August 20, 2024 at 10:11 am
alexandre-antoi.bourrieau
SubscriberHello,
Just a question I have...
I would like to bring into play the mode conversion phenomenon induced on a differential pair by the variation of the dielectric constant on a FR4 for example. That is, creation of common mode insertion and return loss due to assymetries of the two lines due time delay variation because of epsilon variation.
Do you know if it is possible under Ansys HFSS to configure the dielectric constant by ensuring that it varies "spatially" by a certain percentage... A sort of stochastic dielectric constant, but with spatial variation ?
Or maybe this is possible in another way?
Or perhaps, is there other tools (like SIwave or others ... ??) wich can take it into account for SI analysis ??
Thanks you ! -
September 11, 2024 at 2:16 pm
Praneeth
Ansys EmployeeHi Alexandre,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
It is possible to vary the material properties in Ansys HFSS. For your case, you can vary the relative permittivity of the material using the spatial modifier option. You can also import material property dataset for spatial variation.
Please go through "Spatially Dependent Materials in HFSS" section of the HFSS help document for detailed information.
Best regards,
Praneeth.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4618
1530
1386
1209
