Ansys Products
Ansys Products
showing error in Ansys Fluent 2020R1. Result tool not open in workbench
    • deepakvirkar
      when I try to open the Result tool from workbench it showing Error running C:Program FilesANSYS IncANSYS Studentv201CFD-Postbincfx5post.exe -control-port 50565: The system cannot find the file specified.
    • Adithya0601
      my case is the same fluent is not able to submit the project information to the results tab. Software is saying it is not able to write some compressed data files required for results tab to work."File 'C:UsersADITHYADocumentsP7_X100_filesdp0FFFFluentFFF-1-00001.dat.gz' does not exist or is not readable" so this is happening because software is not able to write that data file required. I thought it was because of installation so i tried reinstalling more than 10 times.
    • tsiriaks
      Hi deepakvirkar,
      I think student version does not include CFD Post, I believe it doesn't have cfx5post.exe executable under C:Program FilesANSYS IncANSYS Studentv201CFD-Postbin   . Workbench is looking for this but it's not there, so it throws that error. You might be able to launch a stand-alone CFD-Post from CFX folder (C:Program FilesANSYS IncANSYS Studentv201CFX) but it means you have to load the result manually and not from Workbench.
      Hi Adithya0601,
      Your issue is different , please create a new thread and post the full output in the Fluent console.
      Thanks,
      Win
    • Varun0608
      Can you please suggest how to load it manually? And also, many of my friends are using student version but cfd post proc is working in their laptop.
      Thanks
    • tsiriaks
      Maybe, you can compare that path in the error message with your friends to see the differences.
      To load results into CFD-Post, please create a thread in Fluid Dynamics section.
      Thanks,
      Win
    • Ayushp729
      Hi Deepak,
      Contrary to speculation of tsiriaks, ANSYS 2020R1 does include CFD-Post.
      I had the same problem for over a week and I am relieved to find it RESOLVED!
      My antivirus (Quick Heal) falsely identified some files (which included CFD/CFX post) during installation as ransomware.
      Disabling your antivirus and then reinstalling ANSYS might help.
      Mark this as thread SOLVED if this is your issue.
    • ShubhamS
      hello, Ayush, i tried your solution of reinstalling the ansys .i even restored the quarantine file from the antivirus but having same error.
    • divyanshj11
      I am getting the same problem ... please help men
    • mainak5293
      Hello...nI am getting the same problem in ANSYS 2021 R1 Student version. The error is:nError running C:\Program Files (x86)\ANSYS Inc\ANSYS Student\v211\CFD-Post\bin\cfx5post.exe -control-port 53325: The system cannot find the file specified.nThis is coming repeatedly when i am trying to open ANSYS CFD- Post. nWhen i tried to open manually through the specified path, I was not able to find CFD-Postn
