October 11, 2023 at 2:56 pm
Douglas Cutshall
SubscriberI am using the following command to silent install the software, which is working great. However, when I go to launch the server info is not being imported correctly.
Here is the command I'm using:
"\\xxxx-shares\SiteSoftware\xxxx\Engineering\Ansys STK\Ansys_STK_Pro_v12.7.1\STK_v12.7.1\install.exe" /s /licenseagree /licserverinfo 2325:1055:xxxx-LIC-SRV
I have tried it like this: /licserverinfo 1055:xxxx-LIC-SRV; xxxx-LIC-SRV:1055 and neither has worked. I have to manually configure the server. -
October 11, 2023 at 3:30 pm
Douglas Cutshall
SubscriberI resolved it myself after trying different configs…and this is the one that worked for me:
”\\xxxx-shares\SiteSoftware\xxxx\Engineering\Ansys STK\Ansys_STK_Pro_v12.7.1\STK_v12.7.1\install.exe” /s /licenseagree /licserverinfo 1055:xxxx-LIC-SRVIf you are testing your silent install script, you may want to re-image your machine before implementing a new script as the licserverinfo is stored.
Hope this helps someone in the future.
- The topic ‘Silent Install – LicServerInfo Switch Not Working’ is closed to new replies.
4592
1494
1386
1209
