYS的O形圈活动量对密封性能影响探究》
January 4, 2025 at 7:26 am
Chen Yi
SubscriberHi Deepak:
Can you help me to confirm and how to set to show like the second plot?
Thank you.
January 6, 2025 at 8:23 am
Deepak
Ansys EmployeeHi,
I was not allowed to access the links. But I think they used another external extension to plot as a vector.
Max pressure can also be indicated in 1st plot.
Thanks,
Deepak
January 6, 2025 at 9:44 am
Chen Yi
SubscriberHello Deepak:
Do you know how to display vector plot when I use workbench simulate o-ring maximum contact pressure? Or can I only rely on external extension ?
thank you.
January 7, 2025 at 9:45 am
Deepak
Ansys EmployeeWe do not have any for that as far as I know I am afraid.
January 9, 2025 at 1:48 am
Chen Yi
OK ,Thank you.In other words,how it is used to evaluate sealing performance?Whether to look the maximum contact pressure like the first picture? Now I want to confirm if I use the first picture,is it right ? Thank you.
January 13, 2025 at 3:22 am
Chen Yi
Can you help me ?Thank you.
January 13, 2025 at 8:34 am
Deepak
Ansys EmployeeThe probe can be used to identify the location of max. pressure
5719
