August 5, 2023 at 2:43 pm
SAURAV GAUTAM
Subscriberis it possible to simulate a dopped silicon structure in FDTD to get change in absorption due to dopping in FDTD?
or it can only be modeled in CHARGE?
Please share link if there is any example available
thank you
August 6, 2023 at 12:18 am
Dev
Ansys EmployeeHello, Â As far as I know, there is no direct way to perform doping to materials in FDTD. In FDTD, you can look for your doped material permittivity then import that data to FDTD.Â
I would sugget to use CHARGE.
Thanks.
- The topic ‘silicon absorption coefficient’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Import material .txt file with script
- Absorption cross-section of AuNR excited by prism-based TIR
- How to measure transmission coefficients on a given plane .
- TE Polarization Fraction + Waveguide TE/TM Fraction
- Edge Coupler EME Example Issue
- Lumerical Python API Topology Optimization Error 2025 R1
- 2D inverse design grating coupler
- FDE : Simulation waveguides with electrodes
- Loss of lithium niobate phase modulator
930
599
591
559
