Electronics
Electronics
Simple eddy current simulation eddy current opposite direction
    • KMoula30
    • NKC
      Hi @KMoula30 The cause, which is the current in the coil is counterclockwise.
      So, the effect will be in a clockwise direction.
      If you are applying Right hand thumb rule, it will apply only to the coil, and its filed as the source current is flowing in the coil only.
      Regards Navya
    • KMoula30
      Why is that?
      In the sheet the B is in +x direction so if we apply right hand rule for the B the current must be counter clockwised
  • The topic ‘Simple eddy current simulation eddy current opposite direction’ is closed to new replies.
