Signed von mises stress
    • ashish35
      I couldn't find any option to view signed Von Mises stress result in Mechanical. Is it possible to view this result?
      Best,
      Ashish
    • Rohith Patchigolla
      Hi Ashish,
      Signed von Mises stress can be calculated using user-defined results.
      Hydrostatic stress is simply the average of the three normal stresses [(sx+sy+sz)/3 ], so dividing the hydrostatic stress by the absolute value of itself will give -1 for compression and +1 for tension [(sx+sy+sz)/abs(sx+sy+sz)].
      This stress sign can be directly multiplied by the unsigned von Mises stress to produce the signed von Mises stress.
      Signed Von Mises = seqv*(sx+sy+sz)/abs(sx+sy+sz)
      But the method breaks down when the hydrostatic stress is zero. So, we add a small number to the equation as shown below.
      Please use the below expression in a user defined result to get the Signed Von Mises stress.
      seqv*(sx+sy+sz+1e-6)/abs(sx+sy+sz+1e-6)
      Hope this helps.
      Best regards,
      Rohith
    • ashish35
      Rohith,
      Thank you so much. This is spot on.
      Best,
      Ashish
    • emmanuel.lecomte
      What could be the python script to calculate this signed Von Mises stress ?
      I try but I failed to calculate the abs value of the formula.
      Thanks
      E.L.
    • Erik Kostson
      This post is from 2018 and is now closed. Open up a new one describing and showing any scripts used so members can provide some help.
      Erik
Viewing 4 reply threads
  • The topic ‘Signed von mises stress’ is closed to new replies.
