TAGGED: ansys-simplorer, co-simulation, permanent-magnet, simplorer, speed
October 21, 2020 at 8:52 am
AissamRiad
SubscriberHi,
I'am using the Toyota Prius IPM Model, and I want to run it on SIMPLORER
But since it's my first time using I don't understand all of pins usage, I'm using the circuit shown down below in order to test my model under a certain speed and a certain torque, and I'm getting weird results.
Any help will be welcomed
Thanks in advance
October 24, 2020 at 2:09 amOctober 26, 2020 at 1:45 pmAissamRiad
SubscriberThanks for your answer nI replaced the gnd block as you told me , but the same thing is occuring , i'm not getting the results i want nand for the help PDF , i'm using TWINBUILDER , so the seach table have changed a little bit i can't find what you told to look forndo you have some example of a motor simulation on simplorer and that did give the same results as in ansys maxwellnnThanks in advancenOctober 27, 2020 at 2:22 pmicellb1
Ansys EmployeeHi, Array ,nJust change simplorer to twinbuilder: Twinbuilder Help-->Twinbuilder components-->product coupling-->Twinbuilder coupling-->Maxwell coupling component-->Maxwell Transient Cosimulation Component.nUnfortunately we are not allowed to share files to you. There are public access-able youtube videos related to co-simulation: nhttps://www.youtube.com/watch?v=AAE6-OH0iZc&list=PLNLmSKqKLg4erJWZTVtarp1CKY3drhpS6&index=28nAnother way is to use equivalent circuit extraction(ECE) instead of transient co-simulation. If you have access to ansys learning hub, there is an advance motor training course on Maxwell-simplorer ECE. Here is also a video about ECE(though not on motor): https://www.youtube.com/watch?v=N11SUUnOvTY&list=PLNLmSKqKLg4erJWZTVtarp1CKY3drhpS6&index=36nJuly 18, 2023 at 2:09 amWaqas
SubscriberHi...Were you ever able to solve your problem. I am also having a difficulty in getting resullts from the co simulation between Twin builder (Simplorer) and Maxwell.Viewing 4 reply threads- The topic ‘SIMPLORER Co-simulation’ is closed to new replies.
