October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThe user parameters can not be printed at each iteration. You can get the status of such parameters after the LoadStep or Substep. For this also, you can use *STATUS, parameter_name to get its update. If you want to track any particular result value then you can use NHIST command for result tracking during the solution. You can also use the OUTPR command for controlling the solution printout.
October 4, 2017 at 2:39 pm
nselvara
Ansys EmployeeCan we show User Parameter update on each iteration?
- The topic ‘Showing User Parameter updates…’ is closed to new replies.
