shrinking of a tube
    • ft19
      hello everyone,
      I'm trying to shrink this 3D cylinder in fluent:
      I would like a complete closure of the cylinder maintaining the same thickness. Do you have some suggestion for the dynamic mesh?
    • mli
      Please provide more details of your questions.
    • ft19
      I want to simulate this along all the shape of the tube:
      i would like to pass from the design 1 to the design 2 and then again to design 1
      Yes, that's possible. Have a read through of the Moving Mesh section of the Fluent manual, I think you're looking at rigid body motion and remeshing. Note, the inner diameter cannot become zero as you must maintain the same topology.
      You will probably need a full tet mesh, and I'd suggest refining the mesh.
      It may also be possible to use layering in 2d axi-symmetric which would be much quicker depending on the rest of the model.
    • ft19
      thanks a lot for the answer but can you explain to me what I need to set inside the dynamic mesh and the boundary condition? Because my setting doesn't work and displays "not found zones face" or " negative volume" and I cannot understand why!
      thank you so much!
Viewing 5 reply threads
  • The topic ‘shrinking of a tube’ is closed to new replies.
