January 19, 2024 at 1:20 pm
Cameron Nelson
SubscriberHello,
I'm wondering if you can verify the incidence angle directions for plane wave sources in FDTD and RCWA.Â
In both cases, I am running simulation with a backward propagating plane wave source incident on a diffraction grating strcutre. I am measuring the first order diffraction efficiency. For FDTD, the GUI shows that a negative incidence angle represents a rotation of the plane wave in the counter-clockwise direction. The FDTD and RCWA data is consistent, however it appears as though the sign of the incidence angle is switched. In other words, to make the RCWA AOI-dependent data consistent with FDTD, I have to multiply every incidence angle by -1. Is this discrepancy known?
February 5, 2024 at 8:37 pm
Guilin Sun
Ansys EmployeeThis post will be closed as its questions have been answered in another post /forum/forums/topic/sign-convention-of-diffraction-order-numbers-of-lumerical-fdtd-rcwa/#post-349219.
- The topic ‘Sign convention for incidence angle of plane wave sources in FDTD and RCWA’ is closed to new replies.
5719
