January 10, 2025 at 12:11 am
jmsz7x
SubscriberUsing the DEFINE_HEAT_FLUX udf, I get errors when interpreting, and when compiling I am not able to apply the udf. But when I interpret after compiling, I am able to apply it, but i get this error when running:
Node 2: Process 23384: Received signal SIGSEGV.
Node 1: Process 3268: Received signal SIGSEGV.
Node 0: Process 23128: Received signal SIGSEGV.
Node 3: Process 25308: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No error
In file included from C:\\PROGRA~1\\ANSYSI~1\\v232\\fluent\\fluent23.2.0/src/udf/udf.h:22,
from C:/Users/jmsz7x/Documents/Rc.c:1:
C:\\PROGRA~1\\ANSYSI~1\\v232\\fluent\\fluent23.2.0/src/main/global.h:287: badly punctuated parameter list in
#define'In file included from C:\\PROGRA~1\\ANSYSI~1\\v232\\fluent\\fluent23.2.0/src/dpm/dpm_tools.h:10,
from C:\\PROGRA~1\\ANSYSI~1\\v232\\fluent\\fluent23.2.0/src/udf/udf.h:54,
C:\\PROGRA~1\\ANSYSI~1\\v232\\fluent\\fluent23.2.0/src/dpm/dpm_parallel.h:631: badly punctuated parameter list in#define'
The fl process could not be started.
Can anybody help?
January 10, 2025 at 10:01 am
Forum ModeratorIf it fails to compile there's a problem with the code. The interpreter isn't as rigorous and doesn't permit all macros so isn't used as much now.Â
January 10, 2025 at 5:36 pm
jmsz7x
SubscriberHi rob. Let me clarify, it doesn't fail to compile, I just am not able to apply the boundary condition. I can compile and load the library with no errors.Â
January 13, 2025 at 10:53 am
Forum ModeratorIt's not a boundary condition, it's an adjustment to how Fluent applies the heat flux. The boundary condition is applied on the boundary, DEFINE_HEAT_FLUX isn't, and is covered in the manual.Â
January 13, 2025 at 9:10 pm
jmsz7x
SubscriberThe manual does not mention much at all about the use of the macro. As I mentioned in the initial post, I was able to apply it as a boundary condition, but I am getting errors.
January 14, 2025 at 9:29 am
Forum ModeratorOther than it's not a boundary condition, and to use DEFINE_PROFILE for bc setting. The error is a consequence of DEFINE_HEAT_FLUX not being a boundary condition.Â
January 14, 2025 at 8:13 pm
jmsz7x
SubscriberThank you
5779
